Results 1 to 9 of 9
Thread: Failing shocks
    Oct 11 2007
    Suburbia
    Failing shocks
    I've had 3 PPI's done on R8's, all had less than 20K miles on them, and all 3 needed at least 2 of the 4 shocks replaced, with one needing all 4 (@12K miles).
    Have any of you owners experienced such things? I can't believe the shock failure is so common, and at such low miles. Any insight would be appreciated!
    Thanks.
    12' R8 Daytona/CF V10 6MT
    ~VF750 supercharged~Avior Ti non-res~GT coilovers~Girodiscs~Wingbacks~CF S-wheel~Maxton Aero bits~
    07' RS4 Daytona/Panda
    ~Jackal tune~Zinram 70mm DPs~JHM res catback~Custom CAI~Bilstein PSS9s~Girodiscs~JHM shifter~
    Established Member Two Rings fasttoys's Avatar
    Mar 19 2011
    Audi R8 V8 & Z06,14 Q5,13 M5
    Dallas Tx USA
    Common issue talked on Audi Forums. Many options to replace them with OEM Euro set up & GT Non mag ride which have a lower cost. Mag shocks for all 4 will cost you 5200. Then you need to install them or find someone to do it. If you are buying a pre-owned R8 use these issues in your negotiation to reduce the price.
    Oct 11 2007
    Suburbia
    I actually walked away, I'd just rather not throw extra money at car I haven't even bought yet. Parts seem to be more around 6500 + install. Any information on the Euro or GT setups?
    Veteran Member Four Rings FastEddie's Avatar
    Apr 01 2012
    Queens
    At that price would switching to KW V3 or Ohlins coilovers be more beneficial or is the mag ride that good?
    SUSPENSION-KW V3-Hotchkiss RS4 sway bars-034 Adj UCA-034 strut mount-034 F&R end links-034 motor mounts-034 Snub mount W/bracket-034 Trans mount l BRAKES-ECS Stage 4 BBK-ECS rear rotors & lines, Hawk pads l Engine-JHM Tune-JHM 6 rib pulley-Milltek catless DP's-FI exhaust l EXTERIOR-RS4 black grille-Custom headlights-LED city & DRL lights-ECS LED tail lights & plate lights l INTERIOR-Custom steering wheel-SRP pedals-ECS LED lights-MOMO shift knob-Gen 2 RNSE & AMI l WHEELS-OEM RS4 W/ Michelin PSS
    Oct 11 2007
    Suburbia
    I just wanted a stock car, I would not be opposed to throwing in coils eventually, but even then I'd drop some serious coin on a good setup just after the initial purchase....
    Apr 01 2012
    Queens
    Quote Originally Posted by WinterRunner View Post
    Totally understandable. Im just figuring if you were to lets say find one with leaking mag shocks, negotiate about 5k off price then buy Ohlins TTX or KW V3 and install. yes its a pain but at least you would now have fully adj coilovers.
    Oct 11 2007
    Suburbia
    Oh I tried, they wanted to take 2K off, that's barely covering 1 shock. For sure, sound points, thanks guys!
    Veteran Member Four Rings scott1961's Avatar
    Dec 18 2007
    Boston
    The other thing to look for is ac issues, very high fail rate in the R8's and it's a 5k+ fix. Mine went a couple months ago but luckily just before warranty expired. My car is a 2012 with 23k miles and have only had one shock replaced, wasnt the leaking issue was an electrical problem with it. What model and year you looking for? Mine might be going up for sale soon.
    2021 Turbo Blue RS5 Coupe
    2022 Blue Lamborghini Huracan Evo AWD Coupe
    Gone
    2020 Blue Lamborghini Huracan Evo Spyder
    2019 Blue Ferrari 488
    2015 Blue Lamborghini Huracan LP610 VF-800 Supercharged
    2012 Red R8 V10 6sp manual, VF-750 Supercharged
    2009 Silver R8 V8 6sp manual VF Supercharged
    2008 Black RS4 Cab
    2007 Black S4 Cab
    Oct 11 2007
    Suburbia
    Hi Scott, met you a few times at various events, always a showstopper! Anyways I am finalizing a 09 4.2 as I type. Yours may be a bit out of my range to be fair. What is the most active R8 forum, this is kind of slow. Thanks!
