Results 1 to 31 of 31
    Aug 28 2010
    2005 Big turbo SRT4
    PA
    05.5 S4 Replaced Headlight switch and headlight are now always on??
    So my factory headlight switch was starting to fail. I would turn the switch on and the headlights wouldn't always turn on. Sometimes had to give it a "technical tap" and all the sudden the headlight would turn on in the ON position. I obviously decided it was time for a new on. I replaced the switch with a factory OEM switch. My car is equipped with auto lights and (coming home feature). I replace it with part number 8E0941531B5PR. Replacement was easy and straight forward, but as soon as i installed the new switch my headlights (low Beam xenons) and all other interior lights and rear lights are on no matter where the switch is positioned or time of day. So When the switch is in the "OFF" position everything is on with the key on. I have read others had their rear view mirror (dimming and compass) go out on them, but mine is working just fine. I also don't have a Ross-tech but I do have a vag scanner with limited capabilities. Anybody else have this problem. It really buds me that the lights are always on now.
    Aug 28 2010
    2005 Big turbo SRT4
    PA
    my scanner is coming up with a code of 01800 light switch (E1)
    Static implausible singnal
    Veteran Member Four Rings xhackerekx's Avatar
    Jul 23 2007
    10S6C6_12Q7TDI_A4B6 3.0_VNL730
    Scranton , PA / Poland UE
    change u light switch for oem no made in china
    Aug 28 2010
    2005 Big turbo SRT4
    PA
    I did replace it with a OEM switch. That is why I listed the part number.
    Apr 26 2016
    Kia Sportage V6 - Wifes car
    Metuchen New Jersey
    You can't turn them off at all? If you.live the switch to the right 2 spots they still stay on?
    Sent from the S4 with a Tap!!!
    My S used to have a tap, a valve slap... now it makes no noise at all! RIP
    Aug 28 2010
    2005 Big turbo SRT4
    PA
    With the ignition switch on or the car running I can not turn the lights off no matter what position the headlight switch is.
    Established Member Two Rings scorpioS4's Avatar
    Mar 31 2011
    New Jersey/Delaware,Dover AFB
    that's strange. the part # you listed matches the same one that JHM has on their website so I doubt the switch is faulty. I am no good with troubleshooting electronics so I am I hope someone chimes in that may be of some help
    2k5.5 Moro blue S4 6spd: k&n drop in/FI x-pipe cat back non res/Piggie DP's/JHM 93 octane Tune w-LA/Intake man. spacers/lightweight crankpully/JHM shifter Trio/JHM stage4 lwfw&clutch/Elbow Heater Bypass Kit/Led strip inlays & taillights (fly's V4's)/6000K D1S and 3000K HID Fogs /Cupra R lip/R.
    Aug 28 2010
    2005 Big turbo SRT4
    PA
    Me to! That's why I'm here. I know people can work wonders with a vcds. But I'm not one of them.
    Veteran Member Four Rings A4Maine-iac's Avatar
    May 03 2010
    2012 TT Sold
    Maine
    It could be the switch. Still have the old one? See if you get same with the old one. Contact where you got the other one and have them send out another. Don't chase gremlins that might not be there.
    Also double check the back. Make sure there are no prong issues.
    2002 A4 1.8T - sold
    2007 DTM S4 -Sold Sound clip - https://www.youtube.com/watch?v=bGz60n-31jc
    2012 TT - TTS Rear & Exhaust- UNI Stage 1+ " More to come"
    2021 SQ5 - " Just getting started
    Established Member Two Rings AndyB's Avatar
    Sep 03 2014
    Connecticut
    I have this issue after putting my car in service position, lights stay on in off position. Also the feature when you unlock the car and the fogs and rear lights come on no longer works. My compass in my rear view also doesn't work anymore. I tried resetting the battery a couple times but that hasn't done anything. Hopefully somebody knows.
    Aug 28 2010
    2005 Big turbo SRT4
    PA
    My compass in the mirror works just fine and when I put the switch over to the normal "lights on" and pull out my fogs work.
    Aug 28 2010
    2005 Big turbo SRT4
    PA
    Quote Originally Posted by A4Maine-iac View Post
    And I did the dumbest thing ever and tossed my old switch before confirming this one worked properly
    Jun 07 2014
    phila pa
    where in pa are you? i am in pa 19040 and i have a few swithes here we can test.
    Aug 28 2010
    2005 Big turbo SRT4
    PA
    Quote Originally Posted by rgtorque View Post
    I'm 19425. Probably a little over an hour from you
    Jun 07 2014
    phila pa
    Your call.
    Sent from my SM-N910T using Tapatalk
    Aug 28 2010
    2005 Big turbo SRT4
    PA
    Your call.
    Yeah we can do that. Just need to figure out a time. Maybe next Thursday if your available. You can text me to figure it out. 484-881-1150
    Apr 26 2016
    Metuchen New Jersey
    Did you ever get this sorted? Seems like I have a similar issue, except I can turn everything off if I move the switch 2 spots over.. I knew my auto dimming mirror wasn't working, but had No idea we had a compass on the mirror.. jeez.. don't ya just love gremlins!!!
    Aug 28 2010
    2005 Big turbo SRT4
    PA
    I still have no figured out the issue. I even ordered another OEM switch and tried that. Same thing. Headlight on in every position. Even in the off position. Compass and auto dim mirror still work. I don't know what else to lock at. All pins in the connector look good to. Pulled every fuse in the car and they all checked out.
    Veteran Member Three Rings jakeoboy67's Avatar
    Oct 21 2013
    mk2 Jetta Tdi
    NB , Canada
    have you ever played in the coding for the lighting ?
    Aug 28 2010
    2005 Big turbo SRT4
    PA
    I don't have a Ross-tech and don't know anybody that has one. So no. My code reader can read the coding. But can't change it.
    Oct 21 2013
    mk2 Jetta Tdi
    NB , Canada
    Quote Originally Posted by fast04s4 View Post
    so the only switch that functions as before is the defective one ?
    same part numbers ?
    maybe the internals have been altered inside of your original switch ? (you know , the old method of isolating/bending/breaking pins so that some lights comes on and others are off at certain times instead of changing the coding)
    Aug 28 2010
    2005 Big turbo SRT4
    PA
    Quote Originally Posted by jakeoboy67 View Post
    same part numbers ?
    Well this is stupid I know. But I actually tossed the original switch when I got the new one. So I don't have the original part number from that switch. Everybody that I have asked said this is the correct OEM switch for the car though.
    Apr 26 2016
    Metuchen New Jersey
    Here is a silly question.. not sure if the B6 S4 has D.R.L., if it does, can they be coded out? And if not, my lights are always on, but if I turn the switch 2 spots over to running lights only, the head lights turn off and the running lights stay lit.. the P.O. swapped out the lights for the ones with the led running lights.. and HID instead of the xenon lights.. would that be the reason they are acting funny?
    Sorry to hijack, figured the problems were similar..
    Aug 28 2010
    2005 Big turbo SRT4
    PA
    Quote Originally Posted by chain_slappins4 View Post
    Sounds like a completely different issue. I think your is related to the headlight swap.
    Apr 26 2016
    Metuchen New Jersey
    Probably.. but the question is how to fix it.
    Apr 26 2016
    Metuchen New Jersey
    Anyone encounter something like this before?
    Apr 26 2016
    Metuchen New Jersey
    Here's a quick update.. after searching for hours, I found a wiki on the Ross tech site about recoding the central electrics module for the headlights, and after changing the coding to 01003 ( with sensor, halogen lights and USA), I do not get the implausible signal code for my headlight switch, my headlights are now off, my rear view mirror now dims, and I actually have a compass ( didn't know I even had one), and the auto function now works... so all along it was just a coding issue....
    Hope this helps someone else!
    Aug 28 2010
    2005 Big turbo SRT4
    PA
    Hmm I wonder if that could be my issue as well my coding is 01023. I can't change it though with my scanner. Anybody in SEPA that could help me with the coding?
    - - - Updated - - -
    I forgot to add the coding might be different for xenons to.
    Apr 26 2016
    Metuchen New Jersey
    and my mirrors are actually power folding!!!!
    Apr 26 2016
    Metuchen New Jersey
    for xenon lights it would be 01013
    Apr 26 2016
    Metuchen New Jersey
    but if you have aftermarket hid lights use the 01003 coding.. seems to get rid of all the codes and lights on the dash, and they behave properly
