Results 1 to 6 of 6
    Feb 22 2015
    BMW M3 E46
    United States
    Level Control codes 01400 and 1772 on new compressor and no leaks
    My allroad C5 is currently showing the following codes that reappear even after clearing codes:
    01400 - Suspension Level Control 11-10 - Control Limit Not Reached - Intermittent
    01772 - Signal from Level Control Pressure Sensor (G291) 27-10 - Implausible Signal - Intermittent
    I've recently installed a brand new compressor about a month ago and airsprings about 6 months ago. So i know we're good on leaks.
    The new compressor ran perfect and quickly up until 2 nights ago. i was on the freeway, at level 2. When i slowed down to a traffic light it indicated it was rising to level 3, but the compressor never turned on at all. The yellow suspension light lit up solid on the dash instead after about a minute of trying. When i got home 10 minutes later i turned off the car and back on. the allroad had no issue raising from 2 to 3. The Next day, same issue, level 2 on freeway and when i slowed down to lower speeds the allroad attempted to rise to level 3 but the compressor wouldn't run at all. so the yellow light comes back on. Except this time when i turned off the engine and back on to reattempt, it did not turn on the compressor as well.
    I've already tried a couple times to mitigate the problem, including replacing the relay. Currently its at stuck at level 2 and the compressor has not run since. I've already tested the new compressor by reattaching the old compressor that i still have, im 100% it still runs. But even that won't start up. So i've ruled out that its a compressor issue. I figured the next option was finicky wiring, but he wiring looks good as well and i have not had any problems with changing levels even on rough desert trails.
    Does this leave a faulty g291 sensor or faulty j197 control module as the only possible problems? Thanks in advanced
    Jun 10 2013
    United States
    Its possible that the pump is being overworked (01400) which is due to an incorrect pressure signal from the valve control block (01772). I would try to get vcds on it while driving and monitor the pressure.
    May 20 2010
    Have you checked the level sensors themselves?
    Veteran Member Three Rings AudiNike12's Avatar
    Oct 10 2017
    Sweden
    Bumping this. Did you ever solve this? I've the exact same problem
    Audi A6 Allroad 2.7T -04
    Audi A6 2.4 Sedan -04
    Audi A6 3.2 Sedan -05
    Audi TT 1.8T -99
    Veteran Member Four Rings PaperToast's Avatar
    Apr 29 2009
    Quadzilla
    Longmont, CO
    Quote Originally Posted by AudiNike12 View Post
    dude, i doubt this person is even on the forums anymore
    plenty of more exhaustive and newer threads that cover this in way more detail and dont require resurrecting from the dead
    Rockin' the Rockies
    '01 allroad, 250k woot woot, still boosting on original turbos and tippy, slightly modified. . .
    Scotty@Advanced, "Push it off a cliff, when it hits the ground you should have a few thousand horsepower available for a brief second."
    Oct 10 2017
    Sweden
    Well, problem solved. One pin in the power connector from the compressor was pushed in so it didn't make contact. That's why the compressor didn't run. Had to get a new connector with pins and new wires. Works like a charm now
    Audi TT 1.8T -99
