Results 1 to 30 of 30
    Veteran Member Four Rings Djpeaksd's Avatar
    Feb 01 2016
    Encinitas, CA
    VR Tuned S7 Tuning box Install and inside car pulls
    Ok so I have been able to experiment a little bit with octane levels and tuning box settings. I am also experimenting with different mounting positions in the car so this is all a work in progress. I found that on 91 octane settings 3 and 4 are ideal for my car and 95 octane setting 4 and 5. I wanted to at least put something out so I was able to shoot some video last night and put this together this morning. I also tried to do launch control and push the lap timer start button at the same time but I did hit the button pretty early.
    https://www.youtube.com/watch?v=gho6-ghLHaU
    2021 RS7 Sportback Nardo Grey - Vossen HF3's satin black, lowered via ODIS
    Senior Member Three Rings luv2sleep's Avatar
    Jun 12 2012
    Good looking S7! Thanks for the video. I'll be watching for some numbers.
    Jun 07 2016
    Europe
    Quote Originally Posted by Djpeaksd View Post
    Ok so I have been able to experiment a little bit with octane levels and tuning box settings. I am also experimenting with different mounting positions in the car so this is all a work in progress. I found that on 91 octane settings 3 and 4 are ideal for my car and 95 octane setting 4 and 5. I wanted to at least put something out so I was able to edit some video late last night and put this together this morning. I also tried to do launch control and push the lap timer start button at the same time but I did hit the button pretty early.
    0-60 times?
    Feb 01 2016
    Encinitas, CA
    Quote Originally Posted by luv2sleep View Post
    Thanks Luv! Im thinking I should get a Vbox to get more concrete times and such.
    Feb 01 2016
    Encinitas, CA
    Quote Originally Posted by Logtec View Post
    0-60 times?
    With the lap timer I had it at 4.0 seconds but this is very rough and not very scientific, hahaha. Trying to launch the car, make sure Im recording and push the lap timer button at the same time all while being on a public street.
    Jun 02 2012
    CO
    And tired from the drive to Mexico to accomplish all of this of course..
    2021 Audi RS6 Nardo, CCB, Carbon Fiber package, Red Star Resonator Delete, IE Intake, IE Stage 1, Euro cup holder
    2020 Audi SQ7 Daytona Gray Pearl,
    Gone:
    2012 S4 Brilliant Black
    2016 S6, Daytona Gray Pearl
    2014 SQ5 Moonlight Blue
    Feb 01 2016
    Encinitas, CA
    So went through the raw footage many times on the run I used launch control. I keep coming up with 3.86 0-60. Not sure what our car is suppose to do stock but that seems pretty fast. I thought I remember Audi advertising 3.9 a while ago for the S6.
    Established Member Two Rings dogears's Avatar
    Sep 05 2014
    Thanks! Not the most scientific. A tenth here and there, hard to tell with video. Would be interesting to run with the VR and then run it with the "stock" plug. See the delta.....
    2016 Daytona Gray S6 w/ Arras Red Designer Interior, Sport Package, Black Optics, Bang and Olufson, Driver Assist, Night Vision, and Cold Weather.
    Feb 01 2016
    Encinitas, CA
    Quote Originally Posted by dogears View Post
    Hahaha, yes not to scientific at all but I said from the very beginning that I would do my best to gather info on this unit but at the end of the day Im just a swinging di** on a forum. I can tell though that it pulls harder than stock for sure. Good thinking I might actually put it back to stock and do a couple pulls.
    Sep 05 2014
    Indeed. I'll suggest that to the person I know with one too. Compare notes.....
    Jan 27 2016
    '14 QX80, '12 FJ Cruiser (Heavily modded)
    Denver
    I see you have the laptimer, so do you have VCDS/VAGCOM? If so, it will measure 0-60 and quarter for you.
    Feb 01 2016
    Encinitas, CA
    Quote Originally Posted by jfeger View Post
    @verybadman helped me with Vag-com. So I don't personally have the cable. So Vag will record times not the lap timer?
    Sep 28 2009
    suburb
    I am getting one and will report back once I get it. \
    Audi S7 stage 3 w/srm turbos
    Audi B8 S5 stage 3 w/apr supercharger
    Audi SQ7
    Audi Q5 3.0 EPL stage 2 single pulley (gone)
    Audi Allroad 2.7 stage 3 (gone)
    Audi B5 S4 stage 3 (regrettably gone)
    Audi B8 S5 (gone)
    Sep 05 2014
    I need to VAGCOM my car. I want the extended HUD data that laptimer gives you. Any other suggestions DJ?
    Jan 27 2016
    Denver
    Correct. There is a screen for acceleration. You start the sequence, and when it detects the vehicle starting to move the timer starts. It uses the data from the OBD port, so it should be more accurate than hitting the lap timer button
    Feb 01 2016
    Encinitas, CA
    I did lap timer, lowering 17 mms, seat belt chime, and then one touch hatch close from remote.
    Sent from my SM-G925T using Tapatalk
    Veteran Member Three Rings lv2000's Avatar
    Dec 05 2004
    Current. 2018 s6 prestige Past-997 turbo/ Audi S7 /13 A6 /b8 s4 /b8.5 s4 /b6 s4
    Las Vegas
    Fj peaks dis the tune that much of a gain ? I am going to probably keep my s7 And tune it I only have 22k miles but car has been solid And its 3 years old in August so if it gets flagged it's only a year I loose. But I want Apr but for 500 bucks this looks very enticing
    Jun 12 2012
    Quote Originally Posted by lv2000 View Post
    It's more than double your "$500" figure. Just a fyi.
    Yeah guys...I'd love to see some real 0-60 and 1/4 mile times. Thanks ya'll for doing this!
    Sep 28 2009
    suburb
    i'm not worried about flag with this. and honestly if i have issues, i might as well stress my engine a little more during warranty and if something pops up, remove it and get it serviced :)
    Audi SQ7
    Audi B8 S5 (gone)
    Feb 01 2016
    Encinitas, CA
    Oh one more I forgot to mention. If you are going to get the Tag Motorsports color matched front reflectors, (Makes a huge difference in looks) Then disable the orange reflector light through VAG as well.
    Jun 02 2016
    Nice! I can't wait to see some hard track and dyno numbers from someone. I'm definitely ready to pull the trigger but that price is insane. the only reason I haven't tuned is because of TD1
    Veteran Member Four Rings MadAboutCars's Avatar
    Aug 27 2015
    MY18 Audi RS6 P, MY18 Audi SQ5,MY16 Audi S6 (sold), MY12 Audi Q7 4.2L TDI S-line (sold)
    New Zealand
    You swapped the boost sensor leads?' So now the waste gate is being controlled by the oposite turbos pressure? This sounds like a recipe for disaster. Have you checked with VR tuning to see what they say.
    2018 Audi RS6 Performance - Floret Silver, Titanium styling package, 21" titanium 5 V spoke wheels, Dunlop SP Sport Maxx GT 285/30/21, Black sports seats, Carbon inlays, Sports diff, Sport exhaust, Matrix LED headlights, 360 camera, Head up display, Active lane/side assist with adaptive cruise control, Park assist, Privacy glass, Electric tailgate with foot open
    Mods: Dura-Seal exterior/interior, Audi Sport door lights
    Feb 01 2016
    Encinitas, CA
    Quote Originally Posted by MadAboutCars View Post
    When you are looking at the engine their diagram showed the left boost sensor as sensor 1 and the right as sensor 2. There was no way the loom would stretch that far. So what I did was put their sensor #1 on the right and vice versa. I checked with Adam and he said it didn't matter since it's just reading boost pressure. I figured the loom was just labeled wrong because it stretched perfectly the way I put it on. But now you have me worried!!!!
    Thank you so much for the awesome video review! I just got to take a look at it today for the first time and looks like she is pulling super hard :)
    Jun 02 2016
    This seems awesome. I just bought the Racechip Ultimate and I'm wondering if the price more than doubling is worth it.
    Established Member Two Rings IbisB8.5S4's Avatar
    Sep 09 2015
    2015 Tahoe LTZ, 2008 Silverado
    Mount Vernon, WA
    online says 0-60 for an S7 is 3.9
    http://www.caranddriver.com/audi/s7
    Owner/Operator at Big Al's Detail Garage
    www.bigalsdetailgarage.com
    www.facebook.com/bigalsdetailgarage
    Feb 01 2016
    Encinitas, CA
    Quote Originally Posted by IbisB8.5S4 View Post
    I seem to remember car and Driver always getting amazing zero to 60 times that are very tough to replicate. I thought S7 was 4.3 seconds published by others but not sure.
    Feb 01 2016
    Encinitas, CA
    Quote Originally Posted by TheMajesticKing View Post
    How is racechip been for you? Is it a significant upgrade?
    Jun 02 2016
    My car is in the shop for an air suspension fault. I haven't had a chance to install it yet. I'll keep you guys posted.
    Can't wait! Sorry to hear it's in the shop!
