Results 1 to 4 of 4
    Jan 11 2012
    07 LBZ Duramax, B8.5 S4 6MT, 05 RC51
    Nashua, NH
    Odd occurence, need some input
    Just had one of my power steering lines go the other day, and then resulted in a no start condition, which seems odd to me.
    Put in the remaining fluid that I had for it in, and waited overnight, it fired up normally for 3-4 seconds and died as the fluid spilled out.
    Only ECU code was for a motor mount and a couple lean codes. I'm stock tuned with JHM Piggies and FI non res exhaust. Immo is working, FP is as well, plugs, battery, starter and ignition all good.
    Can anyone shed some light on that??
    b8.5 S4 PP 6MT || CF Inlays || Alcantara || Sport Diff || Roc - Euro || AWE Non-Res Dp + STaSIS Challenge || CR15 || 034 Inserts (Trans/Diff/Subframe)
    b6 04 S4 6MT || Daily || VMR 705 || Nitto || JHM Piggies || Fast Intentions || - Sold
    b6 A4 Sport 6MT || AMB / AEB || IE || JE || GT28R || AWE Tune || 480cc || R8 Coils || RS4 Clutch || Billy Boat || Podi || - Sold
    Veteran Member Four Rings Lucca M's Avatar
    Jan 17 2014
    Past Bmw M3 coupe Euro 1998
    New Jersey
    Do you hear fuel pump priming?
    2004 Black RS FAUX B6
    JHM LWFW, Stage 4 Clutch, Short Throw Trio, IM Spacers, JHM 91,
    034 Street Density Engine, Transmission, Snub Mount & Zero Tolerance Bracket, Rear Diff Inserts,
    PowerFlex Diff insert, Custom 2.75'' Akropovic exhaust, Cross Drilled/Slotted Rotors,
    Rns-E, B7 steering wheel, Schmidt VN Line 3 piece 19x10, Airlift Performance Suspension, Recaro Sport Seats, Ecodes and many many more...
    Insta: luccamentone
    Apr 18 2012
    1995 Toyota Land Cruiser (FJ80/FZJ80)
    Central Texas
    that is odd, beacuse i has a PS hose go (reservoir return) and managed to get off the freeway with only burly steering strength required. the lean code is the thing that sticks out; there could be something like an intermittently shorting O2 sensor wire, but i'd expect some other codes to come with that.
    - emilio
    Jan 11 2012
    Nashua, NH
    Quote Originally Posted by Lucca M View Post
    i did
