Ive done research at nauseam for about 9 months. Hell I’ve also seen a couple guys with similar issues lately (@danaldson, @hemantpd1). But I feel like I’ve gone through the entire checklist of possible scenarios here, so its time to ask for some help.
The Car:
07 2.0 Avant (tip). 81k
The (short) backstory:
About a year ago I had my tune installed (GIAC). About a month later I started noticing some pre-detonation, and I was adding a quart about every 900 miles on average. Did my timing about 6 months ago and noticed a CRAZY amount of oil coming out of the IC piping. Ever since then I've been trying to find the source of it. At WOT I will get some hesitation. If I'm really gunning it at low RPM, I will usually get some knock as it builds boost. The car runs perfectly otherwise.
My theory:
The large amounts of oil in my IC piping is being sucked through the intake, causing hesitation, smoke, and ultimately pre-detonation/knock.
Things I've replaced over the past year:
MAF
Coil packs
Plugs every 3k (NGK coppers)
Entire PCV system
VC+VCG
Switched over to a BSH Catch Can
TURBO
Am I missing something major? Im sure I left something out - its a lot to remember. Im confident that the pre-detonation is due to the oil being sucked through. Just need to figure out how the hell the oil is making it in there.
