Results 1 to 2 of 2
    Veteran Member Three Rings IHave2Turbos's Avatar
    Aug 17 2015
    DIY - B8 A4 HPFP Cam Follower
    EDIT: It seems as though we have the roller type cam follower in our EA888 motor so there should be no wear or tapping from this part at all. It seems this is a non-issue for us.
    I am getting a pretty loud clicking noise from this general region and not sure if it is the HPFP, the Cam Follower, the purge valve or the intake flaps.
    I found this awesome writeup for a B7 A4: http://freepdfhosting.com/8791e81dac.pdf
    The kit I was looking at to perform this job is: https://www.ecstuning.com/Audi-B8_A4...ump/ES2766041/
    I wanted to know if anyone has tackled this on the B8 specifically (MY 2010) and if so, are these instructions accurate?
    C7.5 S6
    Mods : OEM+ Stage3 / DS1 ECU / SRM TCU / CTS HX
    B8 A4
    Mods : HPA\\\ K04 / Manifold / HFC / Tune | CTS FMIC / DP | CR-15 | ECS Inserts
    Retrofits: MMI3G+ / RVC / AHH / Color DIS / Cruise Stalks
    Veteran Member Four Rings Zach L's Avatar
    Feb 24 2010
    Austin, TX
    I have replaced the cam follower on FSI (B7) engines a handful of times. Those instructions will not work as the FSI and TSI engine use a completely different HPFP design.
    It shouldn't be too complicated though. Just be sure to have access to the proper torque specs for anything you remove.
    Daily Driver: B8 A4 quattro 6MT, Aruba Blue on Black, Premium Plus, Sport Package, Bang & Olufsen
    Current Projects: 2006 Cayman S 6MT • 2006 VW GTI 2.0T 6MT • 1997 VW Golf • 1982 VW Rabbit Diesel • 1972 VW Bay Window Bus
