Results 1 to 8 of 8
    Apr 12 2014
    Fort Myers Fl
    Noob exhaust question
    B8.5 S4 and I currently have a Borla cat back exhaust. I'd like to add downpipes without cats (ideally)
    I was looking at the AWE downpipes (with cats) but they have a 6 week lead time.
    I found a 034 Motorsport test pipe in the classifieds. Would that do the same thing I'm trying to accomplish?
    May 12 2016
    S4 2012 6MT
    Montreal, Canada
    I think the test pipe is replacing the cats, so if you want to keep them, you have to install downpipes.. As for the wait, why don't you just go custom?
    Dec 03 2008
    2018 SQ5
    Castle Rock, Colorado
    Doesn't JHM make test pipes for this?
    2021 Audi S4, P34 Intake
    Apr 12 2014
    Fort Myers Fl
    Is there a large performance advantage for deleting the cats? It will all be getting done at the same time as going to EPL stage two dual pully. I guess, is it worth the labor and cost to do test pipes versus downpipes?
    May 12 2016
    S4 2012 6MT
    Montreal, Canada
    If you want a real gain, do test pipes, downpipes and a complete exhaust line to the back. Remove alllll the restriction.
    Jan 14 2009
    2014 S4 2014 GLK Diesel. 06 Jetta TDI
    pasadena md
    Doing down pipes is easy. Doing test pipes are a PITA from what I read you have to lower the subframe to get them out. The "downpipes" just have resonaters in them not cat's.
    Dec 03 2008
    2018 SQ5
    And don't forget the fact that you will fail emissions in many states without cats.
    Veteran Member Three Rings brainpan's Avatar
    Apr 11 2010
    sk8 banana
    ontario
    Borla exhaust already comes with non resonated down pipes, its a full cat-back system. You're looking for test pipes or high flow cats. I was quoted 5-6 hrs labour to replace my cats at an indy shop.
    There was some early controversy around the 034 test pipes around lack of performance and throwing codes.
    Jhm offers high flow cats and test pipes but not much info out there on em.
    Sent from my Note 5
    Bryan
