Results 1 to 17 of 17
    Established Member Two Rings stussy2870's Avatar
    Apr 04 2016
    Butler PA
    Simple Question about Oil Level on MMI
    Hey folks..Just a quick question-- when i first got my car (march/april *used*) my oil level in MMI was maxed out, as i'd expect it to be-- took it in for the 35k maintenance which supposedly included an oil change and my oil level in MMI says just about 50% "level OK".
    So the question is..
    Is it?
    Seems as if they didn't do the oil change both by filter inspection - seemed dirty on the exterior and by the level of MMI.
    Dealer is insisting that they did the change.
    Thoughts/Suggestions welcome.
    2015 Premium A4 Sline 6M/T, Dinan PiggyBack, K&N Typhoon Intake, Comfort Drop Spings, Niche Targa 20x10, RS4 Grill, Slotted/Dimpled Rotors and some G2'd Calipers
    Jan 03 2013
    Baltimore
    Looks like you are about .5q low according to the MMI. Do you have a dip stick? if not i would pick one up and check, sometimes the mmi is a bit off. Sounds a bit fishy if the filter is still dirty on the outside and you may be correct that they didnt change it which sucks. Maybe check the paperwork to see if they changed the filter, though this should always be done as part of an oil change...
    Apr 04 2016
    Butler PA
    No Dip Stick.. Ill throw a 1/2 qt in and get it back up.. I just dont know why (if they did change it) they wouldnt set it back to max level...
    Veteran Member Four Rings kwbdc's Avatar
    Mar 29 2012
    2006 Mazdaspeed6 RIP
    Seattle/WA/United States
    If they changed the filter and opened your hood, the MMI oil indicator will be unavailable for a bit until it registers again. If you were able to see the indicator immediately they never opened the hood and probably didn't change the filter.
    2012 Audi A4 Premium +MT, Quattro, Xpel bra, SLine BBS CI-R 20x8.5 ET 32
    Mods: APR HFC/DP, APR K04, Bilstein PSS10 Coilovers, Okada Coilpacks, AWE Boost Gauge, Eurocode SSK, OSIR CF Spoiler, APR Carbonio Intake, AWE Exhaust, OSIR CF valence, ÜSS Adjustable Stabilizer set, Alu Kreuz, RS4 grille, Fluidampr,Apikol differential, folding mirrors,Brembo GT BBK, Deval CF splitter,ECS skid plate, RS4 rear brakes, Snow performance Stage3
    Veteran Member Four Rings Party_Marty's Avatar
    Nov 02 2015
    Sector 9 Long-board, Rugby Kit
    In the woods
    Keep in mind dealershits aren't looking out for your car, they just want to make as much money as possible.
    ---------------------------------------------------------- IG: party_martyy ----------------------------------------------------------------------
    ---------------------2014 A4 - 6 Speed - Phantom Black Pearl -------------- Peep the Build ---------------------
    Jan 03 2013
    Baltimore
    Quote Originally Posted by kwbdc View Post
    This sort of makes sense, they could have drained from the plug which would not require one to open the hood and would validate the still dirty oil filter. But, how did they get the oil back in? Would need to open the hood for that. There is a method to pull up the oil level on the DIS, i believe you open the hood, close the driver door, turn car on (not start motor) and push the throttle open or something. it was recently posted and was claimed to be more accurate than the MMI.
    Buncha motorcycles
    Memphis, TN
    I just had my 15k service. I had changed oil myself at 10k And the MMI had fallen to about 3/4 down during that 5k miles.
    I scraped the side of the oil filter before bringing it in. MMI read full as soon as I picked up car so I opened hood and filter had been replaced. We'll see how it does now...
    Apr 04 2016
    Butler PA
    Thanks Guys. I cant really tell if they did it one way or another. Since the car was in for the 35k Audicare maintenance and they "claimed" they did all the work (which included plugs) i can safely assume they opened the hood. The MMI indicator was NOT available right away- which you'd expect but the lower oil level seemed odd.
    I guess since i have paperwork stating the work was completed-- ill just top it off and go about my day.
    Paul
    Veteran Member Four Rings Lambda13's Avatar
    Jul 07 2012
    A4, car parts, paint, random sockets, OEM parts.
    Boston, MA
    Quote Originally Posted by stussy2870 View Post
    Paul
    Have them top it off. You had them do a service and it seems they left out 1/2 a qt of oil.
    My 2009 A4 Prem+ Build thread
    Veteran Member Four Rings JeriQo's Avatar
    Jul 08 2015
    mine took a few hours and 60 miles later to register the oil level.
    it kept giving me the "itll take approximatlely 2 mins" notice
    2012 BB A4 P+ S-line Exterior |FBSW RS Paddles/Pedals|CR-15|AFE Filter|ECS inlet|S4 Dual Exhaust|Ace Convex 19x8.5|ECS 10mm rear|Solowerks S1
    Nov 02 2015
    In the woods
    on this same subject, where do you guys buy your oil? (that do it yourself)
    Jan 03 2013
    Baltimore
    Quote Originally Posted by Party_Marty View Post
    I buy the oil change kit from Europa Motorsports. Includes oil, filter and a few add ons if you want. i typically buy one of the gas tank treatments as well and drop it in around the same time. Shipping is pretty quick and sometimes they throw in some goodies (stickers, pens, etc.). They had a special once where if you bought a oil change kit, you got a pair of work gloves.
    Jul 07 2012
    Boston, MA
    Quote Originally Posted by elscotto80 View Post
    They sent me a license plate bracket, flashlight and some stickers!
    Nov 02 2015
    In the woods
    Awesome!!!! Thanks man!!!
    Jul 08 2015
    got mine from autozone, castrol edge syn 5-40 for 30 bucks (5 quartz)
    you can also go to walmart or oreilly
    Veteran Member Three Rings S4_SH1640's Avatar
    Mar 15 2012
    Fairfield County, CT
    Do you mean Europaparts.com? I cannot find the Europa motorsports website?
    Garage:
    B5 S4 Santorin Blue Stage 2
    B8 A4 Premium Plus
    D4 S8 4.0T
    Jan 03 2013
    Baltimore
    Quote Originally Posted by S4_SH1640 View Post
    Yup, sorry. Been a long weekend...
    https://www.europaparts.com/
