Results 1 to 22 of 22
    Veteran Member Three Rings Congratulati0ns's Avatar
    Nov 09 2009
    tri-state
    Exclamation Huge Parts List B5 S4
    UPDATED 6/24/16
    Pick up zip code 11720.
    DRIVETRAIN
    -01E 6 speed 89k miles (no issues) - $850 picked up
    -01E Trans spacer - $55 shipped
    -S4 rear diff 89k - $175
    -Aluminum uprights - $175 shipped (set)
    -Front calipers complete - $120 shipped
    -Rear caliper set - $90 shipped
    -Front or rear subframes - $80 each / clean
    -Front or rear sways - $20 each
    -Axle shields - $30 shipped
    -Front S4 shock spring set - $60
    -Front aluminum shock top hats with control arms - $60 shipped set
    -OEM rear axle set - $120 shipped
    INTERIOR
    -Bose door card set black with speakers -$120 picked up
    -Black leather seat set. Heated. Front driver seat fair. Pass seat good cond. Rear seats in great cond - $250 picked up
    -S4 steering wheels without airbag...new and old style...mint - $105 shipped
    -Mint cup holder - $55 shipped
    -S4 6 speed shift knob - $40 shipped
    -Cruise control/wiper stalk - $30 shipped
    -Climate control unit (some sticky buttons) - $45 shipped
    WHEELS/TIRES
    -Set 17x7 Avus OEM (curb rash/need work) -$250
    -Set 18x8 Avus OEM (curb rash/need work) - $325
    -Set 17x8 Fat fives OEM (slight curb rash) - $300
    -Set 17x7.5 B6 A4 5 spoke wheels OEM with Ws70 Blizzaks (6-7/32) - $450
    -Set 225/45/17 Nokian Hakas 5-6/32 - $175
    -Set 255/35/19 Conti Contact SP (S5 take offs) 6-7/32 - $250
    ENGINE
    -Nearly complete APB BF block (missing, top timing covers, clutch fan assembly, serp belt tensioner) 101k - $850 picked up
    -Set of K03s 72k mint - $215 shipped
    -Exhaust manifolds - $50 shipped set
    -Set of heads, bent valves (timing belt snapped) 89k - $100
    -Bosch MAF - $40 shipped
    -Early intake manifold - $60 shipped
    -Late intake manifold - $80 shipped
    -ABS pump non esp - $85 shipped
    -ABS pump esp - $90 shipped
    -AC Compressor - $60 shipped
    -AC Lines - $25 shipped
    -AC fan - $30 shipped
    -Ypipe - $30 shipped
    -Airbox complete - $60 shipped
    -Stock ICs - $45 shipped set
    -Window wiper motor and assembly - $40 shipped
    -Motor brackets - $70 shipped set
    -Fan control module - $45 shipped
    -APB 72k ignition coil packs (6) - $30 shipped
    -BEL ignition coil packs (set of 8, 2 extra spares) - $65 shipped
    -Brake Master cylinder - $25 shipped
    -Brake booster assembly - $35 shipped
    -Harmonic balancer - $30 shipped
    -Primary o2 sensor set - $60 shipped
    -Secondary o2 sensor set $30 shipped
    -EGT set - $80 shipped
    -N75 - $30 shipped
    -N80 - $30 shipped
    -N249 - $25 shipped
    -Gas pedal - $35 shipped
    -ECU box - $40 shipped
    -Fuel rail - $30 shipped
    -Various coolant, oil hoses and lines. Rubber/hard lines
    -Bosch alternator - $100 shipped
    -OEM starter - $60 shipped
    EXTERIOR
    -Taillights - $60 shipped (set)
    -Pass and driver doors ask - $50 each
    -Silver trunk (ok shape) - $60 picked up
    PM with question.
    6 Speed Single Turbo S4
    Q7 TDI S-Line
    Jan 07 2014
    United States
    Can you send pics of drivers door and trunk?
    Veteran Member Three Rings quattEUro's Avatar
    Jan 01 2010
    B5S4 Avant, e30 325is, 2017 Tacoma TRD Pro, 1974 Honda CB360t, 1979 BMW r100rt
    Poughkeepsie, NY
    do you have the shifter assembly? i need the whole interior bits for a 6 speed
    [INCOG]
    Nov 02 2014
    06 9-3 Aero 2.8T, 96 Miata
    Winchester, VA
    I'll take the ECM. Pm sent.
    Veteran Member Three Rings Audi9's Avatar
    Jul 20 2014
    B5 S4, 8V A3, 8V.5 RS3
    San Antonio, TX
    I'll take the front oem axles
    Nov 16 2014
    ovid ny
    I'm looking for a head light ballast will you sell one????
    Jan 28 2008
    central ny
    Pm'd you.
    Veteran Member Three Rings TheDarkness's Avatar
    Jul 13 2008
    15' A3 2.0T , b5 S4 Stage III
    Pm'd you on front Axles. Got the $ ready
    2001 Stage III Pearl White B5 S4: Frankenturbo F21s | Iforged Flux | Solo Motorsports Dyno Tune | Bosch EV14 52#
    2015 A3 2.0T 8V Mythos Black: KW V3s
    Veteran Member Four Rings erykv1's Avatar
    Jul 01 2014
    'murca
    PM'd
    Veteran Member Three Rings Wagonholic's Avatar
    Mar 01 2014
    2001 B5 S4 Avant (Laser Red)
    Los Angeles, CA
    PM'd
    Justin
    I have a major problem, I'm a boost addict and a wagon addict
    #toomuchboost #racewagon #becauseracecar
    B5 S4 Avant - Laser Red. 6-speed Manual. 1 of 18. Unleashed by STUKLR
    Going big or going home. Doing a garage build. View my build thread.
    #YEengineering
    Jan 20 2011
    Portland, OR
    can you pm me pictures of the shocks? i'll likely take that set from you.
    Active Member One Ring Konstantcream's Avatar
    Oct 09 2014
    West Orange, NJ
    Please pm pics of turbos
    Established Member Two Rings vagra4nt's Avatar
    Aug 09 2005
    b5 s4 01.5m, vw 02 1.8t gti
    LI, NY
    PM'd about passenger EGT
    FrankenTurbo| Nefarious| Haltech| Aquamist| ST| iTGUY
    RIP DAZ
    Nov 09 2009
    tri-state
    All PM'ed back. List updated. Thanks for all interest.
    If you need photos of something, send me your email or number in the PM. Its much easier sending them that way.
    Q7 TDI S-Line
    Veteran Member Four Rings FlyboyS4's Avatar
    Jan 06 2007
    Mk7 Golf R
    FL
    Interested in:
    Front & Rear Sway Bars (with hardware)
    Axle Shields
    AC Fan
    Fan Control Module (with all wiring?)
    Driver's Door Shell (assume it's Silver, have a pic of condition?)
    Oct 06 2011
    Farmington CT
    PM'd.
    hope to hear from ya.
    Established Member Two Rings On3ok?'s Avatar
    May 10 2015
    Milford Delaware
    rear calipers shipped to 19963?
    Senior Member Two Rings NKI 337's Avatar
    Apr 24 2007
    Miami, Florida
    Pm'd
    ***** www.dubbersinc.com *****
    Established Member Two Rings Ob3R's Avatar
    Apr 29 2013
    '17 RS3/ '00 S4/
    Omaha, Ne
    Bosch MAF still available?
    Sent from my Forever Check Engine Light B5 S4
    DD: '17 RS3
    Project: '00 Audi S4 6MT Imola Yellow
    Previously Owned: Too Many...
    Veteran Member Three Rings quattro_silver's Avatar
    Jun 18 2008
    Chicago, IL
    PM'd
    APR
    Vogtland Coilovers
    BBS CH black/lip
    Piggies/Neuspeed G2
    E-Codes + DDM 55w 6k
    SRP pedals
    Hawk HPS + Adams slotted
    Kicker CompVT
    Jul 07 2015
    Lancaster, NY
    Where in the tristate are you? I may need a fuel rail.
    Jul 30 2014
    My baby b6 s4 good wood green pearl, A bunch of b5 a4s, 86 Toyota pickup
    Bellingham,WA
    Diverter valves?
