Figure out this noise and you're top dog ! Audi tech have looked and watched the video and the response so far "WTF" 2012 Audi S4 3.0T, Customer states that immediately following an oil change , a clattering noise was heard. The noise is consistent and does not change pitch with rpm increase. The customer drove the vehicle approximately 50 miles after this incident. The vehicle was taken to a shop in the community near us where a partial disassembly was performed (rear upper chain covers) to expose the upper timing chain tensioners. The findings were- missing and broken chain guide pieces for bank 2 cam chain. The noise described was not commensurate with a chain scraping on a guide, therefor it was assumed to be a collapsed hydraulic tensioner. The vehicle was brought to our shop where the transaxle and rear timing chain cover were removed. There was no obvious damage however on disassembly inspection of the timing chains, the bank 2 exh cam sprocket was found to have several indentations where the chain had been pressed into it. The suspect was the detached chain guide pice (plastic) which may have wedged in between the chain and the sprocket for several revolutions before falling into the oil sump.
Both bank 1 and 2 upper hydraulic chain tensioners were replace, bank 2 exh cam sprocket and upper chain + lower chain hydraulic tensioner were replaced. Balance shaft spun freely and noise free when opreated via high rpm drill. After completing the work the transaxle was reinstalled and the engine started...SURPRISE ! , Noise still there . Transaxle back out + engine started w/o transaxle in place to observe. See Video ... yes ... WTF ?
