    Established Member Two Rings kirkendall's Avatar
    Jan 20 2015
    06 zx6r , 2008 a4 B7
    Lehighton, PA
    A/c troubleshooting
    Hey fellow Audi fans, does anyone have any troubleshooting guides to help me find out why my A/c is not blowing cold air anymore? I just checked and it shows that I was in the "good" range and I don't have a vag-com to check anything else. Can anyone help?
    2008 A4 6 speed mt.
    JHM STAGE 1 - 93 oct.
    Test pipe
    rs6 grille mod
    Oct 16 2008
    South Florida - Ft Lauderdale
    Can you select LO or you are stuck in ECO?
    If you can select LO, does both radiators fans turn?
    Phil
    May 20 2010
    No ECON light on?
    First thing is first--check fuses.
    Next, check the actual pressure. You can rent (or buy) a set of a/c manifold gauges. Without cracking them open to release any gas, you should be able to put the two gauges on their respective sides, and with the car running and a/c on, see if the pressure changes. The low side should decrease to about ~30 psi, IIRC; high side to ~160 psi. If the pressure is equalized, then the compressor is not compressing the gas.
    Next thing I would check is the refrigerant high pressure switch, located on the driver's side of the condenser. Since you've indicated it has pressure, you're probably not leaking it out from the o-ring. It's possible this has gone bad. Though normally when this goes bad, you will get the ECON light.
    If the switch is good, then I fear you probably need to replace the compressor. There is a solenoid in the compressor, which is what changes the angle of the swash plate, which in turn drives the actual pistons to compress the R134a. If you need a compressor, a wreck may be a decent option (though a ticking time bomb, in my opinion). I used discountacparts.com and got a brand new Denso compressor, orifice tube, o-rings (which were about useless), accumulator, and PAG oil for about $400. Compressor is relatively easy to install, but you'll need the system professionally evacuated and refilled.
    If you can find someone close by with VCDS, this may help narrow down your issue quicker (can check the state of the high pressure switch, at least).
    Veteran Member Three Rings Luis_Heineken's Avatar
    May 28 2012
    Bayamon, Puerto Rico (USA)
    Phil
    x2
    Mar 02 2016
    hk
    Hope to enjoy in this forum
    english
    Fav link:
    business english
