Results 1 to 7 of 7
    Nov 28 2015
    Montreal, QC
    Stretch bolt for X-brace, Re-use or can I hit the dealer ?
    Well I bought a X-brace second hand and well I forgot about the stretch bolt. Sure these 6 bolts are only 20usd$, but once you factor shipping to cnd + currency and taxes, well it's 50-60$ for 6 little bolts lol... So, does the dealer carry these in stock most of the time ? orrrr i bet a few of us re-used the oem simply ?
    S4 B8.5 no track, just enjoying spirited driving.
    Veteran Member Four Rings Usa's Avatar
    Dec 23 2013
    B8 S4
    Yeah, that bolt is pretty standard and all service shops will have them on hand.
    S4 (B8) DSG / Quartz Gray Metallic / VAG-COM / 3M Crystalline 70% sides 30% rear / Roc-Euro Intake / APR Stage II / Non-res Milltek / Alu Kreuz Stabilizer / Eurocode Front & Rear Sways & Endlinks / 19x9.5 AG M590 / PSS / RS4 Grill / P3 Gauge / Bilstein PSS10 / AMS Boost Cooler System / ENLAES Rear Spoiler & Diffuser / OSIR Front Splitter
    Veteran Member Four Rings rtl5009's Avatar
    Jul 28 2009
    Philadelphia PA
    Re use them.
    b5 s4 built bottom stg3 on E - Sold- Never felt happier
    c8 a6 allroad
    Veteran Member Three Rings EHesh14's Avatar
    Jul 16 2010
    Colorado
    I just replace them every other tranny fluid change (60k)
    Veteran Member Four Rings superswiss's Avatar
    Jan 07 2013
    San Francisco Bay Area, CA
    Yeah, shops have them on hand as they need to replace them every time they remove something. Most chassis bolts are stretch bolts as far as I know. Reusing stretch bolts will cause them to stretch further, which increases the risk of breakage and they will also not hold the same torque as before. Probably ok if all you do is commute to work and get your groceries, but then you also don't need the x-brace. So, assuming you plan on driving the car harder than the average commuter, I would use fresh bolts.
    2019 AMG C63CS, obsidian blk, blk leather w/ yellow stitching, aero pkg, CF pkg I+II, 19/20 wheels, lighting pkg, multimedia pkg, heat&vent seats, AMG perf seats, digital cluster, night pkg, parking assist, driver assist, european delivery
    2013 panther blk RS5, Ti pkg, blk leather/alcantara, nav pkg, sport exhaust, driver assist pkg, rear shade, alu kreuz, ECS spacers 15f/10r, ECS tru-float rotors, ECS brake lines, Hawk HPS pads, european delivery (sold)
    Veteran Member Three Rings Killerboots's Avatar
    Nov 19 2014
    Phoenixville, PA
    Absolutely use NEW stretch bolts. Do not reuse the ones taken out. Dealerships should have them readily available.
    Nov 28 2015
    Montreal, QC
    i will hit the dealership today,. cheers folks ! :)
