Results 1 to 6 of 6
    Senior Member Two Rings Gotpsi2008's Avatar
    Mar 24 2015
    YFZ 450, Beer Fridge
    Sebago, Maine
    Two bangs and no power?
    So driving home last night, coasting down a hill, I hear and feel a loud bang from the back end of the car, then after a few seconds it happens again, so I pull over, everything looks fine, I go to take off and when I let the clutch out I hear a god awed up noise from the rear end area of the car. Sounds like a shaft spinning in a coupler. I get underneath and have my buddy let out the clutch and I can see the drive shaft spinning into the rear end. I couldn't get a good look at the rear Cv shafts. So does this sound like a rear diff failure or a cv joint? Thanks for any input! Btw the car has all the mods in the sig and 111,000 miles.
    2008 A4 S-Line Grille 2.0T 6MT Quattro | JHM Stage 2 93 | Autotech HPFP Internals | JHM 3" TP | OBX 2.5" DP | JHM LWFW | RS4 Clutch Pressure Plate Combo | 034 Motor Mounts | 034 Snub | 034 Density Trans Mount | Red Top Coils | AFE Pro Dry S | CTS Silicon Turbo Hoses | ECS Intake Boot | P3Cars Boost Gauge | BSH PCV Revamp | EBC Reds | Ziza
    Veteran Member Three Rings allstock's Avatar
    Mar 19 2014
    greater sub of Chicago
    Most likely your CV.
    Dec 10 2011
    991 C2S, Stage 3 S4, E46 M3
    CLT | MKE
    Engine revs freely, but the car won't move?
    Axle.
    -Hayden
    B9 Q5 | Brilliant Black
    E46 M3 Cab | Steel Grey
    Mar 24 2015
    Sebago, Maine
    So after taking off the rear tires, both cv shafts spin awesome and have no play, however when you spin one, the other won't move. Looks like the rear end is going to have to come out and now I should probably start hunting for a rear end. Yeee hawww
    Oct 24 2015
    Perth, WA
    #craigslistm4m
    No in all seriousness, sorry to hear that. Good luck.
    My respray thread
    Mar 24 2015
    Sebago, Maine
    So just a little info on what happened, the spider gears in the diff let go and bound up. No idea how it happened, but put in a 200$ used one off eBay and works awesome now
