Results 1 to 6 of 6
    Feb 20 2010
    TT225, Touareg, Tiguan, TDI, A3, RS6, Jetta
    Brighton, MI
    C5 door hinge bolt - INSIDE one
    On my car, the bolt that goes into the hinge FROM THE INSIDE is loose on the front driver side door.
    This allows the hinge to move and door hanging too low (scraping on sill, riding up on the lock catch plate).
    How can I access and tighten the INSIDE bolt?
    Does not seem that I can get to it with the driver kick panel removed.
    Suggestions? Tips? Links?
    01 Allroad Tiptronic, TCU tune, mild stg 3 (350 HP) tune (stock injectors) KraftwerkTurbo TM1. Lower, Wider. Custom tip vent pod with Podi
    02 Allroad 6 spd, Kraftwerk Turbo TM6, 750cc, 3" MAF, piggy, FMIC, CM stg 5 (hate). 30 psi at 3600 rpm. Needs stronger rods (coming).
    05 Golf TDI
    Looking for 2001 A4 1.8T quattro manual with blown motor
    www.regulatorfix.com
    www.kraftwerkturbo.com
    You would probably have to remove the wheel then the wheel liner
    Using Tapatalk
    Veteran Member Three Rings Sparkstack's Avatar
    Oct 13 2012
    Bits of a 2003 S6, 1990 turbo Miata, 1996 LS400
    Naperville, IL
    It's got to be accessible from the inside. As its not accessible from the wheel well. Passenger side pic for reference:
    2002 S8 - Daily driver.
    2003 S6 - R.I.P. (parting out - PM me if you need anything)
    1996 LS400 - Wife's whip. Thing is bullet proof.
    1990 Miata with FM Turbo - Pocket rocket.
    Feb 20 2010
    Brighton, MI
    Quote Originally Posted by Sparkstack View Post
    Thx.
    Wonder how much have to be removed to get to this bolt if inside, under (top corner) of the dash?
    05 Golf TDI
    Veteran Member Three Rings JediJoker7169's Avatar
    Dec 11 2009
    PDX, OR/SF Bay Area, CA - USA
    My driver's door sags, too, but it doesn't scrape (yet) and I haven't bothered to diagnose what's causing it. Guess I should look into this bolt...
    - JediJoker
    "Dieselgate" / 2011 VW Jetta SportWagen TDI 6-speed
    FORMER: "Das Boot" / 2001 Audi A6 2.7T quattro sedan:
    RS4 clutch / 710N DVs / 2Bennett Stage2 GT front 6-piston Brembo 350mm/rear 311mm / Bilstein PSS9 / Hotchkis Sport anti-roll bars / 034 Density adjustable front UCAs/Track Density front shock mounts/spherical ARB end links / O.Z. Superturismo LM 18" x 8" / Hella E-codes / LED tails / Facelift rear license plate trim
    Oct 30 2009
    Miami, FL
    It should be accessible once you move all the wiring out of the way. If it's anything like the b5 there will be an access hole in the inner sheet metal, get in there with a flashlight and have a good look.
    Sent from my MI 5 using Tapatalk
    2018 S5 Coupe - stock for now
