Hello fellow Audi-os!
I'm looking for some help related to a battery drain problem. About two weeks ago, over a period of five days, my car started to crank slower and slower and ultimately exhibited the classic-dead-battery sound. Yes, yes I know that it's really stupid to let a battery drain all the way. Lesson learned ...
BATTERY BACKGROUND: The dead battery was only 25 months old and, when tested, the equipment indicated that the battery was good but needed to be charged. The little green eye on the battery also indicated the same thing. However, I opted to replace it with an OEM battery from Audi. This is when the fun started.
OTHER BACKGROUND: About a year ago, my phone disconnected from the Audi Bluetooth system and I was never able to pair the phone again. I chalked it up to the latest iOS update. If you're reviewing the logs, check out the phone section at the very end. Shows that the system is entirely offline. Might be nothing, could be something. I'm trying to learn quickly about what means what.
Here's a play-by-play of the last week:
- DAY 1 - Battery was plumb dead. Clickity clickity clickity said the solenoid.
- DAY 1 - Replaced battery with a new, OEM Audi battery (Varta brand).
- DAY 3 - Using VCDS, I coded BEM using the code from the battery.
- DAY 3 - Started the car and it ran TERRIBLY! The engine light was blinking and the battery and ESP light came up.
- DAY 4 - Ran VCDS diagnostic. All sorts of errors included cylinder 1 and 3 misfire, CAN error, battery management error and telephone error (kept a copy of the log).
- DAY 5 - Went through the process of clearing DTCs and ran the diagnostic again without starting the car. Far less errors this time. The 01 Engine codes were clear but I hadn't ran the car yet so that doesn't say much (kept a copy of that log and the log attached below).
- DAY 7 - Decided to run the car for a few minutes. The first 3-5 seconds ran smooth. From about 5-15 seconds it ran rough--lots of RPM searching from 700 to 1000 RPMs. After the 15 second mark, the car started to misfire just like it did before. SIDE NOTE: I noticed that the car cranked slowly!! Wait, what!? Does running VCDS a lot without running engine kill the battery?
- DAY 7 - Pulled logs after running vehicle. Cylinder 1 and 3 misfire returned (kept a copy of that log, too).
- DAY 8 - I'm certain that the new battery is losing juice. Lights are somewhat dim and battery light is on now.
Here's the latest log. Note that this was the log prior to me firing up the car this morning. The only difference between this log and the one after running the car, were misfires on cylinders 1 and 3.
Code:
Wednesday,15,June,2016,19:55:19:04550 VCDS -- Windows Based VAG/VAS Emulator Running on Windows 7 x86 VCDS Version: 15.7.0.2 Data version: 20150820 www.Ross-Tech.com VIN: WAUDL74FX6N102706 License Plate: -------------------------------------------------------------------------------- -------------------------------------------------------------------------------- Chassis Type: 4F (4F0) Scan: 01 02 03 05 07 08 09 0E 0F 15 16 17 19 36 37 42 46 47 4F 52 53 55 56 61 62 65 67 72 76 77 VIN: WAUDL74FX6N102706 Mileage: 172990km-107491miles 00-Steering Angle Sensor -- Status: OK 0000 01-Engine -- Status: Malfunction 0010 02-Auto Trans -- Status: OK 0000 03-ABS Brakes -- Status: OK 0000 05-Acc/Start Auth. -- Status: OK 0000 07-Control Head -- Status: Malfunction 0010 08-Auto HVAC -- Status: OK 0000 09-Cent. Elect. -- Status: OK 0000 0E-Media Player 1 -- Status: OK 0000 0F-Digital Radio -- Status: OK 0000 15-Airbags -- Status: OK 0000 16-Steering wheel -- Status: OK 0000 17-Instruments -- Status: OK 0000 19-CAN Gateway -- Status: Malfunction 0010 25-Immobilizer -- Status: OK 0000 36-Seat Mem. Drvr -- Status: OK 0000 37-Navigation -- Status: OK 0000 42-Door Elect, Driver -- Status: OK 0000 46-Central Conv. -- Status: OK 0000 47-Sound System -- Status: OK 0000 4F-Centr. Electr. II -- Status: OK 0000 52-Door Elect, Pass. -- Status: OK 0000 53-Parking Brake -- Status: OK 0000 55-Headlight Range -- Status: OK 0000 56-Radio -- Status: OK 0000 61-Battery Regul. -- Status: Malfunction 0010 62-Door, Rear Left -- Status: OK 0000 65-Tire Pressure -- Status: OK 0000 67-Voice Control -- Status: OK 0000 72-Door, Rear Right -- Status: OK 0000 76-Park Assist -- Status: OK 0000 77-Telephone -- Status: Cannot be reached 1100 ------------------------------------------------------------------------------- Address 01: Engine Labels: Redir Fail! Part No SW: 4F0 910 560 E HW: 4F0 907 559 Component: 4.2L V8/5V G 0020 Revision: --H01--- Serial number: Coding: 0007772 Shop #: WSC 02335 785 00200 VCID: 24A2399F27D4AF328156D9-8070 ------------------------------------------------------------------------------- Address 02: Auto Trans Labels: 09L-927-760.lbl Part No SW: 4F1 910 156 Q HW: 09L 927 156 A Component: AG6 09L 4,2 MPI USA 0040 Revision: --H01--- Serial number: 4101327 Coding: 0000002 Shop #: WSC 02335 785 00200 VCID: 328ECFC76D20318203CA7F-8066 No fault code found. ------------------------------------------------------------------------------- Address 03: ABS Brakes Labels: 4F0-910-517.lbl Part No SW: 4F0 910 517 L HW: 4F0 614 517 L Component: ESP 8.0 quattro H04 0090 Revision: 00000000 Serial number: 00000000000000 Coding: 0021352 Shop #: WSC 02335 785 00200 VCID: 2DB4DCBB741E6E7A5EF8A4-8078 No fault code found. ------------------------------------------------------------------------------- Address 05: Acc/Start Auth. Labels: 4F0-910-852.clb Part No SW: 4F0 910 852 HW: 4F0 905 852 B Component: FBSAUDIC6 ELV H31 0180 Revision: 30070501 Serial number: 10600700278090 Coding: 0000015 Shop #: WSC 02335 785 00200 VCID: 63207A83625AE80AB8DC12-8036 Subsystem 1 - Part No: 4F0 910 131 L Component: FBSAUDIC6 EZS H45 0070 Subsystem 2 - Part No: 4F0 910 335 Component: FBSAUDIC6 KSG H27 0080 Subsystem 3 - Part No: 4F0 910 220 G Component: FBSAUDIC6 IDG H45 0060 No fault code found. ------------------------------------------------------------------------------- Address 07: Control Head Labels: 4F0-910-7xx-07-H.lbl Part No SW: 4F0 910 732 Q HW: 4E0 035 729 Component: Interfacebox H43 4610 Revision: 00000000 Serial number: 303JL057510456 Coding: 0000003 Shop #: WSC 02335 785 00200 VCID: 318CC0CB68260A9A7AD048-8064 Subsystem 1 - Part No: 4F0 910 609 E Component: Bedienteil MMIC6H08 0050 Subsystem 2 - Serial number: 00000000262998 Subsystem 3 - Serial number: 0125.10.050000000100010778ÿ Subsystem 4 - Serial number: 010778ÿ 1 Fault Found: 00003 - Control Module 005 - No or Incorrect Basic Setting / Adaptation Freeze Frame: Fault Status: 01100101 Fault Priority: 5 Fault Frequency: 1 Reset counter: 112 Mileage: 172991 km Time Indication: 0 Date: 2005.02.12 Time: 15:45:07 ------------------------------------------------------------------------------- Address 08: Auto HVAC Labels: 4F0-910-043.lbl Part No SW: 4F0 910 043 HW: 4F1 820 043 S Component: KLIMABETAETIGUNGH12 0160 Revision: 00000027 Serial number: 00000030067646 Coding: 0000040 Shop #: WSC 02335 785 00200 VCID: 5B5042635A2AD0CAF0ACBA-800E No fault code found. ------------------------------------------------------------------------------- Address 09: Cent. Elect. Labels: 4F0-910-279.lbl Part No SW: 4F0 910 279 C HW: 4F0 907 279 A Component: ILM Fahrer H15 0190 Revision: 00000000 Serial number: 4F0907279 Coding: 0114123 Shop #: WSC 02335 785 00200 VCID: 29BC28AB40F6725AB2A090-807C Subsystem 1 - Part No: 4F1 910 113 Labels: 1KX-955-119.CLB Component: Wischer AudiC6 H05 0150 Coding: 00062736 Shop #: WSC 02335 Subsystem 2 - Part No: 4E0 910 557 Labels: 8K0-955-559.CLB Component: REGENLICHTSENSORH10 0050 Coding: 00141886 Shop #: WSC 02335 No fault code found. ------------------------------------------------------------------------------- Address 0E: Media Player 1 Labels: 4E0-910-111.lbl Part No SW: 4E0 910 111 F HW: 4E0 035 111 A Component: CD-Changer H44 0470 Revision: 00000000 Serial number: AUZ5ZBE7251469 Shop #: WSC 00000 000 00000 VCID: 1CD2017F1FA497F2392661-8048 No fault code found. ------------------------------------------------------------------------------- Address 0F: Digital Radio Labels: 4E0-910-593-XM.lbl Part No SW: 4E0 910 593 G HW: 4E0 035 593 C Component: SDAR XM H04 0670 Revision: 00000000 Serial number: AUZ4Z7E4038058 Shop #: WSC 00000 000 00000 VCID: 2BB0D2A34A0A604A408C8A-807E No fault code found. ------------------------------------------------------------------------------- Address 15: Airbags Labels: 4F0-910-655-8R.lbl Part No SW: 4F0 910 655 F HW: 4F0 959 655 A Component: 66 AIRBAG AUDI8RH29 0300 Revision: 12H29000 Serial number: 00359D0A6PPA Coding: 0013878 Shop #: WSC 40233 444 59028 VCID: 2ABED7A745F07942BB9A87-807E Subsystem 1 - Part No: 4F0 910 339 A Component: BF-Gewichtsens. H02 0050 Subsystem 2 - Serial number: 6332CSME0C6B5A60B Subsystem 3 - Serial number: 6342CSME0C6A387DL Subsystem 4 - Serial number: 6352QSME0612250D6 Subsystem 5 - Serial number: 6362QSME061337176 Subsystem 6 - Serial number: 63734SME06167749+ Subsystem 7 - Serial number: 63834SME0550781F0 No fault code found. ------------------------------------------------------------------------------- Address 16: Steering wheel Labels: 4F0-910-549.lbl Part No SW: 4F0 910 549 A HW: 4F0 953 549 C Component: J0527 0310 Revision: 00H01000 Serial number: 90026052690186 Coding: 0012241 Shop #: WSC 02335 785 00200 VCID: 27B82E9356E2442AA4B4E6-8072 Subsystem 1 - Part No: XXXXXXXXXXX Component: E0221 H07 0090 No fault code found. ------------------------------------------------------------------------------- Address 17: Instruments Labels: 4F0-910-xxx-17.lbl Part No SW: 4F0 910 930 A HW: 4F0 920 980 N Component: KOMBIINSTR. M73 H16 0630 Revision: 00200000 Serial number: 4PY3A1LA5 Coding: 2129201 Shop #: WSC 00581 210 64475 VCID: 21AC308B38C6BA1AEA7038-8074 ------------------------------------------------------------------------------- Address 19: CAN Gateway Labels: 4F0-910-468.lbl Part No SW: 4F0 910 468 A HW: 4F0 907 468 D Component: Gateway H11 0070 Revision: 11 Serial number: 1300805A2881C1 Coding: ECFE73CD1B7904 Shop #: WSC 02334 785 00200 VCID: 27B82E9356E2442AA4B4E6-8072 1 Fault Found: 01303 - Telephone Transceiver (R36) 004 - No Signal/Communication Freeze Frame: Fault Status: 01100100 Fault Priority: 3 Fault Frequency: 1 Reset counter: 112 Mileage: 172991 km Time Indication: 0 Date: 2005.02.12 Time: 15:46:08 ------------------------------------------------------------------------------- Address 36: Seat Mem. Drvr Labels: None Part No SW: 4F0 910 760 HW: 4F0 959 760 Component: Sitzmemory FS H04 0050 Revision: 00000000 Serial number: 00000000896400 Coding: 0082954 Shop #: WSC 02334 785 00200 VCID: 612C708B7846FA1AAAF078-8034 No fault code found. ------------------------------------------------------------------------------- Address 37: Navigation Labels: 4E0-910-88x-37.lbl Part No SW: 4E0 910 888 M HW: 4E0 919 887 C Component: MNS US H45 1100 Revision: 00000000 Serial number: 355JU057556205 Shop #: WSC 02335 785 00200 VCID: 389AFDEF8B5CDBD23D0E3D-806C No fault code found. ------------------------------------------------------------------------------- Address 42: Door Elect, Driver Labels: 4F0-910-793-42.lbl Part No SW: 4F0 910 793 E HW: 4F0 959 793 E Component: TSG FA H12 0080 Revision: 00000000 Serial number: ` Coding: 0051947 Shop #: WSC 02335 785 00200 VCID: 2CB2D1BF4F0467724986B1-8078 No fault code found. ------------------------------------------------------------------------------- Address 46: Central Conv. Labels: 4F0-910-289.lbl Part No SW: 4F0 910 289 G HW: 4F0 907 289 G Component: Komfortgeraet H22 0170 Revision: 01700022 Serial number: 01008257040000 Coding: 4618301 Shop #: WSC 02335 785 00200 VCID: 2EB6DBB77918156267F2AB-807A Subsystem 1 - Part No: 1K0 951 605 C Component: LIN BACKUP HORN H03 1301 No fault code found. ------------------------------------------------------------------------------- Address 47: Sound System Labels: 4F0-910-223-BO.lbl Part No SW: 4F0 910 223 J HW: 4F0 035 223 G Component: DSP-High C6 H09 0240 Revision: PROD_01 Serial number: 00000000807306 Coding: 0000026 Shop #: WSC 02335 785 00200 VCID: 25A4249B2CEE563A9648CC-8070 No fault code found. ------------------------------------------------------------------------------- Address 4F: Centr. Electr. II Labels: 4F0-910-280.lbl Part No SW: 4F0 910 280 HW: 4F0 907 280 B Component: ILM Beifahrer H10 0080 Revision: Serial number: 00000000010391 Coding: 0012114 Shop #: WSC 02335 785 00200 VCID: 5E564B774938C5E297925B-800A No fault code found. ------------------------------------------------------------------------------- Address 52: Door Elect, Pass. Labels: 4F0-910-793-52.lbl Part No SW: 4F0 910 793 E HW: 4F0 959 792 E Component: TSG BF H12 0080 Revision: 00000000 Serial number: qh Coding: 0051947 Shop #: WSC 02335 785 00200 VCID: 2CB2D1BF4F0467724986B1-8078 No fault code found. ------------------------------------------------------------------------------- Address 53: Parking Brake Labels: 4F0-910-801.clb Part No SW: 4F0 910 801 HW: 4F0 907 801 Component: EPB C63C0030 H03 0030 Revision: C63C0030 Coding: 0006022 Shop #: WSC 02334 785 00200 VCID: 5D544C7B443EDEFA8E9854-8008 No fault code found. ------------------------------------------------------------------------------- Address 55: Headlight Range Labels: 4F0-910-357.lbl Part No SW: 4F0 910 357 C HW: 4F0 907 357 C Component: AFS 1 H01 0030 Revision: 00000001 Serial number: Coding: 0000016 Shop #: WSC 02325 785 00200 VCID: 26A6239751E85D229F42F3-8072 Subsystem 1 - Part No: 4F0 941 329 B Component: AFS-Modul links H02 0020 Subsystem 2 - Part No: 4F0 941 329 B Component: AFS-Modul rechtsH02 0020 No fault code found. ------------------------------------------------------------------------------- Address 56: Radio Labels: 4E0-910-541.lbl Part No SW: 4E0 910 541 T HW: 4F0 035 541 B Component: TUNER EU/US/RDW H42 0630 Revision: 00000000 Serial number: 394JO057630005 Coding: 0000002 Shop #: WSC 02335 785 00200 VCID: 318CC0CB68260A9A7AD048-8064 No fault code found. ------------------------------------------------------------------------------- Address 61: Battery Regul. Labels: 4F0-910-181.lbl Part No SW: 4F0 910 181 E HW: 4F0 915 181 A Component: J0644 BEM H12 0590 Revision: 00000000 Serial number: 00000000144973 Shop #: WSC 40233 444 83861 VCID: 23A03A8322DAA80AF85CD2-8076 Subsystem 1 - Part No: 009 151 05D L Component: von VA0 35070440US Coding: 3030393135313035444C2056413033353037303434305553 Shop #: WSC 84010 444 12345 2 Faults Found: 02272 - Quiescent Current Stage 1 000 - - - Intermittent Freeze Frame: Fault Status: 00100000 Fault Priority: 7 Fault Frequency: 3 Reset counter: 255 Mileage: 172991 km Time Indication: 0 Date: 2005.02.12 Time: 15:57:53 02273 - Quiescent Current Stage 2 000 - - Freeze Frame: Fault Status: 01100000 Fault Priority: 7 Fault Frequency: 2 Reset counter: 255 Mileage: 172991 km Time Indication: 0 Date: 2005.02.12 Time: 16:47:21 ------------------------------------------------------------------------------- Address 62: Door, Rear Left Labels: 4F0-910-795.lbl Part No SW: 4F0 910 795 E HW: 4F0 959 795 E Component: TSG HL H21 0050 Coding: 0051754 Shop #: WSC 02327 785 00200 VCID: 2EB6DBB77918156267F2AB-807A No fault code found. ------------------------------------------------------------------------------- Address 65: Tire Pressure Labels: 4F0-910-273-BA.lbl Part No SW: 4F0 910 273 B HW: 4F0 907 273 A Component: Reifendruck 3 H05 0100 Revision: 00050100 Serial number: 00000900013381 Coding: 0062422 Shop #: WSC 02335 785 00200 VCID: 22AE3F873DC0A102F36A2F-8076 No fault code found. ------------------------------------------------------------------------------- Address 67: Voice Control Labels: 4E0-910-75x-67.lbl Part No SW: 4E0 910 754 Q HW: 4E0 035 753 A Component: SDS 3501 US H45 0630 Revision: 00000000 Serial number: 00000510190072 Shop #: WSC 12336 024 394758 VCID: 3482C9DF97343FB2113669-8060 No fault code found. ------------------------------------------------------------------------------- Address 72: Door, Rear Right Labels: 4F0-910-795.lbl Part No SW: 4F0 910 795 E HW: 4F0 959 794 E Component: TSG HR H21 0050 Coding: 0051754 Shop #: WSC 02327 785 00200 VCID: 2EB6DBB77918156267F2AB-807A No fault code found. ------------------------------------------------------------------------------- Address 76: Park Assist Labels: 4Fx-910-283.lbl Part No SW: 4F0 910 283 B HW: 4F0 919 283 B Component: Parkhilfe 4-Kan H09 0030 Revision: 00H09000 Serial number: 11720528704083 Coding: 0001206 Shop #: WSC 02335 785 00200 VCID: 23A03A8322DAA80AF85CD2-8076 No fault code found. ------------------------------------------------------------------------------- Address 77: Telephone Cannot be reached End-------------------------(Elapsed Time: 03:25)--------------------------
