Results 1 to 24 of 24
    Jun 02 2016
    South Florida
    How much should I be willing to spend to install coilovers on my Audi A4?
    After doing a bit of searching on the forum, I found that you guys were being quoted at $300-400.
    My local mechanic (very reputable) quoted me $600-800 at $100/hr. He said Audi's were much more difficult than something like a Honda (he did my brother's for $200) and that it would be an all-day affair.
    This sounds super expensive especially in comparison, where you guys were saying $500 is too much. What I'm asking is: is that way too many hours for getting that job done or is the hourly rate too high? Most quotes I've gotten around the $700+ range but there's another local shop which just quoted me $350 - not sure if they're used to doing this with Audi's though.
    Veteran Member Four Rings Party_Marty's Avatar
    Nov 02 2015
    Sector 9 Long-board, Rugby Kit
    In the woods
    if you were in MD I would do it for you for 300-400 haha.
    ---------------------------------------------------------- IG: party_martyy ----------------------------------------------------------------------
    ---------------------2014 A4 - 6 Speed - Phantom Black Pearl -------------- Peep the Build ---------------------
    Veteran Member Four Rings JeriQo's Avatar
    Jul 08 2015
    next quote say its a 2016 sonata.
    people seem to charge more if its a "luxury" car
    2012 BB A4 P+ S-line Exterior |FBSW RS Paddles/Pedals|CR-15|AFE Filter|ECS inlet|S4 Dual Exhaust|Ace Convex 19x8.5|ECS 10mm rear|Solowerks S1
    Mar 28 2016
    Cambridge, ON
    600-800 seems like way to much to me. My understanding is time wise, about an hour a corner. So I think 400 or so is about right.
    Nov 02 2015
    In the woods
    Quote Originally Posted by JeriQo View Post
    haven't you seen any of the commercials tho? a 2016 sonata is a luxury car
    Feb 24 2013
    CA
    300 is about right tbh. But then again, i did it myself. With a jack. And basic tools.
    Veteran Member Four Rings earhythmic's Avatar
    Sep 17 2006
    ‘17 F450, ‘24 Street Triple RS
    San Francisco Bay Area
    I got quoted a little over $800 too. That's what pushed me over the edge to DIY. Glad I did, it forces you to become familiar with the workings of the suspension which totally helps with troubleshooting or researching mods. Done it twice now, about to be a third.
    2013 Allroad - 12.18s 1/4 mile
    CTS K04| APR | IE | Magnaflow | AirLift 3H | Hotchkis | Vorsteiner
    clicky for build thread
    past: B6 S4, B5 A4
    Mar 11 2012
    Audi A5
    Ventura, CA
    I was quoted 850 with alignment and that was more than I paid for the coilovers. Ended up doing it myself and due to a couple screw ups took the better part of two days but if I were to do it all over again I would still do it myself
    2011 A5 2.0T//Ice Silver Metallic//30% Tint//RS5 Replica Grille//LED Interior Lighting//APR Carbonio Cold Air Intake, HFC, Downpipe, and Stage 1 ECU Tune//Carbon Fiber Mirror Caps//Lamin-x tailights//H&R Swaybars and Street Performance Coilovers
    Veteran Member Four Rings zcspec's Avatar
    Aug 10 2015
    Need VAG-COM work, IM me
    Orange County
    I've done the B8/B8.5 chassis a few times and it's not difficult. A reputable shop *should* be able to complete it in about 5hrs for roughly $400-$500. Anything more, it's too expensive. It's not difficult to do, just very time consuming and requires an extra set of hands to make things easier. The front assembly is heavy and the rear sub frame has to be dropped in order to access and remove the rear springs. If you do have a shop perform the work, ask them, what torque specs they use on all the bolts. If they don't do it right, don't pay!
    Mar 11 2012
    Audi A5
    Ventura, CA
    Quote Originally Posted by zcspec View Post
    I did my back without dropping the subframe. As long as you have the spring compressor that goes on the outside of the spring rather than the inside, you can get the springs out without dropping it.
    Veteran Member Four Rings KFizz's Avatar
    Dec 27 2009
    Edmonton/Alberta
    $0
    Sent from my Nexus 5 using Tapatalk
    Kyle
    2014 a4 Allroad /// Ibis, Unpainted Lowers (True AR)
    Veteran Member Four Rings oascom's Avatar
    Jan 08 2013
    New Jersey
    200$
    APR, Eurocode, AWE, P3, aFe , CTS, Spulen, H&R, 034Motorsport, STaSIS
    Senior Member Three Rings NLPed68's Avatar
    Jan 21 2016
    1968 Chevy C10 Restomod, 1974 Bronco Crawler
    Hayden, AL
    If you're even remotely mechanical and have access to the internet (and the fact that your posting on a forum means you do), for less than half the install quote you can buy all the tools required for the install and some beer for some like minded car guys and get it done. Just my .02¢
    Thanks,\
    Ed
    2012 A4 Avant... APR K04 /c APR tune, B&B catback, 034 HFC, 19" Avante Garde M510's, Bilstein B12 kit, Eurocode F&R swaybars/endlinks, Alu Kreutz, RS4'ish' Grilles, ERON rearview camera, EuroCode FMIC & plumbing, Kohlefaser Luft-Technik intake System, Ross-Tech VAGCOM, R8 coils, S-Line steering wheel /c paddle shifters, S4 F&R brakes /c drilled & slotted rotors/EBC's/stainless lines, LED taillights, Not a Mod, but WeatherTech laserfit floormats, 20% Tint, More to follow
    Veteran Member Three Rings ddun's Avatar
    Jun 06 2009
    Stanton, CA
    I paid $250
    Veteran Member Four Rings SleeperCar's Avatar
    Jan 03 2012
    VW Atlas and too many detailing supplies
    Wilmington NC
    300-450 is a reasonable range. All the specialist shops around me charge 85-95/hr, so 100/hr seems high....
    2019 S4 Build
    2013 A4 Scuba Blue Metallic - SOLD (never forgotten)
    IG: @steves_s4
    Veteran Member Four Rings Audi 4 Life's Avatar
    Jan 16 2011
    06 D3 A8 Black/peanut with alcantara
    Earth
    It depends on where you live. 400 roughly is fair not including alignment.
    I suggust not getting an alignment. And going to a tires plus or firestone after they offer lifetime alignment for 200 so anytime you want to adjust or get tires or if your just bored you can go in for alignment.
    Sent from my SM-G920T using Tapatalk
    RIP - JHM B6 3.0 6MTQ USP Denim Blue/Black w/ Nappa Silver
    Current- B8 A4 2.0t S-Line Stasis Challenge Extreme Edition, Alcantara Headliner, ALA/ACC and 3g+ swap
    D3 A8 4.2 Black/Peanut (Daily)
    Sep 07 2015
    Louisville,KY
    I paid $600 for a shop to install mine here in KY,
    Established Member Two Rings na_v's Avatar
    Jan 27 2015
    got it done for 300
    Current : 2013 S5 Premium Plus | Glacier White | Magma Interior | DSG | ADS | Sport Diff | Carbon Atlas | B&O | Adaptive Lights
    AWE Track Exhaust | PUR 4OUR Forged Wheels | ECS Spacers | Carbon Imports Trunk Lip | Carbon Imports CF Mirrors | ECS Carbon Fiber Intake
    Past : 2014 Ibis White Audi A4 Progressiv | ECS Spacers | H&R Sport Springs | APR Stage 1 | RS Grille | US Millworks
    Buncha motorcycles
    Memphis, TN
    DIY plus beer
    Aug 11 2012
    Beaufort, SC
    $300 at most. Did it with a buddy and I for the first time on my car and got it done within 3-4 hrs.
    Veteran Member Three Rings Dannaye's Avatar
    Mar 20 2014
    1968 Oldsmobile 442
    Orlando FL
    Check local Facebook Audi groups or ig pages. People will gladly help for cheaper
    Instagram @Dannaye
    Jun 30 2009
    Washington DC
    With the folks who did it. None of you guys had trouble removing the pinch bolt. That bolt is the reason i do not work on suspensions.
    Putting the control arm back to torque it properly was equally as annoying.
    Mar 11 2012
    Audi A5
    Ventura, CA
    Quote Originally Posted by pkny View Post
    Mine was extremely easy in and out.
    Mar 20 2016
    Elmira, NY
    I paid $400, if you have a couple hours and a friend or two it really isn't too bad to DIY. I just didn't have time when I bought my springs and Im not a patient individual!
