Results 1 to 12 of 12
    Veteran Member Four Rings 2010A6's Avatar
    Mar 10 2015
    2017 Jeep Cherokee; 2018 S3 Nano Gray
    Albany, NY
    HELP: Upper control arm pinch bolt head broke off!!!
    What do I do now?
    Sent from my iPhone 6s+ using Tapatalk
    Current: 2018 Audi S3 2.0T Nano Gray / Magma Red
    Past: 2010 Audi A6 3.0T Midmight Blue / Pistachio Beige
    Veteran Member Four Rings zcspec's Avatar
    Aug 10 2015
    Need VAG-COM work, IM me
    Orange County
    From my experience removing a few pinch bolts from the B8/8.5 chassis, that pinch bolt is only held in by the other side's nut. I do not believe it's threaded inside the pinch hole.
    What I would recommend that you do:
    - slightly jack up the front suspension from the brake assembly
    - tap on the threaded side of the pinch bolt until you feel it slightly move (you may have to raise or lower your brake assembly to relieve some pressure on that area)
    - from there, you should be able to tap it completely out, with a long bolt or something that can go through the pinch bolt hole
    - replace the bolt with an OEM bolt/nut or simply head to your hardware store to find a replacement to hold you over)
    Dec 10 2011
    991 C2S, Stage 3 S4, E46 M3
    CLT | MKE
    Correct; it isn't threaded. Hammer it out.
    If it won't budge, you may need an air hammer. My A6 saw many WI winters, and the pinch bolt snapped both ends off when I went to remove it with an impact. I could tell it had probably never been removed before throughout the car's life. The thing would not budge even a single millimeter no matter what I tried, until I finally went and bought the air hammer. Had it out in a few minutes after that.
    -Hayden
    B9 Q5 | Brilliant Black
    E46 M3 Cab | Steel Grey
    Feb 06 2013
    CA
    I once had to actually drill out the pinch bolt, since even an air hammer was useless against it... It was the biggest pita I'd ever dealt with.
    Sent from my Nexus 6 using Tapatalk
    Veteran Member Four Rings D's Avant's Avatar
    Oct 03 2007
    02 BMW 330i
    Illinois
    Soak it with PB Blaster. Soaking it at least overnight. Tap around the bolt/upright area to maybe loosen things up. Try a punch first, then air hammer, heat, then drill it out if you have to. This will take you hours if it is really stuck. Welcome to pinch bolt hell, I've been there before with my B5.
    Use some anti seize for the new one, duh.
    Current '08 A6 Avant S-Line
    Former '99 A4 Avant 1.8t
    Feb 01 2016
    09 A6 3.0T (Sold), 11 Cooper ALL4 S, 2013 S5
    Lowell, MA
    Quote Originally Posted by 2010A6 View Post
    What do I do now?
    I have that very same pain today!
    2013 S5, B&O, Sports Diff, Nav Plus, Carbon inlays, Akebono, APR Stage 2, Dual Pulley, DSG Tune, APR intake and back pipe. KW HAS. Variant 20x10, Carbon Imports rear spoiler, RS Grill, Passport 9500i and night surveillance by Blackvue :) Ultracharger and Intercooler, ECS X-pipe
    Mar 10 2015
    Albany, NY
    Quote Originally Posted by Mickmerr62 View Post
    Oh my friend I'm sorry to hear! Be extremely careful with how you proceed. All in all I spent over $2,300 replacing things from the first shop's attempt at getting it out via grind wheel and torch. Both sides of my front end still rattle over uneven roads like gravel or cracks in the city streets.
    Feb 01 2016
    Lowell, MA
    That sucks, I'm sorry you're having continued hassle.
    The shop that has my car outsourced it to a local machine shop who told my guy they had done 5 already this year.
    Penalty of living in New England methinks.
    Apr 20 2012
    2004 Audi S4 Avant RIP 1995 Mercedes E320 Wagon 1958 Mercedes 180D
    Winnipeg, MB Canada
    My friend has a method that's worked on so many pinch bolts... here in Canada with our winter and salt on the roads basically welds the bolt to the upright.
    I'd go as far as if I ever buy a new audi I'd remove the bolt the day I bought it and put some anti seize on it and take it out yearly lol
    You can get it out with an air hammer, pb blaster and having the nut on the end... just have someone tightening it while it's being hammered out, and torch it with minimum MAPP gas. You'll have to replace the upper control arms too. We kept cutting off threads as the bolt comes out so we diddn't get it stuck on the upright. Make sure that shop puts antiseize on the new bolt.
    Current
    C6 S6 Phantom Black Pearl
    Milltek Cat Back
    Airlift Performance Struts
    Accuair Elevel w/ Ilevel
    JHM Tune
    JHM Intake Spacers
    Ispiri CSR1D Wheels
    Feb 01 2016
    Lowell, MA
    Thank you for this very helpful advice. Much appreciated.
    Mar 10 2015
    Albany, NY
    Quote Originally Posted by b6s4avantMBCA View Post
    Pretty much what I tried but I damaged the threads when I took the nut off. It got very messy lol
    Apr 20 2012
    Winnipeg, MB Canada
    yeah I could see that. They are a huge pain in the a$$. Good news is now that they are out it's much easier going forward. If the shop didn't put antiseize on it, you should when you get it back.
    Current
    Milltek Cat Back
    JHM Tune
    JHM Intake Spacers
    Ispiri CSR1D Wheels
