Results 1 to 13 of 13
    Senior Member Two Rings tomahawk297's Avatar
    Jul 25 2014
    Mississippi
    Wheel leaning after control arm replacement?
    Alright so I just got done replacing all of the control arms, TR end, CV axle, and sway bar end link on the driver side. After I put the wheel back on and dropped it to the ground as I was getting ready to jack the other side up and get started on it I noticed the side I just finished leans outwards pretty bad. I made sure to measure the tie rod end and put everything all back as it was and torqued to spec. Took my sweet ass time to make sure I did it as well as I could, I don't think I messed up! Do I just need an alignment? It just looks worse than I thought it would for just needing an alignment. Thanks in advance!
    Veteran Member Three Rings konarider94's Avatar
    Dec 28 2011
    14 EBR 1190SX
    kalamazoo, MI
    yes you need an alignment now. The parts are going to have small differences in dimensions that mess everything up.
    2018 A5 S-Line Manual
    Jul 25 2014
    Mississippi
    Thanks for the reply, once I finish the passenger side I'm going straight to get an alignment. Looks like it would really SHRED my tires with the lean it's got right now. Good news is I hear no more squeaking and creeking when I bounce the driver side up and down! Feels a lot more solid also.
    May 20 2010
    Yes, definitely need an alignment, as you've completely changed the geometry when you removed all those pieces. Afterwards, you should be great. Hopefully the shop is close.
    Jul 25 2014
    Mississippi
    A few miles is all, I'll drive slow lol.
    Feb 24 2004
    Minneapolis
    Quote Originally Posted by tomahawk297 View Post
    What does "leans outward" mean? Does the top of the wheel lean out? Boy if that's pretty obvious, I'm not sure it's just an alignment issue. And if your tie rods were off by a mile, it would affect the toe, not the camber.
    11 A4 Q, Prestige, Black
    207,000 miles, APR Stage 1
    May 20 2010
    Quote Originally Posted by mtroxel View Post
    Alignment should fix some, if not all of that. Anything beyond that will be charged.
    OP, just to make sure--you didn't accidentally confuse which upper control arm goes where, did you?
    Jul 25 2014
    Mississippi
    Absolutely not, I did one at a time to be sure of this and made sure the new one matched the old one exactly.
    Jul 25 2014
    Mississippi
    Just realized I meant the bottom of the wheel faces outward not the top of the wheel.
    May 20 2010
    Important distinction. That's probably fine for now and will get straightened out at alignment. You should have some slight negative camber when all is said and done.
    Jul 25 2014
    Mississippi
    Thanks for the replies and reassurance, now I can rest well tonight!
    Feb 15 2016
    Cambridge,Ontario
    I hope you are torquing.with weight on the car.
    2014 A4 2.0TQ Technik Manual
    2006 A4 2.0TQ Manual
    1978 Porsche 911SC Targa
    1976 Yamaha XS 360
    Apr 24 2016
    California
    Made this mistake with poly bushings in my 96 Cobra, freakin thing sounded like a 50 year old truck any time I hit a bump or anything. That creaking noise will haunt me till I die.
