Results 1 to 7 of 7
    Jun 06 2016
    Oak Grove Mo
    Oil leak thoughts
    (Okay working with a 04 A6 3.0) So I have noticed a oil leak under the car here recently. It's not major I'd say maybe 10 drops every 12 hours. I've looked all over underneath the motor and I'm not seeing anything under the engine bay. The only place I see oil dripping from is towards the middle of the car where the tail end of the tranny meets the drive shaft. I stuck my hand on top of the tranny the best I could and its dry. Do you guys have any thoughts. Since I'm using my cell I can't post any of the pics I took of the area that's leaking. Any tips on posting pictures from a cell phone then I can show you what I'm talking about.
    Aug 04 2009
    Glen Ellyn, IL
    I use photobucket.com. Once you upload the pic you copy/paste the IMG link.
    Have you been able to determine what kind of oil it is? You can try putting some plastic like a grocery or garbage bag or some old Tupperware underneath to catch it and then see what it is. That'll definitely help you narrow things down.
    OEM+ work in progress allroad
    Unicorn Society member #8
    @fourings | Build
    Veteran Member Four Rings SteelyS6's Avatar
    Oct 29 2011
    Winnipeg Manitoba
    If it's your output seal on transmission/ center diff you want to fix that asap as they only hold somewhere around 12 ounces of fluid. My S6 started as a drop and got progressively worse over a short amount of time.
    Jun 06 2016
    Oak Grove Mo
    The fluid looks to be a goldish color
    Jun 06 2016
    Oak Grove Mo
    Here are the pics. Pretty positive it's the input seal. Thank you so much for the advice to look at that.
    Jun 06 2016
    Oak Grove Mo
    [IMG][/IMG]
    [IMG][/IMG]
    Jun 06 2016
    Oak Grove Mo
    [IMG][/IMG]
