Used to have low pressure side issues but fixed all those. Car runs great most of the time but sometimes at low RPM cruising speeds I'll have throttle cuts and the EPC light comes on. I've had to pull over on the side of the road, turn the car off, turn it back on and it runs mint again. Very odd. I have had a few times where I get throttle cuts in 130+ mph range but that may have been due to bad E85 when travelling in Wisconsin.
Main code is:
6538 - Bank1; Fuel Measuring System 2
P1093 00 [032] - Malfuction
Other one is:
23254 - Fuel Level Sensor Circuit
P0461 00 [096] - Implausible Signal
Thinking the second one is just due to a bad fuel level sensor since it started popping up right after I installed a new Low Pressure Pump. Thinking the main issue is the first code.
Thanks for any help! Unfortunately logs won't really help because it's so intermittent and there's no way to trigger it intentionally.
