Results 1 to 2 of 2
    Aug 28 2009
    Atlanta
    Need help with bixenon conversion wiring and coding on a
    Hello,
    While doing the halogen to bixenon conversion, my mechanic is saying that there are no pins available to connect the kufatec harness wiring to the ECU - so Did somebody face this problem? Do I have the wrong module?
    Also my car is showing errors now after the retrofit. Does anybody have the exact vagcom codes for halogen to Bixenon conversion on an A5 (I see some posted for the A4 but thinking that this is not the right one).
    Thanks
    Veteran Member Four Rings V8Star's Avatar
    Jun 08 2010
    Quote Originally Posted by 101audi View Post
    Hello,
    Thanks
    The Kufatec wiring harness does not go to the ECU, it goes to the central electronics control module.
    There will be some error codes until you perform the coding changes. If I remember correctly, you can leave the two extra wiring pins disconnected and code the central electrics module and the lights will function without errors. However, the two extra wires that need to be pinned are for the high beams.
    R8 V10 Supercharged
    8V.2 RS3 grocery getter
    A few A4 Avants
