Results 1 to 19 of 19
    Deactivated Three Rings
    Apr 28 2012
    ny
    This doesnt seem normal
    Just took out my intake and decided to snoop around the engine a bit and noticed this... Does anyone have any idea wtf would cause that?
    Veteran Member Four Rings jfo's Avatar
    Nov 17 2010
    Courtenay, BC, Canada
    There should be a hex head bolt there. Looks like someone cut or snapped it off? Are you the original owner?
    2011 A4 Avant
    Apr 28 2012
    ny
    Quote Originally Posted by jfo View Post
    I am the second owner. What does that hold together? Any chance you have the same engine and could snap a quick pic? If not do you know what its called so I can google a pic?
    Nov 17 2010
    Quote Originally Posted by Jerritt View Post
    I don't know what engine you have but mine's the usual 2.0 TFSI. I don't know what it's for and only the head of the bolt is visible...nothing is attached to it. Perhaps someone like Allowancer, who has taken this apart can explain what it's for.
    2011 A4 Avant
    Veteran Member Four Rings earhythmic's Avatar
    Sep 17 2006
    ‘17 F450, ‘24 Street Triple RS
    San Francisco Bay Area
    My guess is he's got the 2.0T also since the pipe in that first pic says turbo.
    Confirmed there's supposed to be a hex bolt there, I forgot to put it back in when I installed my HFC (had no reason to remove it really) and smoke was billowing out of it.
    2013 Allroad - 12.18s 1/4 mile
    CTS K04| APR | IE | Magnaflow | AirLift 3H | Hotchkis | Vorsteiner
    clicky for build thread
    past: B6 S4, B5 A4
    Apr 28 2012
    ny
    Quote Originally Posted by earhythmic View Post
    Does anyone have a picture they can take of what its supposed to look like? my engine is 2.0T. This area is so mangled I cant tell what belongs there. What would that bolt hold together?
    Veteran Member Four Rings blbroo's Avatar
    Oct 26 2012
    SQ5, Nissan D21, 435i Gone: K04'd B8 A4, M235i, UrS6, B9 SQ5, D21 Nissan 4X4
    St. Louis, MO
    Here is a pic from another DIY that shows what that area should look like. I think that is a bolt that holds on the heat shield. I can get a pic of mine when I get home from work.
    Collector of German things.
    “Whoever said laughter is the best medicine had clearly never tasted scotch.”
    Nov 17 2010
    There's really nothing to see other than the bolt head. It's just like the undamaged area next to what you have, with a bolt head.
    Edit: It's exactly like the bolt head in the above pic.
    2011 A4 Avant
    Oct 27 2010
    Sepang S3, Arctic S4.
    Norwood, MA.
    Should be a 6mm allen head.
    2016 S3
    Instagram- @Thisisastickup
    Sep 17 2006
    Just snapped this. Like others have said, it's literally just a bolt head.
    past: B6 S4, B5 A4
    Apr 28 2012
    ny
    I get that now that I see it. Others have said it was a hex bolt. So Im sitting here telling the parts guy I need a hex bolt and hes looking at me clueless. They wouldnt let me send the photo to make my life easy.
    - - - Updated - - -
    Quote Originally Posted by b6Hate4 View Post
    Jun 12 2013
    1999 Pontiac Grand Prix GTX
    LaSalle, Ontario, Canada
    That's your exhaust heat shield. I don't think the bolt should be a hex head; the part number resolves to a triple square round head bolt. If you want a pic of one, I can take one. Part number is: N10 572 403
    2010 Silver Audi A4 MT Sport Package w/ B&O
    Stage 'X': FrankenTurbo F23L Ceramic Coated Manifold | Bully-Flo P&P Head | Ferrea Intake Competition Valves | Ferrera Exhaust Super Alloy Valves | IE ValveSprings & Retainers | HFC wrapped w/ DEI Titantium
    Eurocode FMIC | Maestro Tuned | K&N Typhoon Intake | EuroCode Meisterwerk | StopTech BBK | 034 Motor Mounts & All Inserts | CTS PCV Catch Can
    Build Thread
    Oct 27 2010
    Norwood, MA.
    Quote Originally Posted by Allowencer View Post
    On 3 cars I've removed the heat sheild on there have been 2 triple squares, and 1 6mm allenhead.
    2016 S3
    Nov 17 2010
    There are 2 retaining bolts on the upper part of the shield and this single bolt on the lower section. It too may just be another retaining bolt. They may have changed the bolt type, since mine definitely take a hex driver. In his pic, you can see one of the upper bolts and it's a triple square. It's also hard to tell from the pic if the remains of a bolt are there or just damage to the shield.
    2011 A4 Avant
    Jun 12 2013
    Ah, good call guys. Wasn't aware of the hex bolt. I see what you both are saying now though.
    Build Thread
    Apr 28 2012
    ny
    Appreciated. As long as its not an important part I will just leave it as is.
    Im trying to figure that out too, I cant tell if the bolt itself sunk into the shield or if the bolt head broke off and the stud is in there still.
    Sep 17 2006
    I swear when I forgot to put mine back in and started the car there was tons of smoke coming out of that hole, I think it may be more than just a dumb heat shield bolt. IF that's true and that bolt was left/shimmied out then could all that black crap be crusty exhaust or burned oil you'd typically find in a catch can...and warping the surrounding metal?
    past: B6 S4, B5 A4
    Oct 27 2010
    Norwood, MA.
    No. That bolt could be plugging a hole that would otherwise be utilized on a different engine that uses this same bare head, but oil and exhaust crust would not build up like that.
    2016 S3
    Jun 12 2013
    That hole is just a bolt hole for sure. I didn't even put the heat shield back on my car post my rebuild; nor did any of the bolts go back in.
    Build Thread
