Results 1 to 4 of 4
    Nov 13 2009
    the OC, SOCAL
    blinking fob key meaning?
    so I noticed my key fob blinks sometimes while the car is on. I changed the battery thinking it means its low in battery but it still blinks.
    the key fob works fine and everything functions fine.
    so does anyone know what it means.
    Apr 04 2015
    B5 S4, 92' SC300', 84 Cressida
    Most likely a button is stuck or your remote is bad. Have you ever dropped it in water?
    Sent from my SM-G935T using Tapatalk
    01 B5 S4
    Autospeed DTS, Forge DVs, APR BiPipe, APR Snub mount, Stasis/Alcon Mono4 355mm BBK, Unknown Short Shifter, Blitz TT, NefMoto Stage2, SSAC v2, TTV Steel FW, CM FX300
    16 A3 e-Tron
    Stock for now
    Nov 13 2009
    the OC, SOCAL
    nope. it was like that since day one. my Q3 2016 does this as well.
    Active Member Two Rings gui_a3's Avatar
    Jan 25 2016
    CARMEL NY
    the key fob will blink every time u open/close a window or door in the car even if the car is running. ive noticed this as well. next time u get in the car. open the window n look at the key fob you'll see it blink. wouldn't worry about it. don't think its a big deal
