Results 1 to 15 of 15
    Oct 02 2006
    Wadsworth,OH
    :: ECS Tuning :: #SaveThePans | B8/B8.5 S4 ECS Street Shield
    The belly pans provided for modern Audi’s have always appeared to be out of place, cost-cutting parts.
    Many enthusiasts have chosen to run their cars without this protective cover entirely. This decision, however, ignores the unfortunate reality that the belly pan protects several critical engine and drivetrain components.
    ECS has a much more sensible solution – The Street Shield Skid Plate features corrosion resistant, 4.76mm thick 5052 aluminum, offering complete engine undercarriage protection.
    #SaveThePans
    Fits:
    Audi B8/B8.5 S4 2010-2016
    Be sure to check out our -----> Installation PDF <-----
    Jason
    Veteran Member Four Rings ShelbyM3's Avatar
    Feb 05 2007
    Portland, OR
    It's saved my pan now twice.
    Nov 28 2015
    Montreal, QC
    you guys need to make the panel that clip to the bumper !
    S4 B8.5 no track, just enjoying spirited driving.
    Senior Member Two Rings Pawan2013's Avatar
    May 28 2013
    B8 S4, DSG, Sport Diff, B&O + Nav
    Many Mods
    Oct 02 2006
    Wadsworth,OH
    Appreciate the feedback. We do not feel it necessary to make that piece out of aluminum. This would simply just add more weight as there is nothing above that plastic piece that actually needs protected. There is just a crumple zone.
    Jason
    Nov 28 2015
    Montreal, QC
    Jason
    because plastic break easily, mine is. and i can only imagine the stream of turbulance air created with the open spot/broken area.
    Oct 02 2006
    Wadsworth,OH
    Quote Originally Posted by waxxonMTL View Post
    We have replacements below.
    Click HERE
    Jason
    Feb 06 2014
    portland, OR
    How about a hole for easy access to the drain plug!
    Oct 02 2006
    Wadsworth,OH
    Quote Originally Posted by nomis88 View Post
    Design for this likely will not be revised unfortunately. Appreciate the feedback though!
    Jason
    Oct 14 2012
    Empty...for now...
    SE PA
    I noticed when I installed mine that I had to remove the reinforcing bracket/angle that comes from the factory mounted to the subframe just in front of the steering rack (2015 S4). I suppose the Street Shield does the same job of deflecting anything from hitting the steering rack, but in case of any dealer warranty type issues I'd prefer to leave the reinforcement bracket in place with the Street Shield mounted over it. My constructive criticism would be to revise the Street Shield to allow for this, if possible.
    SOLD 2015 Daytona Gray S4
    Veteran Member Four Rings infinkc's Avatar
    Feb 14 2004
    S Ã C, CÃ*
    Jason
    Yea was the only thing ever stopping me from buying one. Wish it had a drain hole with cover.
    There are 10 kinds of people in this world, those who know binary and those who don't.
    Veteran Member Three Rings cjw's Avatar
    Aug 11 2015
    Alberta
    + one for drain hole.
    2013 Lava Grey S4 S-Tronic
    Injen, EPL DP (3.2 ratio) +TCU, Magnaflow Catback Back to Stock, PLM HX
    Oct 02 2006
    Wadsworth,OH
    Quote Originally Posted by SteveYem View Post
    I can't see removing the factory piece and installing our street shield as a replacement causing any issues with warranty. You're literally replacing a piece of metal with a larger piece of metal. If you hit something with the street shield installed and hypothetically causes damage to the rack it more that likely would have caused the same type of damage with the factory piece if not more damage.
    Jason
    Jul 21 2014
    United States
    I kept my factory bracket and added the street shield over it by adding two or three bolt holes to the shield. Best of both worlds. Search for threads started by me and you should find all the details. Pretty easy change. The factory bracket is very heavy steel and angle shaped, which will take a big hit that would shred the aluminum sheet.
    Oct 14 2012
    Empty...for now...
    SE PA
    Quote Originally Posted by GTItoS4 View Post
    Thanks for chiming in. I remember reading your post about this. Next time I get under the car I may follow suit. I agree that the steel angle is very robust and would serve its purpose better than the relatively thin aluminum, so I'll feel much better when I get it reinstalled.
