Results 1 to 4 of 4
Thread: Shift knob
    Mar 28 2016
    Shift knob
    Okay, I give up. How the hell does one remove the shift knob in this car?!? I figured a quick search would yield the answer, but nope.
    Jul 17 2011
    Sin City, USA
    Shift knob
    It is very easy. Start by grabbing the frame of the boot and pulling up. Should not need a lot of force to unclip from the center console. Pull the boot up over the knob and there should be a crimp clamp there. You will need to take that off. Then fold the boot back down. Next, this takes both hands, grab the gear select button and pull outward to disengage it from the button mechanism.. At the same time, pull up on the shift knob. It should slide up and off.
    '09 C6.5 A6
    Veteran Member Four Rings Dutch_A6's Avatar
    Aug 19 2012
    GMC Terrain
    Belleville, IL
    be careful no to let go of the knob after you pull it off it might slip in and is a pain to get out, i used a clip after pulling the knob out to keep it out when i pulled it off
    Black 2012 A7 Prestige
    Zito ZF01 wheels
    EPL stage 2 tune
    Tinted marker lights
    Roc Euro intake
    AWE touring exhaust
    APR CPS
    Feb 06 2013
    CA
    Quote Originally Posted by Dutch_A6 View Post
    +1 on that...huge PITA to get out again, but it can be done if need be.
