Results 1 to 4 of 4
    Veteran Member Four Rings sandspeed's Avatar
    Mar 13 2007
    05 S4 Avant Abt AS400 clone, 14 SQ5
    Sunny UK
    Need a set of worn rear rotors
    Does anyone have a worn set of rear brake rotors? They can be completely shot, and will only be used to build an adapter for a custom rear brake setup. Anyone looking to change theirs soon or have an old set they've been wanting to scrap?
    -Tim
    Account Terminated Four Rings
    Dec 03 2009
    PNW, Washington
    I might have a set in the garage. I can look later tonight when I get back.
    Veteran Member Four Rings FastEddie's Avatar
    Apr 01 2012
    Queens
    Quote Originally Posted by sandspeed View Post
    Do they have to be RS4 rotors? I have my OEM rotors for the rear and you can have them.
    Edit: i have a B7 S4
    SUSPENSION-KW V3-Hotchkiss RS4 sway bars-034 Adj UCA-034 strut mount-034 F&R end links-034 motor mounts-034 Snub mount W/bracket-034 Trans mount l BRAKES-ECS Stage 4 BBK-ECS rear rotors & lines, Hawk pads l Engine-JHM Tune-JHM 6 rib pulley-Milltek catless DP's-FI exhaust l EXTERIOR-RS4 black grille-Custom headlights-LED city & DRL lights-ECS LED tail lights & plate lights l INTERIOR-Custom steering wheel-SRP pedals-ECS LED lights-MOMO shift knob-Gen 2 RNSE & AMI l WHEELS-OEM RS4 W/ Michelin PSS
    Mar 13 2007
    Sunny UK
    Quote Originally Posted by Peter1.8t View Post
    That would be awesome.
    Quote Originally Posted by FastEddie View Post
    Yes, they have to be RS4 rotors.
    -Tim
