Results 1 to 38 of 38
    Registered Member Three Rings seanriv's Avatar
    Jan 07 2008
    2001 Audi Allroad, 2015 Mini Cooper
    San Francisco,CA
    Born Again Allroad Project
    Heyo! Been meaning to put this together since I have brought this allroad back from the dead and it is better than ever!
    The timing belt decided to snap, which was a big surprise since it was supposed to be good for at least another 40k but oh well... James down at Sprint Auto Works had an allroad and I ended up shooting his car for Audizine and thats when I started the hunt to find one. His olympic blue is basically a carbon copy of what my allroad is now and I actually have a lot of parts from his since he is going stage 3+ plus right now so its down for a while. More on that later...
    The day it died... I thought it was going to the junker but James convinced me and promised it would be an entirely NEW car when I got it back.
    Then I was talked into this. 01E 6 Speed Swap. These boots are a pain in the ass to find... The trim plate is even harder.
    That belt sure looks old... (VIDEO)
    Out with the old.
    Rebuilt heads from the timing belt failure.
    034 Flywheel with RS4 Clutch. Bunch of 034 hoses, secondary air pump block off plates. Also installed 034's new track solid motor and trans mounts.
    Rebuilt 01E Trans with new syncros. Also have the JHM/034 shifter and delrin knob, super nice.
    The 034 catless downpipes before I put in James setup since they didnt line up right. Btw, not 034's fault, this shit is niche and just how it goes. Originally was going with 034 catless downpipes but since they are specifically made for the S4 they did not line up to mate with the stock exhaust. But I ended up going full custom anyways and James had 034 downpipes with cats which was the better choice anyways.
    I ended up taking James system which was custom built by Rick from Synergy Motorsports, system is a work of art and sounds incredible!
    Fixed cluster screen!
    All back together! Btw, car does not have a check engine light or any other dash warning! I thought this would be impossible, but he said he could make it happen.
    (VIDEO)
    (VIDEO)
    Audio sample, gonna have some better footage/audio soon. (VIDEO)
    James also has a Sprint Auto Works/Because Bags Suspension kit that is direct plug and play with the oem management system, no longer feels like a couch in the corners!
    Polished the headlights, so worth it! Also removed the amber.
    Upgraded DV's, stock ones just couldnt hold the APR tunes boost.
    Using it! Gotta figure out the exterior, paint is shit... Thankful the interior is SUPER clean. Hope to have more up soon on the car, still having a blast with the APR tuning. James and crew at Sprint Auto did a killer job on this and treated my car as there own. Zero short cuts taken and only the best parts used. I know Luke at Sprint did a lot of the work on it, doesnt look like a fun car to work on. HAHA. Ill gladly always bring my cars from San Francisco to San Jose to make sure its done right the first time.
    Veteran Member Four Rings SteelyS6's Avatar
    Oct 29 2011
    Winnipeg Manitoba
    Thumbs up, nice to see it brought back to life and being used! Exhaust is beautiful!
    May 22 2010
    N.E. Connecticut
    Nice, body wise, any thoughts on color matching bumpers and fenders when repainting ??
    May 20 2010
    Nice!
    Find it funny you've covered up your license plate in some pics, but not in others. I typically find doing it isn't going to help you much unless you've pissed off the crazy dude at the DMV
    Jan 07 2008
    San Francisco,CA
    Haha, I uploaded the pics randomly the past few months so I forgot to do some. Oh well...
    Jan 07 2008
    San Francisco,CA
    I actually think I would do the entire body one color if I repaint. But maybe a wrap before, good paint is really expensive. I would probably do a color change so that makes it more expensive.
    Veteran Member Three Rings JTown77's Avatar
    Feb 01 2010
    2002 S6 red, 2003 2.7 allroad stage II blue, 2005 4.2 allroad silver, 2003 FLHRCI
    Charlotte N.C.
    Very nice ride there!
    I have a rosstech vcds HEX-USB+CAN Interface and cam lock bar to rent with deposit in the Charlotte area. Like all C5 owners I am looking for local parts!
    Jan 07 2008
    San Francisco,CA
    Running healthy after an upgraded fuel pump!
    Junior Member Two Rings
    Mar 23 2016
    Look great, I have one question, why did you install the DVs like that?
    Jan 07 2008
    San Francisco,CA
    They are supposed to operate the same in either direction. That's what the documentation said at least.
    Jan 07 2008
    San Francisco,CA
    Fitment question?
    18x9 ET20 w/ 255/55 Tire
    Will they fit?
    Feb 01 2010
    Charlotte N.C.
    Quote Originally Posted by seanriv View Post
    Fitment question?
    Will they fit?
    I am mm from rubbing with
    18x8 et 35 - 245/50/18 with 17.5mm spacer. Final offset then being 17.5
    I am a full inch taller than stock.
    Nov 07 2016
    Kalispell mt
    Loving it. Should be a sweet ride.
    Jan 07 2008
    San Francisco,CA
    Well they kinda fit...
    Jan 07 2008
    San Francisco,CA
    Feb 01 2010
    Charlotte N.C.
    Wow and I thought my wheel wells were full! Why so large?
    Jan 07 2008
    San Francisco,CA
    Wanted more than 45 series tire, think I overdid it...
    Senior Member Two Rings rah253's Avatar
    Oct 07 2016
    pierce county, wa
    Love the car, great work!
    Mar 01 2015
    STL
    What brand gauge is that in the AC vent?
    Jan 07 2008
    San Francisco,CA
    It's a P3 Gauge, love it. http://www.p3cars.com/
    Jan 07 2008
    San Francisco,CA
    Went down to a 255 45, much better.
    Jan 07 2008
    San Francisco,CA
    It’s FOR SALE! Looking to get $5K, I’ll update with more details soon.
    Located in San Francisco, Ca.
    [email protected]
    Current picture!
    Veteran Member Four Rings ChicagosPhantom's Avatar
    Aug 28 2013
    02 Nemo S6 (stolen) / 03 Silver A6 2.7T K04 01E / 03 Daytona RS6 / 04 Dolphin A6 2.7T 01E / 02 Silve
    Chicago IL
    [email protected]
    Current picture!
    Nice... We have a forum moderator of our own people and he's abandoning the ship!
    Established Member Two Rings SUBAMMAS's Avatar
    Mar 15 2020
    PacificNW
    Quote Originally Posted by ChicagosPhantom View Post
    Will the last person to leave the C5 forum please sweep up and turn out the lights?
    '05 Allroad 4.2
    Aug 28 2013
    Chicago IL
    Quote Originally Posted by SUBAMMAS View Post
    Getting there... Might be me tho... Still have 6 of them.
    Mar 15 2020
    PacificNW
    Could end up being me. I've just started collecting. I'm loving my AR, and would certainly jump at the chance to pick up a clean S6 or RS6 Avant.
    '05 Allroad 4.2
    Jan 07 2008
    San Francisco,CA
    Haha, it sure is quiet. I just don’t want to sell it to a moron on CL... Comments like these make me want to keep it...
    Senior Member Three Rings ItsCAvalos's Avatar
    Aug 04 2018
    Rockford, Illinois
    If I had the money I’d go down the rabbit hole. But I don’t
    Veteran Member Four Rings hoganalley's Avatar
    Feb 23 2007
    Burlington
    Quote Originally Posted by ItsCAvalos View Post
    I don't have the money, but I'm going down the rabbit hole anyways! Unless the engine blows, I'm here for the long haul - I bloody ass love this car
    Sent from my ONEPLUS A6003 using Audizine mobile app
    05 allroad 2.7T Stock
    99.5 A4 1.8T K04 - Sold
    Veteran Member Four Rings Kruat's Avatar
    Nov 10 2004
    01 S4, 03 RS6, 15 A8L, 16 PSD F350
    Longview, WA
    Well ill be a C5 owner for life. Might let my Allroad go, even my S4. But will not let my RS6 go. And, God forbid it gets totaled, then I'll buy another.
    --Mike--
    01 Casa S4
    03 Mugello RS6
    15 Moonlight A8L TDI
    01 Aviator TT (sold)
    99.5 Santorin A4 (sold)
    04 Cobalt Allroad (sold)
    Jan 07 2008
    San Francisco,CA
    If it had black interior I’d keep it, lol
    Aug 04 2018
    Rockford, Illinois
    Aren’t part outs common? I’m not sure how much it’d cost but just an idea
    Jan 07 2008
    San Francisco,CA
    I don’t want to cross that bridge on this one.
    Veteran Member Four Rings 02 A6 2.7T's Avatar
    Nov 19 2006
    Too much crap
    WA
    Here ya go … it's local ….https://www.audizine.com/forum/showt...ersion-project
    2002 A6 2.7T - 6MT Crystal Blue APR Stage 1
    2002 S6 - 6 MT Black/black
    **SOLD ** 2002 allroad 2.7T 6MT
    Jan 07 2008
    San Francisco,CA
    Quote Originally Posted by 02 A6 2.7T View Post
    Perfect for someone who buys my allroad, lol
    Forum Moderator Four Rings doobiesdaddy's Avatar
    Sep 05 2008
    2001 Stage 3 allroad 2.7t 6mt TDI gearbox , 2021 Mercedes E 350
    Montana / San Francisco
    I'm surprised that we have never crossed paths. I too, have a 2001 stage 3 allroad and I also live in San Francisco. My stage 3 happened after a timing belt failure as well (Had at least 50k miles left until was time to change). I purchased my allroad 20 years ago and am the one and only owner of this car. When I drove it off the lot in 2001 I knew I would keep this car forever. When this Corona is all over we should get a beer.
    Dave - Moderator
    Issue? send me an email
    When I went to school, they asked me what I wanted to be when I grew up. I wrote down ‘happy’. They told me I didn’t understand the assignment, and I told them they didn’t understand life.
    -John Lennon
    Mar 15 2020
    PacificNW
    Yeah, I was out at Dre's place a few weeks ago to pick up an RNS-E from him, but didn't get a chance to look at it (short on time + social distancing + he was on daddy duty ). Probably a good thing I didn't see it, because I probably would have made a deal for it on the spot. Especially if he had put a 6-speed in it.
    '05 Allroad 4.2
    Jan 07 2008
    San Francisco,CA
    Quote Originally Posted by doobiesdaddy View Post
    I’ve know of your allroad and surprised as well. What area in SF are you? I’m in NOPA, shoot me an email and we can link up after this mess.
    [email protected]
