I am running JHM tune with RAI HFC/DP on a stock HPFP. I am having some serious fuel cuts, to the point the car is not driveable.
I used to run an upgraded HPUPGRADE HPFP with APR Stage 2+ tune, switched to JHM tune but retained the upgraded pump....until a hole was punched in my cam follower which in turn damaged the piston on the pump. That is when the stock pump went back in (with a new cam follower of course).
Since that time, I noticed a "blip" here and there while driving which I later equated to a minor fuel cut. I did notice some scoring on my cam shaft from when the follower failed and was replaced, so that may be my problem afterall (a damaged cam shaft), however my mechanic seems to think it shouldn't cause fuel cuts and instead perhaps eat through followers a little quicker. I have been keeping on a eye on my follower ever since and it is fine for now.
The fuel cuts (blips) became more frequent until one day all of a sudden the car was bogging, jerking, and RPM's dancing, and even stalling once. Fuel cuts were very pronounced and noticeable at that point. I thought maybe my follower failed again so I checked it out and it was fine. After putting the fuel pump back on, the car seemed to be back to normal for another couple of weeks and then it happened again, even more pronounced this time.
Out came my trusty VAG-COM and I have these codes:
5 Faults Found:
000320 - Oxygen (Lambda) Sensor B1 S2
P0140 - 004 - No Activity - MIL ON
Freeze Frame:
Fault Status: 11100100
Fault Priority: 2
Fault Frequency: 21
Reset counter: 255
Mileage: 167521 km
Time Indication: 0
Freeze Frame:
RPM: 812 /min
Load: 17.6 %
Speed: 0.0 km/h
Temperature: 93.0°C
Temperature: 41.0°C
Absolute Pres.: 1000.0 mbar
Voltage: 13.462 V
008342 - Post-Catalyst Oxygen (Lambda) Sensor Correction; Bank 1
P2096 - 002 - Too Lean - Intermittent
Freeze Frame:
Fault Status: 00100010
Fault Priority: 2
Fault Frequency: 2
Reset counter: 255
Mileage: 167561 km
Time Indication: 0
Freeze Frame:
RPM: 3028 /min
Load: 12.9 %
Speed: 44.0 km/h
Temperature: 92.0°C
Temperature: 33.0°C
Voltage: 13.462 V
000135 - Fuel Rail/System Pressure
P0087 - 002 - Too Low - Intermittent - MIL ON
Freeze Frame:
Fault Status: 10100010
Fault Priority: 2
Fault Frequency: 12
Reset counter: 255
Mileage: 167590 km
Time Indication: 0
Freeze Frame:
RPM: 3646 /min
Load: 57.6 %
Speed: 136.0 km/h
Temperature: 92.0°C
Temperature: 27.0°C
Absolute Pres.: 990.0 mbar
Voltage: 13.843 V
004243 - Bank 1; Fuel Measuring System 2
P1093 - 008 - Malfunction - Intermittent
Freeze Frame:
Fault Status: 00101000
Fault Priority: 2
Fault Frequency: 1
Reset counter: 255
Mileage: 168457 km
Time Indication: 0
Freeze Frame:
RPM: 2621 /min
Load: 12.9 %
Speed: 57.0 km/h
Temperature: 92.0°C
Temperature: 30.0°C
Voltage: 13.843 V
004372 - Oxygen (Lambda) Sensor; B1 S2
P1114 - 008 - Internal Resistance too High
Freeze Frame:
Fault Status: 01101000
Fault Priority: 2
Fault Frequency: 1
Reset counter: 255
Mileage: 168468 km
Time Indication: 0
Freeze Frame:
RPM: 2384 /min
Load: 7.1 %
Speed: 69.0 km/h
Temperature: 92.0°C
Temperature: 30.0°C
Voltage: 13.843 V
My guess with the O2 sensor codes is when fuel cuts were taking place, the sensor was registering a lean situation. Then you can see the two codes referring to Fuel Rail/System Pressure and Fuel Measuring System 2 failing or intermittent. I cleared the codes, drove around a bit, and only got the 004243 - Bank 1; Fuel Measuring System 2 code again.
In perusing the VAG-COM website, I came across this for the Fuel Measuring code:
17501/P1093/004243 - Bank 1; Fuel Measuring System 2: Malfunction
Possible Symptoms
- Power Loss
- Misfire(s)
- Stalling
Possible Causes
- Fuel Pressure insufficient/exceed/fluctuating
- Fuel Pump (High Pressure System) faulty
- Fuel Pressure Regulator Valve (N276) faulty
Possible Solutions
- Check Fuel Pressure (on FSI engines High and Low Fuel Pressure System)
- Check Fuel Pump (High Pressure System)
- Check Fuel Pressure Regulator Valve (N276)
- Check Fuel Filter and Filter in Fuel Pump Casing
- Special Notes
When found in 2.0l TFSI:
- Check TSB/TPI 2008753 (Rest of World), incompatibility between Fuel Pressure Regulator Valve (N276) and ECU software.
When found in conjunction with Misfires and Lean fault codes, check RVUTB: 01-09-03 or 2018919 (NAR only) 2.0T (BPY), for updated Crankcase Breather Valve
If the breather valve is faulty, full engine vacuum is typically found when removing the oil cap at idle.
Ran a test on the N276 and it appears to be working (hear clicking during the test). Same thing with the HPFP...clicking during test. Fuel pump/filter would be the next thing to check on that list but I was wondering if anyone has any other insight on this.
