Is anyone able to help me here, I'm installing a DW65v high flow fuel pump in my 1.8TQ APR Stage 3+.
My APR chipped ECU had fried and as a result I've swapped a stock ECU in the car with the car booked in for a custom tune next week. I'm prepping the car for E85 fuel with the DW65v fuel pump and Bosch 1000cc injectors (to be installed on the day of the tune).
I've already custom fit the DW65v pump into the basket, I just need to work out how to get the filter sock to work at the inlet side.
I've hooked up to the outlet port but what is the second port (smaller vertical port) that is shown in the image below. The AWD pump does not have it. At first I thought it was an overflow and hooked a second line from it back to the overflow on the outside of the basket.
I was able to prime the pump and start the car but it kept cutting out after a couple of seconds. Interestingly enough it would run with the MAF unplugged. I unplugged the MAF given that the APR MAF housing is 3" and given that I'm on the stock tune at the moment I though that the inaccurate MAF readings (lower than actual flowrate given the bigger housing) would lean out the AFR. As soon as I plug the MAF back in, the car stalls
I was able to drive the car for about 20 mins with the MAF unplugged and could see off the Short Term Fuel Trims that it was leaning out +25% under part to full throttle. At this point I ran into fuel starvation and the car then stalled under part throttle. Being concerned about damaging the pistons and plugs from running lean I got her straight back to the garage to see what I could do about it.
At this point I'm not sure firstly what the small port is on the DW65v pump, and there's nothing in the documentation or website as to what it is, and I'm also unsure of whether I'm getting inconsistent pressure at the rail because I could be overloading the stock Fuel Pressure Regulator in the fuel filter.
Also worthy of noting is that both the MAF and Fuel Filter have been replaced recently so I wouldn't be expecting them to be contributing to the issue.
Thanks in advance to anyone willing to shed some light!
