Results 1 to 11 of 11
    Sep 05 2013
    Ottawa, Ontario
    Can't pass readiness / Do I need a new tune?
    So my e-test is coming up in september and my car can't seem to pass readiness. I think ever since I've installed my HFC and downpipe my car hasn't passed readiness. I bought this car with the APR tune, K04 and injector combo already on the car 3 years ago and have since then installed the HFC, DP, Exhaust and front mount intercooler. Do you usually need to re-tune the car when adding these parts in?
    Thanks again
    Senior Member Three Rings crazyquik22023's Avatar
    Jan 30 2012
    Brunswick, Ohio
    The Cat and O2 sensor readiness could be caused by your HFC. You can install a spacer on the rear o2 sensor and it might pass. The "Air" readiness is a problem with the secondary air system. This has nothing to do with the HFC or downpipe you installed.
    Apr 15 2014
    Ottawa/Gatineau Canada
    Quote Originally Posted by crazyquik22023 View Post
    Spacer and also 034 makes a spacer with a mini cat inside it ;)
    2004 A4 Avant Quattro. (H&R springs, S100 Nav unit, Neuspeed Cat back, Torque solutions Snub mount, Thor Skid Plate, APR Stage 1, 18" S4 Rims, 2X Podi / Oil Press / Oil Temp / Boost/VAC, Full LED interior, Backup Camera/Screen, Upgraded 2.0 Coil Packs, Vag-Com, B7 Center console/B7 Hand Brake, B7 Aero wiper arms B7 rear headreasts,APR Carbonio intake, Fan washer sprayers,
    2014 VW Tiguan. (bone stock)
    Veteran Member Four Rings Furly's Avatar
    Dec 19 2013
    The spacer hardly ever works. Good luck
    Audi Club Bay Area
    Veteran Member Four Rings MurkyRivers_A4's Avatar
    Dec 17 2009
    Tools, boxes of random car parts, 55 gal drum of used oil
    Kentucky
    Quote Originally Posted by Furly View Post
    Car done yet? :)
    2015 Daytona Grey Audi S4 | DSG
    2013 Ibis White Audi A4 | Tip
    2006 Brilliant Black A4 Titanium | 6 speed
    Dec 19 2013
    Quote Originally Posted by MurkyRivers_A4 View Post
    Car done yet? :)
    Is you finished or is you dun?
    Audi Club Bay Area
    Dec 17 2009
    Kentucky
    Whoah, hey. If you gonna do that I want some respeck
    Dec 19 2013
    Well maybe if you put some respek on it, I might be finish.
    Audi Club Bay Area
    Sep 05 2013
    Ottawa, Ontario
    Thanks for the information. I'll try the spacer. Wouldn't that make it have less of a reading since it wouldn't be sitting as deep inside the dp? Sorry for my newbieness.
    The secondary air system makes sense since I've deleted it and put a resistor in place. No cel though
    Apr 15 2014
    are you getting the spacer or the spacer with the small cat inside it?
    Sep 05 2013
    Ottawa, Ontario
    Quote Originally Posted by Luxus Panzer View Post
    I'm not sure, Which one is best recommended? If my Cat and 02 readiness can pass then I can still pass my emission test with only the air readiness not completed.
    My SAI is deleted with a resistor in place whit no CEL, but what is it that makes this part of the test pass? Is it the N112 that gives the signal to pass or is it the primary 02 sensor? I thought since I have the 3 inch HFC there would be enough air flow to ''trick'' my system to think the SAI is still sending air to the cat.
    Sorry for all the questions, I'm just trying make sense of all of this.
