Results 1 to 20 of 20
    Veteran Member Three Rings brainpan's Avatar
    Apr 11 2010
    sk8 banana
    ontario
    Intermittent misfire help
    Been chasing misfires for a few weeks now, it first started in cylinder 1. I swapped cylinder 1 and cylinder 2 coils and the misfire traveled to cylinder 2, perfect bad coil.
    Thought after that I had it all figured out. Replaced the bad coil in cylinder 2 (originally from cylinder 1) with a new one straight from the dealer.
    Later that night, I get a code again, cylinder 1 misfire... so after reading a few threads I change the 2 remaining coils on cylinders 1 and 3 problem gone...
    Fast forward 8 days to today, cylinder 1 misfire again...
    So my question is, what are the odds of getting a new coil that is faulty? I'm sure its possible, but unlikely. The parts guy did say they have a 1 year warranty on ignition coils...
    Tomrw at work I will swap 1 and 2 again and see what happens. But I was wondering if there's anyone out there that's been through this before ?
    Running giac stage 2 pump, still pulling hard when it's not misfiring. Misfires only happen on WOT pulls usually after a shift.
    Side note: after clearing the codes the car wouldn't turn over, was almost like the ignition cycle was cutting itself short... tried 3 times and nothing, would get like half a crank and just quit. I checked voltages on battery getting 12.2 so tried to turn over again and it started.. wtf.
    Sent from my Note 5
    Bryan
    Veteran Member Four Rings s4matty's Avatar
    Aug 15 2015
    2 feet
    Niagara canada
    Try putting it in N instead of park after you clear the codes..My car does the same thing after I scan it
    Sent from my SM-G900W8 using Tapatalk
    Forum Moderator Four Rings Loe's Avatar
    Aug 09 2015
    Audi RS E-tron GT, BMW i4 xDrive40
    Sarasota, FL
    How do the plugs look?
    Loe P - Forum Moderator, Audizine
    Sold: ('14 Audi S5 S-tronic: [email protected] (127.36mph highest trap)| +424 ft. D/A | 3.371 PR | full-weight/street tires).
    Current: BMW F82 M4cs, Audi TT RS APR E85 Stage 1 "+" ecu/tcu: [email protected] (Panel filter | 4" turbo inlet | intercooler | stock exhaust, suspension, 18" Neuspeed wheel/tires, | full weight).
    Veteran Member Four Rings jran76's Avatar
    Jun 20 2011
    2002 Audi S4
    Plano, TX
    Have you checked the plugs? What year is your car, how many miles, and have/when were the plugs last replaced?
    I saw quite a few misfires when logging (never threw a code), but just proactively replaced all the plugs and coil packs to be safe. At the end of the day, it's a couple hundred bucks, and at least in my case, the car ran much better after doing so.
    Outside of plugs and coilpacks, the most likely culprit is a leaky intercooler, so if the problem persists, I'd consider pulling the S/C to check for leaks.
    2018 S4 : Daytona Gray : Black Nappa : Carbon Atlas : S Sport : Black Optics : 034 Springs/Rear Sway Bar/Inserts : 19x9.5" BBS CH-R Wheels : EPL tune : Wagner Intercooler
    2002 S4 : Black : Black Leather : 6-Speed : Stage 2+ ...
    2022 Q7 : Mythios Black
    Apr 11 2010
    sk8 banana
    ontario
    Quote Originally Posted by s4matty View Post
    Awesome thanks, kindda shit myself a bit, things haven't been going my way lately lol..
    Quote Originally Posted by Loe View Post
    I never check it, they have about 20k km on them, assumed they were ok.. guess that's something to check for tomrw..thanks!. what should I be looking for on the plug?
    Sent from my Note 5
    Bryan
    Jun 20 2011
    2002 Audi S4
    Plano, TX
    Quote Originally Posted by brainpan View Post
    Sent from my Note 5
    I'd check the gap first, and just make sure they don't look too fouled up. Something in the 0.028 range is a good gap. You could even go a little lower (or a stage colder) on a stage 2 tune.
    Aug 09 2015
    Sarasota, FL
    Quote Originally Posted by jran76 View Post
    yes, this is something that can happen as well. Check the plugs to see if there is a white mold-like substance on the tips of the plug. Check your coolant levels as well. If all is clear, swap the plugs on cyl 1 and 2 to see if it moves.
    If it's a coolant leak on the intercooler, I would advise to revert everything back to stock and take it to the dealer ASAP (or ind. shop if out of warranty) as the coolant may lead to a hydrolocked engine (worse case scenario) or contaminating your cat.
    Apr 11 2010
    sk8 banana
    ontario
    OK I'll definitely look into this tomrw, i don't own a spark gap tool so maybe something for the shop to look at for me.
    You had an intercooler leak right? Looks like I'm gonna be going to the shop this week and get him to check it out. Don't wanna mess around with something like that. My coolant is slightly below min when cold...
    Sent from my Note 5
    Bryan
    Apr 11 2010
    sk8 banana
    ontario
    Pulled cylinder 1 plug, seems ok to me? Any thoughts, seems pretty worn for just 20k km ?
    Sent from my Note 5
    Bryan
    Apr 11 2010
    sk8 banana
    ontario
    Just to add, measured .32 with feeler gauge
    Sent from my Note 5
    Bryan
    Jun 20 2011
    2002 Audi S4
    Plano, TX
    The pic of the spark plug is a little hard to see as far as how much white build up is there. It looks ok from what I can see there though. A small amount of buildup is normal.... I would personally gap the plugs to .028 or so, and then try swapping them around like Loe mentioned.
    Apr 11 2010
    sk8 banana
    ontario
    Thanks for the reply jran, I'll try swapping 1 and 2 tonight, as for the gap I don't have the tool to close it up. Is it that much of a hassle to change the gap? I've never done it before but doesn't seem like it's that hard to do
    Sent from my Note 5
    Bryan
    Jun 20 2011
    2002 Audi S4
    Plano, TX
    Sent from my Note 5
    It's easy. Depending on the plug, some are hard to move though. I don't use special tool in most cases. Just press it down on something, and use the feeler gauge to check. I prefer the feeler gauge over a spark plug gap tool.
    Apr 11 2010
    sk8 banana
    ontario
    Awesome thanks!
    Sent from my Note 5
    Bryan
    Aug 09 2015
    Sarasota, FL
    The plug looks 100% healthy. However, it doesn't hurt to swap. It doesn't appear to have a white moldy-looking substance I was referring to (think cauliflower head, only not as massive), your white substance is 100% normal looking.
    Apr 11 2010
    sk8 banana
    ontario
    Great thanks Loe! Hopefully tonight I can get around to swapping plugs. I did a few hard pulls this morning and couldn't get a code.
    Seems like when the ambient temp is around 20 degrees I get the misfire. This morning was around 12 degrees.
    Sent from my Note 5
    Bryan
    Veteran Member Four Rings schirm's Avatar
    Apr 23 2009
    1999 bmw z3coup M with 5,000 miles Mint
    Forked River nj
    When I chased a misfire on the same cylinder it ended up being a bad CAT
    2004 A4 1.8t | Avant | 6MT | Stock | Atlas gray |
    2010 S4 | Ice Silver Metallic | Sport Diff | 6 speed | 19 5-Tri-Spoke Wheels | Audi Drive Select | B&O | Silver/Black Nappa Sport Seats | Navigation Pkg | Brushed Aluminum Trim | APR Stage 2+ | Hoen Xenonmatch Fogs | 034 Motor mounts | Roc Euro | black RS4 Grille |
    Past
    2007 A4 | Revo Sg 2+
    2005 Subaru Legacy GT 365WHP
    Apr 11 2010
    sk8 banana
    ontario
    Quote Originally Posted by schirm View Post
    That was my first worry, the exhaust note changed and later misfire. Turned there was a weld issue on my center res on my borla exhaust, which they warrantied.
    Just un update, re gagged cylinder 1 to 28 thou and cylinder 2 was already at 29. Swapped em and so far so good. What was also strange is cylinder 1 plug was Bosh and 2 was NGK.
    A plug is a plug but.. the dealer did the maintenance under audi care and replaced both front wheel bearings too, only to have fail 10 months later and deny any wrong doing because I'm lowered...
    Sent from my Note 5
    Bryan
    Senior Member Three Rings Italiano's Avatar
    Jul 27 2009
    2012 BMW X5, 1979 Corvette
    Charleston, SC
    having a similar issue, just ordered an new set of factory plugs to see if it resolved the issue. My dealer of course blames it on the aftermarket NGK plugs i have, they would not replace them so i have to do it.
    2014 S4 (B8.5) APR Stage II+ ll APR Pulley upgrade ll APR Exhaust ll APR TCU Upgrade ll 20% tint
    Established Member Two Rings A4MZ's Avatar
    Dec 21 2007
    West Chester, PA
    I had a random misfire that couldn't be diagnosed which ended up being a dropped valve. Complete engine rehaul. Was GIAC stage 2 as well.
