Results 1 to 8 of 8
    Feb 28 2016
    bradenton/fl/SE
    No Crank - no start. Power to dash and accessories.
    2009 Audi A4 Quattro. Battery was low and me like a dummy hooked up a charger directly to the battery while the cables were still attached (wasn't thinking). Now the car wont crank and got the ESP light. Hooked up VCDS and have tons of malfunctions.
    Any ideas? Did I blow a power supply relay, killed the ECM or what?
    Thanks for the help!!
    VIN: WAULF78K89A132762 Mileage: 109280km-67903miles
    01-Engine -- Status: Malfunction 0010
    02-Auto Trans -- Status: Malfunction 0010
    03-ABS Brakes -- Status: Malfunction 0010
    04-Steering Angle -- Status: OK 0000
    05-Acc/Start Auth. -- Status: Malfunction 0010
    08-Auto HVAC -- Status: Malfunction 0010
    09-Cent. Elect. -- Status: Malfunction 1010
    15-Airbags -- Status: Malfunction 0010
    16-Steering wheel -- Status: Malfunction 0010
    17-Instruments -- Status: Malfunction 0010
    19-CAN Gateway -- Status: Malfunction 0010
    42-Door Elect, Driver -- Status: Malfunction 0010
    46-Central Conv. -- Status: Malfunction 0010
    47-Sound System -- Status: Malfunction 0010
    52-Door Elect, Pass. -- Status: Malfunction 1010
    53-Parking Brake -- Status: Malfunction 1010
    56-Radio -- Status: Malfunction 0010
    62-Door, Rear Left -- Status: Malfunction 0010
    65-Tire Pressure -- Status: Malfunction 0010
    72-Door, Rear Right -- Status: Malfunction 1010
    Address 01: Engine (DL0MA-CAEB) Labels: 06H-907-115-CAB.clb
    Part No SW: 8K2 907 115 AL HW: 8K2 907 115 D
    Component: 2.0l R4/4V TF H14 0001
    Revision: E1H14---
    Coding: 0104010A190F0160
    Shop #: WSC 06436 444 11696
    ASAM Dataset: EV_ECM20TFS0118K2907115AL 001001
    ROD: EV_ECM20TFS0118K2907115AL.rod
    VCID: 79FE75CBF8CAF5F61A-802C
    2 Faults Found:
    5463 - Starter Control; Returned Message
    P3052 00 [167] - 50 Short to Plus
    MIL ON - Not Confirmed - Tested Since Memory Clear
    Freeze Frame:
    Fault Status: 00000001
    Fault Priority: 2
    Fault Frequency: 1
    Mileage: 109284 km
    Date: 2008.05.27
    Time: 00:31:51
    4716 - No Communications with Parking Brake Control Module
    U0128 00 [036] - -
    Intermittent - Not Confirmed - Tested Since Memory Clear
    Freeze Frame:
    Fault Priority: 6
    Fault Frequency: 1
    Mileage: 109284 km
    Date: 2008.05.27
    Time: 00:00:18
    Readiness: 1110 0101
    Address 02: Auto Trans (J217) Labels: 0B6-927-156.clb
    Part No SW: 8K0 927 158 C HW: 0B6 927 156
    Component: 0B6 20TFSIUSA H04 0030
    Revision: --H04---
    Coding: 001002
    Shop #: WSC 06325 000 00000
    ASAM Dataset: EV_TCMAL651 A01004
    ROD: EV_TCMAL651.rod
    VCID: 3664BEF78954DA8EB7-8062
    1 Fault Found:
    2478 - No Communications with Parking Brake Control Module
    U0128 00 [036] - -
    Freeze Frame:
    Fault Priority: 6
    Fault Frequency: 1
    Mileage: 109284 km
    Date: 2008.05.27
    Time: 00:00:19
    Address 03: ABS Brakes (J104) Labels: 8K0-907-379-V1.clb
    Part No SW: 8K0 907 379 AB HW: 8K0 907 379 AB
    Component: ESP8 quattro H04 0060
    Revision: -------- Serial number: --------------
    Coding: 150500
    VCID: 79FE75CBF0CAF5F61A-802C
    6 Faults Found:
    01314 - Engine Control Module
    013 - Check DTC Memory - Intermittent
    Freeze Frame:
    Fault Status: 00101101
    Fault Priority: 6
    Fault Frequency: 2
    Reset counter: 68
    Mileage: 109284 km
    Time Indication: 0
    Date: 2014.12.17
    Time: 20:59:39
    Freeze Frame:
    Hex Value: 0x00C0
    Hex Value: 0x4082
    Hex Value: 0x0009
    Hex Value: 0x4692
    Hex Value: 0x00FF
    00473 - Control Module for Elect. Park/Hand Brake (J540)
    Freeze Frame:
    Fault Status: 01101101
    Fault Priority: 6
    Fault Frequency: 10
    Reset counter: 29
    Mileage: 109284 km
    Time Indication: 0
    Date: 2014.12.17
    Time: 20:59:53
    Freeze Frame:
    Hex Value: 0x0000
    Hex Value: 0x2282
    Hex Value: 0x0013
    Hex Value: 0x0294
    Hex Value: 0x00FF
    00532 - Supply Voltage B+
    002 - Lower Limit Exceeded - Intermittent
    Freeze Frame:
    Fault Status: 00100010
    Fault Priority: 6
    Fault Frequency: 1
    Reset counter: 68
    Mileage: 109284 km
    Time Indication: 0
    Date: 2015.01.06
    Time: 12:00:21
    Freeze Frame:
    Hex Value: 0x0000
    Hex Value: 0x1082
    Hex Value: 0x0018
    Hex Value: 0x0268
    Hex Value: 0x00FF
    004 - No Signal/Communication - Intermittent
    Freeze Frame:
    Fault Priority: 6
    Fault Frequency: 2
    Reset counter: 68
    Mileage: 109284 km
    Time Indication: 0
    Date: 2014.12.17
    Time: 20:59:39
    Freeze Frame:
    Hex Value: 0x00C0
    Hex Value: 0x4082
    Hex Value: 0x0009
    Hex Value: 0x4692
    Hex Value: 0x00FF
    01315 - Transmission Control Module
    Freeze Frame:
    Fault Status: 00100100
    Fault Priority: 6
    Fault Frequency: 1
    Reset counter: 68
    Mileage: 109284 km
    Time Indication: 0
    Date: 2008.05.27
    Time: 00:00:21
    Freeze Frame:
    Hex Value: 0x0000
    Hex Value: 0x0782
    Hex Value: 0x000A
    Hex Value: 0x8593
    Hex Value: 0x00FF
    Freeze Frame:
    Fault Priority: 6
    Fault Frequency: 10
    Reset counter: 29
    Mileage: 109284 km
    Time Indication: 0
    Date: 2014.12.17
    Time: 20:59:53
    Freeze Frame:
    Hex Value: 0x0000
    Hex Value: 0x2282
    Hex Value: 0x0013
    Hex Value: 0x0294
    Hex Value: 0x00FF
    Address 05: Acc/Start Auth. (J393) Labels: 8K0-907-064-05.clb
    Part No SW: 8K0 907 064 F HW: 8K0 907 064 F
    Component: BCM2 1.1 H80 0141
    Revision: 00002001
    Coding: 090100
    VCID: 336287E39226CFA690-8066
    Subsystem 1 - Part No SW: 8T0 959 754 A HW: 8T0 959 754 A
    Component: FBSAUDIB8 IDG H37 0060
    Subsystem 2 - Part No SW: 8K0 905 852 D HW: 8K0 905 852 D
    Component: ELVAUDIB8 H36 0041
    5 Faults Found:
    00956 - Key 2
    Freeze Frame:
    Fault Priority: 3
    Fault Frequency: 1
    Reset counter: 68
    Mileage: 109284 km
    Time Indication: 0
    Date: 2014.12.29
    Time: 14:22:59
    02812 - Supply Voltage (Terminal 30) for Electronic Steering Column Lock
    Freeze Frame:
    Fault Priority: 5
    Fault Frequency: 10
    Reset counter: 68
    Mileage: 109284 km
    Time Indication: 0
    Date: 2015.01.06
    Time: 11:54:43
    00446 - Function Limitation due to Under-Voltage
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 7
    Reset counter: 68
    Mileage: 109284 km
    Time Indication: 0
    Date: 2015.01.06
    Time: 11:59:56
    01330 - Central Control Module for Central Convenience (J393)
    Freeze Frame:
    Fault Priority: 6
    Fault Frequency: 8
    Reset counter: 68
    Mileage: 109284 km
    Time Indication: 0
    Date: 2015.01.06
    Time: 12:00:54
    02811 - Control Module for Electronic Steering Column Lock (J764)
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 2
    Reset counter: 68
    Mileage: 109284 km
    Time Indication: 0
    Date: 2008.05.27
    Time: 00:00:01
    Address 08: Auto HVAC (J255) Labels: Redir Fail!
    Part No SW: 8T1 820 043 AA HW: 8T1 820 043 AA
    Component: KLIMA 1 ZONE H06 0140
    Revision: A1000000 Serial number: 0118.09.080261
    Coding: 64002000
    VCID: 70E848EFA3B0B4BEAD-8024
    7 Faults Found:
    Freeze Frame:
    Fault Priority: 1
    Fault Frequency: 2
    Reset counter: 68
    Mileage: 109284 km
    Time Indication: 0
    Date: 2015.01.06
    Time: 11:59:24
    Freeze Frame:
    Voltage: 8.40 V
    Temperature: -7.0°C
    RPM: 0 /min
    008 - Implausible Signal - Intermittent
    Freeze Frame:
    Fault Status: 00101000
    Fault Priority: 6
    Fault Frequency: 1
    Reset counter: 68
    Mileage: 109284 km
    Time Indication: 0
    Date: 2008.05.27
    Time: 00:00:21
    01206 - Signal for Duration of Ignition Off Time
    Freeze Frame:
    Fault Status: 01101000
    Fault Priority: 7
    Fault Frequency: 10
    Reset counter: 29
    Mileage: 109284 km
    Time Indication: 0
    Date: 2008.05.27
    Time: 00:00:13
    03220 - Stop Valve for Coolant for Climatronic (N422)
    009 - Open or Short to Ground - Intermittent
    Freeze Frame:
    Fault Status: 00101001
    Fault Priority: 3
    Fault Frequency: 1
    Reset counter: 68
    Mileage: 109284 km
    Time Indication: 0
    Date: 2008.05.27
    Time: 00:00:20
    00457 - Control Module for Network (J519)
    Freeze Frame:
    Fault Priority: 6
    Fault Frequency: 1
    Reset counter: 68
    Mileage: 109284 km
    Time Indication: 0
    Date: 2008.05.27
    Time: 00:58:00
    00256 - A/C Pressure/Temperature Sensor (G395)
    Freeze Frame:
    Fault Priority: 7
    Fault Frequency: 1
    Reset counter: 68
    Mileage: 109284 km
    Time Indication: 0
    Date: 2008.05.27
    Time: 00:58:00
    Freeze Frame:
    Temperature: 29.0°C
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 2
    Reset counter: 69
    Mileage: 109284 km
    Time Indication: 0
    Date: 2008.05.27
    Time: 00:06:29
    Freeze Frame:
    Temperature: 28.0°C
    Temperature: 27.0°C
    Load: 0.0 %
    Absolute Pres.: 1.0 bar
    RPM: 1160 /min
    Speed: 0.0 km/h
    Current: 0.000 A
    Temperature: 37.0°C
    Address 09: Cent. Elect. (J519) Labels: 8K0-907-063.clb
    Part No SW: 8K0 907 063 D HW: 8K0 907 063 D
    Component: BCM1 1.0 H22 0253
    Revision: 05022001 Serial number: 00000000226605
    Coding: 690000B1063C00010000080300007F5F0F1452080000000100 0000
    VCID: 306888EF6330F4BEED-8064
    Subsystem 1 - Part No SW: 8K1 955 119 A HW: 8T1 955 119 Labels: 1KX-955-119.CLB
    Component: WWS 170908 H06 0070
    Coding: 00FD11
    Subsystem 2 - Part No SW: 8K0 941 531 F HW: 8K0 941 531 F
    Component: E1 - LDS H07 0070
    7 Faults Found:
    Freeze Frame:
    Fault Priority: 6
    Fault Frequency: 1
    Reset counter: 68
    Mileage: 109284 km
    Time Indication: 0
    Date: 2015.01.06
    Time: 12:02:00
    Freeze Frame:
    Fault Priority: 3
    Fault Frequency: 1
    Reset counter: 68
    Mileage: 109284 km
    Time Indication: 0
    Date: 2015.01.06
    Time: 12:00:00
    00910 - Indicator Lamp for Emergency Flashers (K6)
    012 - Electrical Fault in Circuit - Intermittent
    Freeze Frame:
    Fault Status: 00101100
    Fault Priority: 2
    Fault Frequency: 2
    Reset counter: 68
    Mileage: 109284 km
    Time Indication: 0
    Date: 2015.01.06
    Time: 11:54:00
    Freeze Frame:
    Fault Priority: 6
    Fault Frequency: 1
    Reset counter: 68
    Mileage: 109284 km
    Time Indication: 0
    Date: 2008.05.27
    Time: 00:00:00
    Freeze Frame:
    Fault Priority: 6
    Fault Frequency: 1
    Reset counter: 68
    Mileage: 109284 km
    Time Indication: 0
    Date: 2008.05.27
    Time: 00:00:00
    Freeze Frame:
    Fault Priority: 6
    Fault Frequency: 1
    Reset counter: 69
    Mileage: 109284 km
    Time Indication: 0
    Date: 2008.05.27
    Time: 00:01:00
    Freeze Frame:
    Fault Priority: 3
    Fault Frequency: 1
    Reset counter: 68
    Mileage: 109284 km
    Time Indication: 0
    Date: 2008.05.27
    Time: 00:58:00
    Address 19: CAN Gateway (J533) Labels: 8T0-907-468.clb
    Part No SW: 8T0 907 468 H HW: 8T0 907 468 H
    Component: GW-BEM 5CAN H06 0094
    Revision: 4GB20042 Serial number: 4200G088268151
    Coding: 000303
    VCID: 4684CE37F1B44A0E27-8012
    Subsystem 1 - Part No SW: 8K0 915 181 B HW: 8K0 915 181 B
    Component: J367-BDM H04 0150
    6 Faults Found:
    03041 - Energy Management Active
    000 - - - Intermittent
    Freeze Frame:
    Fault Status: 00100000
    Fault Priority: 7
    Fault Frequency: 29
    Reset counter: 68
    Mileage: 109284 km
    Time Indication: 0
    Date: 2014.12.22
    Time: 14:01:00
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 68
    Mileage: 109284 km
    Time Indication: 0
    Date: 2008.05.27
    Time: 00:00:01
    01332 - Door Control Module; Passenger Side (J387)
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 3
    Reset counter: 68
    Mileage: 109284 km
    Time Indication: 0
    Date: 2008.05.27
    Time: 01:39:12
    01334 - Door Control Module; Rear Right (J389)
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 2
    Reset counter: 68
    Mileage: 109284 km
    Time Indication: 0
    Date: 2008.05.27
    Time: 01:39:12
    02252 - Generator
    Freeze Frame:
    Fault Status: 01100100
    Fault Priority: 2
    Fault Frequency: 3
    Reset counter: 29
    Mileage: 109284 km
    Time Indication: 0
    Date: 2008.05.27
    Time: 00:13:21
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 3
    Reset counter: 69
    Mileage: 109284 km
    Time Indication: 0
    Date: 2008.05.27
    Time: 00:00:00
    Address 53: Parking Brake (J540) Labels: 8K0-907-801-V1.clb
    Part No SW: 8K0 907 801 E HW: 8K0 907 801 E
    Component: EPB Audi B8 H05 0060
    Revision: 00000003 Serial number: 10000000097809
    Shop #: WSC 00000 000 00000
    VCID: 316E8DEB683AFDB6E2-8064
    8 Faults Found:
    03200 - Switch for Electric Parking Brake (E538)
    011 - Open Circuit - Intermittent
    Freeze Frame:
    Fault Status: 00101011
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 69
    Time Indication: 0
    Freeze Frame:
    Voltage: 12.20 V
    Count: 38
    Hex Value: 0x0170
    Hex Value: 0x0082
    Hex Value: 0x0101
    02435 - Supply Voltage for Control Module for Right Channel
    Freeze Frame:
    Fault Priority: 1
    Fault Frequency: 1
    Reset counter: 69
    Time Indication: 0
    Freeze Frame:
    Voltage: 12.20 V
    Count: 15
    Hex Value: 0x4070
    Hex Value: 0x0082
    Hex Value: 0x0101
    02426 - Brake Disk Rear Left; Not Reached
    Freeze Frame:
    Fault Priority: 1
    Fault Frequency: 1
    Reset counter: 69
    Mileage: 109284 km
    Time Indication: 0
    Date: 2008.05.27
    Time: 05:26:55
    Freeze Frame:
    Voltage: 12.00 V
    Count: 0
    Speed: 0.0 km/h
    Hex Value: 0x0270
    Hex Value: 0x0008
    Hex Value: 0x0810
    02427 - Brake Disk Rear Right; Not Reached
    Freeze Frame:
    Fault Priority: 1
    Fault Frequency: 1
    Reset counter: 69
    Mileage: 109284 km
    Time Indication: 0
    Date: 2008.05.27
    Time: 03:50:18
    Freeze Frame:
    Voltage: 11.90 V
    Count: 1
    Speed: 0.0 km/h
    Hex Value: 0x02F3
    Hex Value: 0x0011
    Hex Value: 0x0208
    Freeze Frame:
    Fault Priority: 4
    Fault Frequency: 1
    Reset counter: 68
    Mileage: 109284 km
    Time Indication: 0
    Date: 2008.05.27
    Time: 00:00:21
    Freeze Frame:
    Voltage: 11.90 V
    Count: 66
    Speed: 0.0 km/h
    Hex Value: 0x0260
    Hex Value: 0x0001
    Hex Value: 0x0101
    02432 - Supply Voltage for Left Parking Brake Motor (V282)
    Freeze Frame:
    Fault Priority: 1
    Fault Frequency: 1
    Reset counter: 69
    Time Indication: 0
    Freeze Frame:
    Voltage: 12.20 V
    Count: 28
    Hex Value: 0x0170
    Hex Value: 0x0082
    Hex Value: 0x0101
    Freeze Frame:
    Fault Priority: 4
    Fault Frequency: 1
    Reset counter: 68
    Mileage: 109284 km
    Time Indication: 0
    Date: 2008.05.27
    Time: 00:00:21
    Freeze Frame:
    Voltage: 11.90 V
    Count: 64
    Speed: 0.0 km/h
    Hex Value: 0x0260
    Hex Value: 0x0001
    Hex Value: 0x0101
    01321 - Control Module for Airbags (J234)
    013 - Check DTC Memory - MIL ON
    Freeze Frame:
    Fault Status: 11101101
    Fault Priority: 4
    Fault Frequency: 2
    Reset counter: 28
    Mileage: 109284 km
    Time Indication: 0
    Date: 2015.01.06
    Time: 11:53:52
    Freeze Frame:
    Voltage: 9.40 V
    Count: 80
    Speed: 0.0 km/h
    Hex Value: 0x0260
    Hex Value: 0x0001
    Hex Value: 0x0101
    Sep 24 2014
    2015 Audi Q3 Quattro, 2017 Corvette M7 Grand Sport, 2017 Audi SQ5, 2019 Porsche Macan, 24 Jetta GLI
    Central NJ
    Hooking up a battery charger should not have done any damage...unless you hooked it up backwards......
    Did you let the battery charge-up for a few hours before you tried to start the engine?? Sounds more like you tried to start the car with a weak battery. If the battery can't hold a charge, after trying the charger, get a new battery.
    Feb 28 2016
    bradenton/fl/SE
    Yes charged the battery to full. Performed a battery test with a SOLAR battery tester. Passed the test (850 CCA rated - tested at 925 CCA). Not sure if I blew the ECM power use or something else with all the malfunctions on the VSDS shown.
    Veteran Member Four Rings dalmation53's Avatar
    Aug 20 2013
    Miami
    Quote Originally Posted by nstywarrior View Post
    This just happen to me it was my starter and battery went out on me. Replaced both and bam. Car starter.
    Sent from my C5306 using Tapatalk
    Ivan
    Jun 26 2009
    Bremerton WA
    The dates on the faults look odd. It has stored faults from before the battery went dead and the then went back to a zero date (2008). If the battery died while cranking it may have left the solenoid still engaged with the flywheel. I would clear codes, pull the negative battery terminal for a minute, open a door to help kill residual charge. Hook battery back up and press start without the brake to power up and have ECU initialize. Set clock and then try and start. May not do anything but at least new fault data will be easier to distinguish from stored faults.
    I don't know for sure that the ecu monitors the starter solenoid for position but looking at the fault it looks as if the short it reads may just be the solenoid stuck in the engaged position. You may have to manually rotate the engine a little to allow the solenoid spring to retract the starter shaft if it is bound against the flywheel.
    Mar 23 2014
    South Bend, IN
    Did you ever find out the issue? I have the SAME EXACT issue going on right now, and have check fuel systems and they seem to be ok! PLEASE HELP!
    Aug 18 2017
    Denmark
    I also have the same EXACT issue right now. I would love to know if you found a solution :-)
    Dec 01 2011
    if there's no crank then check your guys' starters. that's usually where it would start, all the fault codes and stuff are normal once battery is low or with similar problems like this, that's just the car shutting down and doing stuff with all those modules and they all throw codes, clear them out afterwards and they should be fine.
    IG @theshawon
