    Veteran Member Three Rings cjw's Avatar
    Aug 11 2015
    Alberta
    Exhaust rattle at at central clamp
    So I've noticed a rattle around 1400-1500 rpm at the central clamp between my OEM exhaust and the Magnaflow. There is lots of clearance in all directions and It seemed to develop about 5-6 weeks after the install. I went under there, and tightened it further and it went away for a few days, but it's back. I had my wife rev the car in neutral while I was underneath and the rattle is definitely from the clamps.
    I am worried I would be overtightening the OEM clamps. They already look like they are bending.
    Any ideas?
    2013 Lava Grey S4 S-Tronic
    Injen, EPL DP (3.2 ratio) +TCU, Magnaflow Catback Back to Stock, PLM HX
    Established Member Two Rings ARoach04's Avatar
    Jul 17 2015
    '15 Q5 Prestige TDI
    Masshole
    I have this same issue now after installing my new downpipes last weekend. It's appears that those clamps are rubbing against the Heat shield between the exhaust and the drive shaft.
    '16 Audi S4 Premium + | DSG | Florett Silver | Sport Differential | MMI+ | BO | Black Optics | ECS | V1 | AWE |
    '15 Audi Q5 Prestige TDI | Glacier White | MMI+ | BO | Black Optics |
    Veteran Member Three Rings creativecody's Avatar
    Jul 20 2012
    Quote Originally Posted by cjw View Post
    Any ideas?
    Is it a rattle or more of a vibration? I have AWE Touring and eventually developed a vibration (felt through the center console armrest) in that same RPM range. Try turning the clamp so the screw isn't pointing at the heat shield. When mine was heated up it would move enough for that screw to come in contact with the heat shield and vibrate the center console. Shop turned the clamp and it's been fine ever since.
    2013 S4
    APR Stage 2+ (Dual Pulley & Ultracharger) | APR CPS v2 | Milltek Resonated | Bilstein PSS10 Coilovers | Eurocode Alu Kreuz, Front/Rear Sways, Front/Rear Endlinks | Eurocode Transmission & Differential Mounts | SPC Control Arms | Stoptech BBK 380mm (front), Stoptech Rotors/Pads (rear), SS Lines | HRE FF01 19x9.5 et45 | Michelin PSS 265/35/19 | ECS Carbon Fiber
    Aug 11 2015
    Alberta
    It's a rattle in the clamp. There is clearance all around. If I push on the clamp a bit, the rattle stops. I just don't to keep tightening it and over do it.
    Established Member Two Rings RJRAUDI's Avatar
    Apr 09 2014
    Oakland County MI
    I have the Magnaflow also. A couple weeks after install I had a rattle. Took it to two different shops, one claimed it was a blown resonator. Finally tacked it down to the center clamps like you are saying. I had them really torque the clamps and haven't had the issue since (it's been about a year).
    I read on a previous thread that replacing the center clamps solved the issue for a different member. Maybe pick up a new set and try them?
    2014 S4 - Brilliant Black-Black/Lunar Alcantara - SOLD
    2017 Dodge Charger R/T Super Scat Pack
