Bump...
Originally Posted by
amusante
I don't know how you guys did it. I couldn't get the boot onto the throttle body with the nut still on the t clamp, and once it was on, I couldn't get the bolt to meet the nut. I'm sure i was doing something wrong but a traditional clamp seems to be doing the job at the moment. If anything goes wrong, I'm buying a samco, which is much thinner and manageable
I was having the same issue as you...also ordered from ECS around the same time (July 2016). Not sure if it is an ECS thing or just how they all are...See pics below.
My 034 TBB came with a 3.25" diameter T-bolt clamp. The clamp is from Clampco, P/N 941000-325 with a 3.03" min and 3.34" max diameter. Herein lies the problem. The 034 TBB, at least the one that I received, is 3.41" resting diameter. So larger than the max of the clamp. If you put the nut on just the very first thread of the clamp you can get it to open up to 3.37" which allows you to squeeze the clamp over the TBB when it is just resting (not on car) however the TBB expands slightly when placed over the throttle body making the issue worse. There is no way this clamp size will fit when the TBB is placed on the throttle body.
My solution for now was using 3.5" t-bolt clamps which allowed it to fit over the TBB. The clamp I used has a range of 3.38" to 3.7" so there is not much compression of the TBB to hold it on there tightly so I hope it doesn't blow off. I didn't measure the actual clamp min diameter but if it actually is 3.38 that only gives it .03" compression (.015" radially) which is not nearly enough.
Are all 034 TBBs like this or did something change?
TBB diameter:
3.25" Clamp that came with TBB:
3.5" clamp that I used instead. It is bottomed out with only .03" compression:
