Results 1 to 7 of 7
    Senior Member Two Rings MrSnickelsnizer's Avatar
    Dec 03 2012
    michigan
    check your intermediate shaft bearings
    Next time you do a timing belt just pull off the oil gear and check your bearings. I randomly decided to do that and lo and behold here is what I found. I also found out audi doesn't even offer replacements. Integrated engineering or Techtonics Tuning (where I got mine) are your only options. It sucked getting the front one out and I am definitely not replacing the rear one as I have no idea how you would get the old one out. It is way inside the block. Plus installing the new would be incredibly challenging. My rear one actually looked quite good. No noticeable wear. Just thought I would share.
    1998 Audi A4 1.8t Quattro
    Veteran Member Three Rings Papa_Dios's Avatar
    Jul 01 2010
    fl
    Sent from my Z987 using Tapatalk
    Finally off jackstands!!!!!!!!!!!!!!!!!!!!
    My 5 speed swap thread
    Parts I have for sale!!!
    Senior Member Two Rings MarcRogers's Avatar
    Jan 18 2016
    PA
    About to do my TB very soon thank god I saw this. How many miles are on that motor?
    Veteran Member Four Rings csosnowski's Avatar
    Sep 05 2010
    Computers
    Terrebonne, Oregon
    You can get sealed power bearings from Napa or another parts place for a 1982 dodge omni 1.7L.
    SEP 1726M is the part number for them, auxiliary shaft bearing set is what they are called in the catalog. Around $30 if I recall.
    I had to do some digging to find them, that's what I used in my built motor. I had the machine shop r&r them when the block was being hot tanked.
    2001.5 S4 Avant Sport 6MT - Brilliant Black - Nogaro Alacantra - SOLD
    2003 RS6 - Avus Silver - Black / CF - RIP
    2013 Q5 2.0t - Black - Black - RIP
    2004 A4 USP Avant 1.8t 6MT - Silver - Black cloth
    Dec 03 2012
    michigan
    Quote Originally Posted by MarcRogers View Post
    almost 160,000mi
    Quote Originally Posted by csosnowski View Post
    I'll probably have my local napa order a set and I'll check those out :)
    Jan 18 2016
    PA
    They work just fine?
    Oct 30 2008
    B5, B7, B8, 8V, 4M
    Big Lake, MN
    This just in- engine bearings wear out.
    Sorry for the snarky comment, but it is true. The rear one would need to have the motor completely torn down to replace. My avant has 243k on it and is still kicking. Was planning on rebuilding a motor on the side for it, but now that I bought an S4 that won't happen anytime soon.
    2020 SQ7- Wife's ride
    2000 S4- Working?
