Results 1 to 19 of 19
    Veteran Member Four Rings namvar's Avatar
    Jul 10 2014
    2024 SQ8 Prestige, 2018 A4
    SF Bay Area
    Question RS5 Engine block leak
    Hi Everyone:
    I've been noticing a faint coolant odor in my engine block. While looking around I found evidence of a leak just below the oil cap. Any ideas as to what may be causing this?
    Thanks
    Namvar
    IMG_3890 by namvar_kiaie, on Flickr
    IMG_3891 by namvar_kiaie, on Flickr
    IMG_3892 by namvar_kiaie, on Flickr
    IMG_3893 by namvar_kiaie, on Flickr
    2015 RS5: Mythos Black, Tech Package , Dynamic steering, Black Optics, Folding side mirror upgrade, internal LED lights, Eventuri Intake, Akrapovič exhaust, KW DDC ECU, lots of CF
    2013 3.0T Prestige Q7: Sport pedals, LED interior lights
    Veteran Member Four Rings chrissurfr's Avatar
    Apr 26 2005
    Houston
    Maybe (hopefully) a spill from them pouring the oil in there?
    2017 Cement Grey TRD Pro 4runner
    2014 Suzuka Grey RS5 >:)
    • AWE Track Exhaust with center muffler straight piped
    • H&R Street Coilovers
    • BBS CH R - Gold with red caps
    • eCode headlights
    • Eventuri intake
    • JHM Stage 2 ECU/TCU
    • other things I forgot about
    Veteran Member Four Rings HazeMyth's Avatar
    Jul 17 2015
    Colorado
    It looks like an awfully low amount to be an active leak. I'd guess it's from spilling while adding oil with how little is there.
    It'd be real hard for me to smell a coolant odor coming from my car, because my neighbor's piece of shit always reeks of coolant.
    2013 Audi S5 - EPL Stg 2 ECU/TCU
    2011 Toyota Tacoma TRD Sport - Lifted, reinforced, and slow
    2003 Evolution VIII - HKS280, FBO
    2004 Subaru STI - Stg. 2 (Sold)
    IG: @MrHazeMyth
    Jul 10 2014
    SF Bay Area
    It's definitely coming out of that joint. My last oil change was 3k miles ago and I wipe my engine down at least twice a month. So I'm fairly certain it was not because of spillage.
    Veteran Member Four Rings ak_siberian's Avatar
    Jan 30 2015
    992C4S, T2 Touareg V8, Porsche Macan S, & Gehl turbo bobcat;
    20 miles NW Fairbanks, Alaska
    An oil leak does not smell like coolant... what was recently done to the car Namvar?
    siberian
    The best long distance runners eat raw meat, run naked and sleep in the snow
    Veteran Member Four Rings JamesRS5's Avatar
    Feb 27 2014
    Dubai
    Have you identified what that leak is, obviously if its oil it won't smell of coolant.
    I know it's not good practice but I put my finger in it and have a little taste, if it's sweet tasting it's coolant, if it tastes like oil, guess what...
    Has your coolant level dropped?
    Jan 30 2015
    I wonder where else he puts his finger in... :) Sorry couldn't resist
    siberian
    Jul 10 2014
    SF Bay Area
    Quote Originally Posted by ak_siberian View Post
    siberian
    It has a green tint to it
    Jan 30 2015
    Namvar, I doubt it's oil, though coolant color can vary (green or reddish) and it's no longer sweet (too many animals have been killed drinking up the old "sweet" stuff).
    So back to my question, was there anything done to the car in your last service? Could be head gasket leak, valve cover warping, engine block crack, coolant hose nearby leaking... When you dry the stuff up, does it start leaking right away or do you need to warm up the engine and run it for a while? I doubt any codes would be thrown by this.
    siberian
    Jul 10 2014
    SF Bay Area
    So back to my question, was there anything done to the car in your last service? Could be head gasket leak, valve cover warping, engine block crack, coolant hose nearby leaking... When you dry the stuff up, does it start leaking right away or do you need to warm up the engine and run it for a while? I doubt any codes wold be thrown by this.
    siberian
    It definitely seeps through that joint and I think when the engine is hot. I dumped the codes and you are right... nothing
    Jan 30 2015
    Again, Namvar, what was done to the car as you just took it in recently... Since it looks like it manifests itself when engine is warm/hot, it's likely expansion on a seal rather than a crack which would show right away when the water pump starts.
    siberian
    Feb 27 2014
    Dubai
    It may be worth checking the torque on the bolts on that side of the engine, do the re-torquing with the engine cold.
    Jan 30 2015
    Remember that if you use a digital torque wrench, that the reading you get may not be the value it was torqued at but once it seated itself etc. (especially since fluids have now deposited themselves on the bolts).
    Also if you're checking on the valve cover bolts, read the manual and determine the torque ORDER of the bolts. Covers can deform really easily if you don't use the order they are intended to be tightened in. Keep us posted
    siberian
    Feb 27 2014
    Dubai
    Personally I would back them off and re torque in the correct order, the order they were torqued may be the reason it's leaking?
    Jul 10 2014
    SF Bay Area
    siberian
    Just an Oil change at 20K Miles.
    Jan 30 2015
    Quote Originally Posted by JamesRS5 View Post
    Exactly James.
    siberian
    Jan 30 2015
    Quote Originally Posted by namvar View Post
    It's under warranty, take it back; don't mess with it. If it wasn't under warranty then James' suggestion and mine is the way to proceed
    Keep us posted and have a great weekend Namvar
    siberian
    Jul 10 2014
    SF Bay Area
    That's the plan Siberian... The master tech is looking at the pictures now.
    Jan 30 2015
    Keep us posted
    siberian
