Results 1 to 3 of 3
    Junior Member Two Rings
    Sep 06 2015
    Nassau County
    Why do B8.5's make more power the B8 stock and modded?
    On APR's site, both with the K04 kit on 93oct the B8.5 makes significantly more TQ. Any reason for this?
    Veteran Member Four Rings Zach L's Avatar
    Feb 24 2010
    Austin, TX
    Quote Originally Posted by S4orceAudi View Post
    In the US, they use similar, but slightly different engines. Very similar hardware wise (they are both EA888 Gen 2 engines) but the engine calibration is different. They both use the Bosch MED17 engine management, but the fuel system in the B8.5 is slightly different (usually allowing for E85 fuel) and so the engine calibration is different to accommodate the newer fuel system. B8 engine code is CAEB. B8.5 engine code is CPMA.
    The B8.5 doesn't always make more power. The B8 engine produces more power in Stage 2 on APR's site. But remember, those are only peak numbers. The curve of the power/torque matters just as much.
    Outside the US, there is much more difference between the B8 and B8.5 engines used in each car. B8 is a Gen 2 engine and the B8.5 is a Gen 3 engine using Simos ECU, similar to Mk7 GTI and 8v A3. The Gen 3 engine is far superior.
    Daily Driver: B8 A4 quattro 6MT, Aruba Blue on Black, Premium Plus, Sport Package, Bang & Olufsen
    Current Projects: 2006 Cayman S 6MT • 2006 VW GTI 2.0T 6MT • 1997 VW Golf • 1982 VW Rabbit Diesel • 1972 VW Bay Window Bus
    Sep 06 2015
    Nassau County
    Thanks! That explains it.
