Results 1 to 4 of 4
    Jan 14 2009
    2014 S4 2014 GLK Diesel. 06 Jetta TDI
    pasadena md
    Factory Car cover?
    Hey any of you guys have the Audi OEM outdoor car cover? Have any of you guys tried to wash it yourself with your washer or have you taken it to a dry cleaners or a laundrymat? I need to clean mine. Not sure how to go about it.
    Veteran Member Three Rings StealthBlackA4's Avatar
    Aug 23 2012
    2012 Porsche Carrera 4S
    Erie, PA
    I'm sorry as this is no help to you since yours is an outdoor cover and mine is a soft indoor cover. I just throw mine in the washer on delicate with a little soap (no softener) and let it get clean. Then throw it in the dryer on low heat until it dries. Again, this is for the indoor cover. Not sure if this would help with yours.
    Established Member Two Rings kcobourn's Avatar
    Jan 04 2013
    2008 Acura MDX
    United States
    OP has the cover ever scratched your paint?? Any issues with mildew / mold from moisture?
    B8 P+ Ti 6MT, APR Stage 2, Alpha Cooling, EuroCode TRUfit, AWE Touring, H&R OE / R Sway, Bilstein B8s, CR-15, JHM SS, Q5 Brembos, ECS two-piece rotors / SS lines, 034 Trans / ECS diff mounts, ECS 8mm(f)/10mm(r)
    Jan 14 2009
    pasadena md
    Quote Originally Posted by kcobourn View Post
    Nope the factory cover has been great. If the cover is wet i leave it on the car till it dries or lay it out to dry it if its not on the car. If you put it away wet it will mold and mildew. I never had any issues with scratching the paint. I like it because its fitted
