If you're dialing down to H&R springs are you also installing new dampers ? You'll eventually blow the oem dampers since they will be strained by being compressed, being unable to work as designed within their range.
I was looking at TT wheels a couple years ago but because of their 52 offset, I didn't see how they would work without complications and anything over a 5-10mm spacer was a no-go. still needed at least 15 to 18mm spacer to achieve the offset i wanted. I would prefer not to use spacers.
In the end it is worth it to get the right wheels with correct offset so you can run a square set up as in a 245-255-265 with a 35 or 40 profile on an 8.5 or 9" wheel. I also think an 18" is a better and is available in a wider range of width sizes than 19".. TSW, BBS, AG and HRE all make wheels that won't leave you guessing.
I do like the OEM look but our B6's are not easy to fit considering the wheel wells have a much narrower space allotment than more recent Audi's..
