Results 1 to 13 of 13
    Senior Member Two Rings Poopcorn's Avatar
    Nov 18 2014
    Calgary/AB/Cansda
    2.7 Swap wiring question
    Hi guys, I'm doing 2.7 swap right now.
    The swap is at wiring part now. I used the wire harness that made from clint.
    All the connectors have a place to go except those blue and tan colors...
    Anyone has any idea what are those two connectors for?
    Thank you
    [IMG][/IMG]
    Apr 19 2014
    F80 M3, B6 S4 Avant 2.7t swapped
    Southern Maryland
    Relays go there, do you still have them from the old harness
    Nov 18 2014
    Calgary/AB/Cansda
    Quote Originally Posted by fernandj View Post
    Thanks for the reply..
    Which relay??
    Apr 19 2014
    Southern Maryland
    one relay will have 273 i think written on it i don't know about the other cause i do not have it, which maybe why my car won't start
    Nov 18 2014
    Calgary/AB/Cansda
    I dont have any relay to put in...
    Oct 23 2010
    2004 Atlas Gray A4 Avant
    Cranberry TWP, PA
    The little one is the starter relay, the larger one marked 219 is the ECU power relay. I'm assuming Clint reuses the 219 to supply the ECU and injector supply line with his harness.
    2004 Atlas Gray B6 Avant, built 2.7T w/ BB K24's on E85
    2005 Touareg 4.2 gas guzzling daily
    2002 Triumph Daytona 955i
    1997 BMW M3 Coupe (sold, sad reacts only)
    Nov 18 2014
    Calgary/AB/Cansda
    Quote Originally Posted by Steve Bassen View Post
    So which one is the small one? The blue one? Or the tan color one? And should I use the relay from 2.7 engine or replays from b6 chassis?
    Oct 23 2010
    Cranberry TWP, PA
    Blue one
    Nov 18 2014
    Calgary/AB/Cansda
    Blue one
    COOL, so the blue one is relay 395 and tan one is 219 or 373?
    Oct 23 2010
    Cranberry TWP, PA
    What's Clint say? From a pic of one of his old swap harnesses, it looks like he's got the black 219 relay in it...
    Nov 18 2014
    Calgary/AB/Cansda
    Yea they are suppose with the relays... I didn't have them on the original engine harness when sent it to Clint, so that's why I'm missing it. Anyways thx guys for the info. Problem solved :)
    Oct 29 2005
    10speed
    San Francisco, CA
    395 and 373
    - Clint
    May 18 2008
    Edmonton/AB
    395 doesn't work in this blue plug
    [IMG][/IMG]
