Results 1 to 9 of 9
    Feb 20 2010
    TT225, Touareg, Tiguan, TDI, A3, RS6, Jetta
    Brighton, MI
    2006 A4 Cabrio - not consistently working
    Sometimes the top opens, sometime closes.
    Most often, it stops somewhere in the middle, hydraulic motor just making noise.
    I don't know how the system looks like, but assume a hydraulic pump, reservoir, cylinders.
    It sounds like the system is low on fluid. NOT sure if that can be.
    a) how and where to start troubleshooting?
    b) is 'leak' possible? How to check?
    c) other suggestions?
    01 Allroad Tiptronic, TCU tune, mild stg 3 (350 HP) tune (stock injectors) KraftwerkTurbo TM1. Lower, Wider. Custom tip vent pod with Podi
    02 Allroad 6 spd, Kraftwerk Turbo TM6, 750cc, 3" MAF, piggy, FMIC, CM stg 5 (hate). 30 psi at 3600 rpm. Needs stronger rods (coming).
    05 Golf TDI
    Looking for 2001 A4 1.8T quattro manual with blown motor
    www.regulatorfix.com
    www.kraftwerkturbo.com
    Veteran Member Three Rings SprintBlueWorld's Avatar
    Sep 16 2013
    08 Hemi Big Horn, 08 Honda civic, 08 Audi S4 Cab MT6
    Pa
    The most common fix is to open up the top motor and clean the brushes. If the doesn't work it may require replacement. If the top isn't opening or closing at all the trouble is more likely the top position sensor, or the micro switch in the top storage compartment. Check out the cabriolet drawings on GenuineaudiParts.com
    Here's another excellent link
    http://www.audi-sport.net/xf/threads....131801/page-6
    Oem RS4 Reps, RS4 Pedals, KN Air Filter, JHM 93 tune, JHM Intake Spacers, Rear Stoptech Slots & SS Brake lines, JHM 6-Rib Pullys, 034 Snubby Bracket, Dimple/ECS Oil & Diff Magnetic Drain plugs, Apikol Diff Mount, 034 Carrier Mount Inserts, Corsa RSC Cat-Back, 034 Sway Bar & End Links, Piggies in a Blanket, Front JHM LW Rotors, Hawk HPS pads, 13mm Spacers
    Feb 20 2010
    Brighton, MI
    VAGcom any help to 'see' status of micro switches?
    Motor seems to be running fine, PUMP makes varying noises (and keeps running, even so top stopped moving). Hence also not believing it is electric (swtich).
    Motor/pump keeps running, just top not moving; top can be 'helped' by hand.
    05 Golf TDI
    Sep 16 2013
    Pa
    Yeah, I got that problem myself. Been meaning to deal with it by lubing the hinges on the bows maybe mess with the tension, but it hasnt been a huge issue. From everything I have been able to gather this has to do with the top motor itself. However concise information regarding cabriolet function is hard to find. Try the cleaning technique on the link I provided as it solves the most common issues. As I understand it the brushesi used on the motors were of poor quality.
    Feb 20 2010
    Brighton, MI
    Likely unrelated, but driver side (left) 'damper' (seems to have a cord or string hooked up) is leaking a bit oil/grease. I assume this short cylinder contains a tension spring and an oil dampener?
    05 Golf TDI
    Feb 20 2010
    Brighton, MI
    How do i get to the motor and pump and hydraulic reservoir?
    Where is it located (I think somewhere on the right (passenger) side of the trunk?)?
    I once heard/read someone talking about a leaking cover, and finding hydraulic oil in that area.
    05 Golf TDI
    Sep 16 2013
    Pa
    Yeah again the link above on page one shows how to get to it. Its on a passenger side in the trunk. Getting to it is the tough part. Woring with the motor was relatively easy.
    Veteran Member Three Rings IslandHydro's Avatar
    Nov 29 2008
    WA State
    If what's been suggested already doesn't help, you might want to post here: Convertibles-Only
    B6 S4 Cabriolet
    Milltek exhaust w/ SW tips, H9 fogs (DRL), denison Ipod adapter.
    Debadged except the rings, TWM Leopard shift knob.
    TD Pro Race 1.2 Wheels, Continental Extreme Contact DWS.
    Feb 20 2010
    Brighton, MI
    Quote Originally Posted by SprintBlueWorld View Post
    When i have the car here, I will dig down to the motor/reservoir. According to the instructions, there is a fill cap on the motor. I will check fluid level and top off fluid first.
    What fluid to use? The Audi power steering fluid (I think synthetic mineral fluid or so)?
    05 Golf TDI
