Results 1 to 26 of 26
    Senior Member Two Rings Shaun Perry's Avatar
    Jan 02 2013
    San Ramon, CA
    Recommendations for brake pads?
    2012 S4 coming on 27k miles.
    Brake light is on in the middle and the red "BRAKE" letters to the right(that are there when the parking brake is engaged).
    (Random observation) I feel like the car is dragging. Like for example in a car with a manual foot or hand parking brake. As if the brake is slightly engaged, like 20% or something, just feels like something is halting the car from driving freely. Don't know if there's any valid truth behind this observation but I can sort of "feel" something like this.
    Anyway, everything is completely stock. My question to everyone is do I just go and have what needs to be replaced with OEM components? Is there a crowd favorite of upgraded pads that people like? Do I go all in and go for a BBK upgrade? Do I not?
    If it helps, the car may or may not be going EPL stage 2 tune and TCU tune, but that won't be happening anytime soon. If I upgrade, I would like it to suffice the performance expectation but I don't track the car or need anything too excessive.
    Would love to hear input, or to get ahead of the game, go ahead and paste links for threads where this may have been discussed already, and sorry in advance if this post is too newb for some of the people out there who might just roast me for posting this?
    Thank you
    Apr 05 2016
    Portland, OR
    Unless you plan on tracking the car you probably don't need a BBK.
    See this thread: http://www.audizine.com/forum/showth...ecommendations
    As we were just talking about this :)
    Jan 02 2013
    San Ramon, CA
    Quote Originally Posted by whiped View Post
    Thank you for that.
    And maybe you can answer, the two lights I have on in the dash. Are they specific to front brakes or rear brakes? Or is it just a warning regardless of which sensor is going off? I'll have my mechanic check either way but was just thinking of ordering the parts and then going for install, save me a trip.
    Dec 03 2008
    2018 SQ5
    Castle Rock, Colorado
    Quote Originally Posted by Shaun Perry View Post
    Thank you for that.
    The light on the dash are triggered by a single sensor on one of the front pads. So there's a possibility you're rears are fine. I'm guessing it's normal to have both the yellow pad warning in the center, and the red BRAKE warning light as well because I have both active for worn brakes as well.
    Akebono pads are pretty much the favorite around here. Almost zero dust compared to OEM, and no squeal. Pretty much everybody and their mom will tell you to replace rotors as well. I just picked up all 4 Meyle rotors and Akebono pads all around for $404 shipped from fcpeuro.com. You won't beat that deal on any brake setup for this car anywhere. If you want slotted/drilled, you are looking closer to $800-1000 on the cheap side for parts alone.
    2021 Audi S4, P34 Intake
    Nov 23 2014
    North Carolina
    akebono for low dust and no noise, I also hated the OEM hard bite at the initial engagement that made it a pain to make small braking adjustments at low speed. I just resurfaced my oem rotors and used the akebonos. replacements go with ECS geomet or zimmerman. slotted I'd go with ECS again or powerslot. for more stock like pads try stoptech pads.
    2021 Glacier White S5 Prestige Coupe - ECS Swaybars, 034 dynamic+ links, ECS tower brace, wheel spacers 12.5f 15r, CTS catted Downpipe, Wagner Intercooler, Andy_FL CF inlet pipe, EPL stage 2 E40 or 034 stage 2 E85 depending on mood
    2019 X3 M40i - Sold
    2015 Sepang S4 Prestige 6MT - sold
    Senior Member Three Rings AudiSTL's Avatar
    Sep 21 2013
    2011 S4
    st. louis
    had mine akebono for less than 1000 miles but love them low dust
    AWE Quad Exhaust / Rotifom Ind 19x10 (old) / V12 245/35 tires / Solo Werks / ECS Carbon Luft Intake / Stoptech / Verde V99 19x9.5
    Enlaes CF decklid / EPL 1+ w DSG
    https://www.instagram.com/admirstl3/
    Veteran Member Three Rings hotleadsingergu's Avatar
    Jun 18 2015
    Cleveland
    Not to denigrate, but this is really something that could have been solved with a search. There are countless threads about brakes every week, and every one pretty much comes to the same conclusion:
    Buy Akebono and don't look back.
    Mar 21 2015
    ^ All of what he said.
    I have Akeebono and love the no dust. The wear sensor should be on the driver side front.
    Oct 14 2012
    Empty...for now...
    SE PA
    I'll also endorse the Akebono option. I have them in my rear brakes and can attest to the low dust level, silent operation, and minimized initial bite.
    SOLD 2015 Daytona Gray S4
    Jan 02 2013
    San Ramon, CA
    Thank you everyone! Akebono will take the vote. Just deciding now on the rotors. I like the drilled and slotted from ECS. They're the same price as the slotted.
    Although that Meyle rotor akebono pads for $404 shipped front AND rear seems pretty amazing.
    Dec 03 2008
    2018 SQ5
    Yeah, with my current budget, I couldn't justify more expensive brakes just for looks. Every penny I save is another penny i can spend on tuning one of these days...
    Veteran Member Four Rings doughboy17's Avatar
    Aug 05 2010
    2007 Audi A4 3.2 Quattro; 2021 Mazda CX-5 Turbo Carbon Edition (my wife's vehicle)
    Central IL
    Quote Originally Posted by SteveYem View Post
    Just to clarify, are the Akeebono s to which you are referring ceramic?
    2014 Monsoon Gray S4 Prem+ | S-Tronic w/ EPL tune | LH Magma Nappa leather interior | Carbon Atlas inlays | Sports Diff | Adaptive Damping suspension | 19” peelers | MMI Nav | B&O | EPL Stage 2 via JHM 179mm crank pulley | Resonated AWE Touring w/ 102mm tips | ECS silicone intake tube with aFe filter | RKX tranny mount insert | tints | VAG COM mods via OBDeleven | Autostyle Mats
    Veteran Member Four Rings sacandagaD's Avatar
    Jul 02 2013
    2015 S4 P+, 2008 Honda Element,2018 Porsche Macan GTS
    Saratoga Springs, NY
    Quote Originally Posted by doughboy17 View Post
    They are.
    2015 P+, Sepang Blue, Black/Black Alcantara / DSG / Sport Diff / Tech package / OEM Euro Auto-folding mirrors / EPL stage 1 ECU/TCU / BMC Air filter and AWE Intake tube / Carbon inlays / Hard wired V1 / CR-15 / 3M PPF / 19" AdvanApexV601/Hartmann Rotor reps / Akebonos / LED interior and reverse lights / ZxE fogs / Multiple Vag-com mods
    Loved but traded: 2011 S4 P+, Deep Sea Blue Metallic, Black/Silver Alcantara
    Veteran Member Four Rings cspcrx's Avatar
    Jan 04 2013
    2009 Tacoma, 2007 Harley Softail, 1986 Honda CRX
    Phoenix, az
    I have been running the Akebono pads now for two full weeks and the rears, which are still stock, are now making more brake dust then the fronts. I heard others mention how much better these pads were on dust but wow. Also the stupid brake squeal is gone that was so annoying is gone. When it is time for rears I am going to do the same setup as the front. Really happy with it so far.
    2012 Ibis P+ / DSG / Silk Napa / B&O / Sport Diff. / ADS lite / MMI & Nav / APR Stage 2+ & TCU Tuned / Ultra Charger / 184mm KI LIL BITCH / ECS Kohlefaser Luft-Technik Intake / AMS Alpha Cooler / ECS 2-Piece Rotors / Akebono Pads / VMR 803 19x9.5 ET45 265-35-19 PSS / ECS Drivetrain Bushing Inserts / CR-15
    11.8 @ 116mph 2487DA on 93oct file Stage 2+
    THEN THEN THEN Rinse & Repeat!
    Jan 02 2013
    San Ramon, CA
    Question. After self installing new brake pads and rotors and installing the new wear sensor.
    Will vag-com be needed to reset the system? Will the "brake" in red letters and the yellow brake icon light still show up.
    Or will the system reset itself once it sees a new wear sensor in place?
    Apr 25 2016
    Anchorage
    My brake error went away with new sensor installed on first fire up
    Jan 02 2013
    San Ramon, CA
    Quote Originally Posted by mike907 View Post
    Thank you for clarifying
    Jun 12 2015
    2017 Q7 / 1969 GTO
    Austin, TX
    I put EBC Redstuff with EBC USR slotted and I'm very happy. Mostly, ZERO squeal and minimal dust.
    Jan 02 2013
    San Ramon, CA
    Quote Originally Posted by EstorilS4 View Post
    I'm going with akebono pads and the ecs drilled slotted rotors all from ECS.
    Jul 02 2013
    I have the ECS slotted with Akebonos and they are dead silent and no dust.
    Feb 18 2008
    LI, NY
    i have a brembo bbk upfront and just recently did rear brakes with akebono pads. love the low dust and no issues
    Veteran Member Three Rings PSUGOLD's Avatar
    Mar 10 2014
    Philly Area, PA
    I am getting mine done tomorrow. I went with Hawk HPS pads with the ECS kit here: https://www.ecstuning.com/ES2597368/
    2016 Daytona Grey Pearl Effect crystal effect , Sports Diff, Adaptive Suspension, Carbon Atlas inlays, Borla Cat Back, DS1 Stage 1 w/ Boosted Euro TCU.
    Veteran Member Four Rings A.C.'s Avatar
    Sep 15 2013
    2015 VW GSW TDI, 2004 GLI, 2015 Kia Sorento
    MD
    I've used Hawk pads and PowerSlot rotors on both of my Jettas Mk3 VR6 and MK4 GLI and they worked great. Although a different kind of beast I would think they would work in similar fashion. Now that my new baby needs shoes I may have to revisit this option.
    Jun 12 2015
    2017 Q7 / 1969 GTO
    Austin, TX
    Great choice. You'll be very happy.
    Veteran Member Three Rings JWreck's Avatar
    Jul 28 2014
    Cedar Park, TX
    I have Akebono pads.
    I wish I had stuck with OEM. I miss the bite, and feel like the Akebonos have less stopping power during aggressive driving.
    2019 RS5 Sportback | Nardo | Nappa | Dynamic | RS Driver Assist | Black Optics | Dynamic Steering | B&O
    2017 AMG C63S | Gone
    2014 S4 P+ | Gone
    Nov 18 2014
    Quote Originally Posted by JWreck View Post
    I feel the same way about HPS 5.0.
