Results 1 to 40 of 55
    Senior Member Two Rings grrrrrrr's Avatar
    Mar 27 2008
    valencia, california
    APR Stage 1 meh...
    So i just had APR stage 1 flashed. Is it just me or seems like there's no difference from stock . planning on stage 2 in a few months.
    Forum Moderator Four Rings Loe's Avatar
    Aug 09 2015
    Audi RS E-tron GT, BMW i4 xDrive40
    Sarasota, FL
    it'll take awhile to adapt if you just flashed, but yeah, stage 1 doesn't add too much down low (especially with a 91 octane file) until past 5,500rpm.
    Loe P - Forum Moderator, Audizine
    Sold: ('14 Audi S5 S-tronic: [email protected] (127.36mph highest trap)| +424 ft. D/A | 3.371 PR | full-weight/street tires).
    Current: BMW F82 M4cs, Audi TT RS APR E85 Stage 1 "+" ecu/tcu: [email protected] (Panel filter | 4" turbo inlet | intercooler | stock exhaust, suspension, 18" Neuspeed wheel/tires, | full weight).
    Apr 05 2016
    Portland, OR
    You should be able to feel the difference especially at higher RPMs. (Do a launch?)
    Regardless, I approve of stage II. Sticking with APR?
    Geoff
    Veteran Member Three Rings Silverbullet S4's Avatar
    Mar 10 2015
    CO - 6,200' +
    Quote Originally Posted by Loe View Post
    According to APR, there is no adaptation period. Either way, go Stage II or bust....
    2013 S4 - APR Stage 2+, DP, CPS v3, BLQ 20s, Solo Werks coilovers, CR-15, EBC Rotors F&R, Deval diffuser, AWE exhaust & USP Intake - TD1 inevitable
    Mar 27 2008
    I should have waited and went to stage 2 directly. I'll give it until Monday but I'm thinking of returning to the shop and ask for a refund since APR offers 30 days money back. Also they are asking $375 for labor for pulley install is that fair enough?
    Mar 27 2008
    Quote Originally Posted by whiped View Post
    I actually prefer GIAC but the nearest reputable shop near me only offers APR.
    Mar 10 2015
    CO - 6,200' +
    Quote Originally Posted by grrrrrrr View Post
    Pulley install is a PITA. Price sounds about right.
    Veteran Member Three Rings cjw's Avatar
    Aug 11 2015
    Alberta
    I actually though the jump from stock to Stage I was better than Stage 1 to Stage 2. Don't most dyno's somewhat agree? APR's does.
    2013 Lava Grey S4 S-Tronic
    Injen, EPL DP (3.2 ratio) +TCU, Magnaflow Catback Back to Stock, PLM HX
    Veteran Member Four Rings Thurston's Avatar
    Apr 27 2015
    canada
    yeah stage 2 will be significantly more torquey down low as you know i'm sure. The whole adaptation thing is definitely real but happens quickly, stg 1 really was only noticeable for me above 5k rpm.. I am very glad I went ahead and went with the basic stage 2 set up, it probably won't knock your socks off but it is a solid solid improvement.
    Jul 21 2004
    South Florida
    If the APR dealer could datalog for you that would help a lot. I wouldnt be surpirsed if the junk 91 octane is showing a bunch of knock activity. Throw some e85 in there (up to 30%) before you return it to see if it becomes a different animal. Honestly if I had to live where there was 91 octane I think i'd buy a 55 drum of race fuel and have it in the garage at all times.
    Mike
    2018 Audi S5
    Gone-
    Jun 12 2015
    CA
    90% of the flash's impact is immediate. Only 10% will be felt via adaption later.
    Mar 27 2008
    I think for the cost of stage 1 is a bit high for the perfomance i get imo. or maybe i was just expecting too much.
    Sent from my SM-N920I using Tapatalk
    Jul 21 2004
    South Florida
    If you were getting the full stage 1 performance you could get from full boost and from 93 octane I think you'd likely be blown away by the change but I'm guessing for whatever reason you are not making that power (my best guess was crap octane).
    Mike
    2018 Audi S5
    Gone-
    Mar 27 2008
    Quote Originally Posted by Silverbullet S4 View Post
    i just called back the shop and they said give it a few hundred miles to adapt. If nothing changes they will reflash.
    Veteran Member Four Rings Usa's Avatar
    Dec 23 2013
    B8 S4
    I didnt notice my S2 until the days after.. this is after leaving APR HQ in Opelika, AL and I was given similar guidance.
    S4 (B8) DSG / Quartz Gray Metallic / VAG-COM / 3M Crystalline 70% sides 30% rear / Roc-Euro Intake / APR Stage II / Non-res Milltek / Alu Kreuz Stabilizer / Eurocode Front & Rear Sways & Endlinks / 19x9.5 AG M590 / PSS / RS4 Grill / P3 Gauge / Bilstein PSS10 / AMS Boost Cooler System / ENLAES Rear Spoiler & Diffuser / OSIR Front Splitter
    Mar 27 2008
    Quote Originally Posted by Usa View Post
    was there a difference after the adaption period?
    Mar 10 2015
    CO - 6,200' +
    Funny, they told me it's immediate with no adaptation. Then again I went straight stage II but shouldn't matter. Pretty sure they even posted in the forum somewhere there is no adaptation period but don't care enough to hunt for it.
    Did they tell you full adaptation takes 31 days? ;)
    Mar 27 2008
    hahaha. hopefully my s4 is not slow to adapt to changes.
    Aug 01 2013
    Washington DC area
    I've been running APR Stage 1 for 3 years on 93 and it feel great. For me, it took no more than a 20 mile drive back home to feel the difference after getting the tune. A little more torque and power down low and a whole lot up top past 5K. No experience with 91 octane. DSG tune was icing on the cake when it became available last year. To OP, if you are DSG, get the TCU tune. A bit too expensive for what it is, but worth it. Now that I am past warranty, I am going dual pulley with AWE H/E next week and maybe CW after that if there is still a need for more power, unless APR surprises us with a dedicated dual pulley tune. Keeping fingers crossed.
    Established Member Two Rings Albertaoil's Avatar
    Mar 18 2014
    2012 Audi S4, 2004 VW Passat, 4motion, 2008 GMC 2500HD Duarmax Heavily modified
    Alberta
    Crazy, I did EPL stage one and it was a HUGE difference immediately, even my GF commented on it. I know your APR but I would think they are all very similar.
    2012 Audi S4, CTS Intake, CR-15, LED interior lights + Licence plate. LED fogs. 18% tint all around. EPL stage 1.
    Veteran Member Four Rings cspcrx's Avatar
    Jan 04 2013
    2009 Tacoma, 2007 Harley Softail, 1986 Honda CRX
    Phoenix, az
    Looking at the synopsis numbers on APRs site 91 octane tune is not that dramatic of a change from stock except above 5k. 93 octane tune shows a letter improvement across the board. I would switch to the 93 tune and put some 93 in it.
    2012 Ibis P+ / DSG / Silk Napa / B&O / Sport Diff. / ADS lite / MMI & Nav / APR Stage 2+ & TCU Tuned / Ultra Charger / 184mm KI LIL BITCH / ECS Kohlefaser Luft-Technik Intake / AMS Alpha Cooler / ECS 2-Piece Rotors / Akebono Pads / VMR 803 19x9.5 ET45 265-35-19 PSS / ECS Drivetrain Bushing Inserts / CR-15
    11.8 @ 116mph 2487DA on 93oct file Stage 2+
    THEN THEN THEN Rinse & Repeat!
    Senior Member Two Rings Sudz's Avatar
    Apr 19 2014
    Beer Fridge
    Houston, Texas
    Stage 1 for me pulled more urgently to red line above say 5k rpm.
    Stage 2 added more torque to the low to middle rpm range.
    This was the 93 octane tune.
    2004 A4 Avant USP 6mt, Motoza Tuned
    2015 BMW M4, 6mt, Mineral White Metallic, BPMSport Tuned
    2016 Z06/Z07 Vette
    Veteran Member Four Rings MrFunk's Avatar
    Apr 04 2012
    MSP
    Give it time to adapt. For me this took almost a week (but I don't drive a ton).
    After a while run the stock file.
    You will notice the difference.
    Senior Member Two Rings Wreckm's Avatar
    Oct 30 2013
    San Gabriel California
    anyone around 91 that adds race fuel? ratio? and which tune
    Mar 27 2008
    Quote Originally Posted by MrFunk View Post
    I will give it until monday if there's noimprovement they will reflash it. but not sure how it will help.
    Mar 27 2008
    Quote Originally Posted by Albertaoil View Post
    could be the 91 octane.
    Jan 04 2013
    Phoenix, az
    Quote Originally Posted by Wreckm View Post
    Not race fuel but E85. I mix in 3-4 gal which gets me to almost 94 octane.
    Apr 27 2015
    canada
    I just had mine done at a vw/audi only indy shop and got by for 215$ ! needless to say, they earned my future business (cold front install) w/ a price like that.
    Apr 04 2012
    MSP
    This motor is different to turbo motors also. Stage 1 tune is not as dramatic on a SC motor. The biggest difference is noticed on the highway in higher RPM where boost does not bleed off. If you are looking for more seat of pants low end grunt then you gotta go stage 2.
    Sent from my SM-G925P using Tapatalk
    Dec 23 2013
    B8 S4
    Noticeably, where at first I was skeptical for dropping 2K on a tune/pulley but noticed some higher bands being used... days after it was like a new car... and then you get used to it :)
    My favorite is flashing back to stock for service and driving stock for a few days and then putting the tune back on, so much more boost
    Nov 01 2015
    2012 Q7
    FL
    I had a 93 Stage I for about 3 months. It is noticeable in the high rpm range.
    Now that I'm Stage II and TCU tune, what a night and day difference. Others have said it and they are absolutely right. You can feel the difference from 0 all the way up.
    2014 S4 P+
    APR STAGE II & PULLEY, APR TCU TUNE, 034 X BRACE, REAR SWAY, MOUNT INSERTS, REAR SOLID END LINKS, CR-15, ECS INTAKE, DIPSTICK, F&R SPACERS, REAR WAVE ROTORS, STAINLESS LINES, HPS 5.0 REAR PADS, STOPTECH 380MM BBK
    2012 AUDI Q7
    STOCK
    Aug 11 2015
    Alberta
    I also notice warm weather, not even that hot, seems to affect the feelz. More noticeable in the mid range.
    Mar 18 2014
    Alberta
    I run 94 octane, (petro Canada), they have been out of gas for over three weeks now though.
    Sent from my SM-G920W8 using Tapatalk
    Senior Member Three Rings xpoweruk's Avatar
    Feb 05 2016
    UK
    If I use my revo 1+ on the crappy fuel setting the difference is huge.
    I'd get the 93 file at least as your car will be much happier then :)
    Custom stacked chargecooler
    revo Stage dual pulley with revo intake
    Milltek ValveSonic Exhaust Q5 Brembo 4 Pots
    18x9 Wolfrace ProLite alloys
    Eibach rear ARB & Eibach springs
    Mar 27 2008
    Quote Originally Posted by xpoweruk View Post
    not sure where to find 93 in los angeles
    Feb 05 2016
    UK
    E85 with 91 is just as good if not better
    Quote Originally Posted by cspcrx View Post
    Apr 05 2009
    1984 Audi 4000S Quattro, 1989 Toyota MR2 SC, 1960 Alfa Spider
    SF BayArea
    epl stage 1 plus 4 gallons E85 + tranny tune and I couldn't be happier with mine. without the E85 octane boost to our weak 91, wasn't as forceful of acceleration. Have had a few car guy friends tell me my car pulls harder than anything they have ever driven. Thing about a good stage 1 set up is car actually feels smoother than stock for normal driving, and its easy to put it back to stock for warranty work. stage 2 not so much.
    Jan 04 2013
    Phoenix, az
    I know mine sure likes the mix of 91 & E85 and I am stock, but I have to deal with stupid hot 110+ degree air temps.
    Senior Member Two Rings roadawg's Avatar
    Jan 09 2015
    It's the fuel.
    I think people get so hung up on other details, when fuel is the key. 91 is crap, I'd bet money the ECU is pulling a lot of boost/timing.
    I would strongly recommend to address the fueling issue first before re-flashing. Any companies tune, stage 1/2 whatever will have the same problem. If you reflash, or switch tunes without better fuel you will end right back up where you are.
    I just have an APR flash no pulley and I immediately noticed a difference in power everywhere. The jump from nothing to a flash is way more than the difference from a flash to a pulley.
    Any E85 in your area? If not that really sucks, there isn't much you can do then..
    2012 S4 - Man pedal, sport diff, APR tune, Meisterwerk SS, AWE Exhaust & other goodies.
    Feb 05 2016
    UK
    Quote Originally Posted by roadawg View Post
    If you have access to denatured ethanol you can pop tht in instead (adjust ratio accordingly)
