Results 1 to 8 of 8
    Veteran Member Four Rings zcspec's Avatar
    Aug 10 2015
    Need VAG-COM work, IM me
    Orange County
    Solowerks Coilovers for B8/8.5 Chassis, in Very Good Condition
    ***SOLD*** ***SOLD*** ***SOLD***
    I have a set of Solowerks coilovers for the AWD B8/B8.5 chassis (this includes the A4/S4/A5/S5/allroad). These will also work on a 2WD, but the rear spring rate is slightly stiffer. These coilovers are less than 6 months old and have no more than 5K miles. Even though they have gone through one Seattle winter, everything functions as it should. I have cleaned up the coils and placed a coating of anti-seize/anti-rust on the adjustment sleeves so they adjust up/down freely. You should have no issues what’s so ever.
    There are tons of reviews on the Solos. My impression is that the manufacture accomplished their goal of creating an extremely good daily driving coilover for the money. They are very comfortable and ride slightly stiffer than stock. These were replaced with a set of coils better suited for the track, at the expense of a harsher ride.
    Asking $325 for local buyers or $365 shipped anywhere in the Continental US. For extra funds, I can install these for local buyers.
    Front Shocks
    Front Helper Springs
    Front Springs
    Rear Shocks
    Rear Springs
    Rear Spring Perches
    Spanner Wrenches
    Feb 08 2016
    Portland
    Realistically priced too
    Established Member Two Rings Rated_ZX's Avatar
    Jan 29 2016
    Gurnee, IL
    Sooooo much want....
    Veteran Member Four Rings JeriQo's Avatar
    Jul 08 2015
    Install assist too?? Youre the man peter!
    Sent from my HTC One_M8 using Tapatalk
    2012 BB A4 P+ S-line Exterior |FBSW RS Paddles/Pedals|CR-15|AFE Filter|ECS inlet|S4 Dual Exhaust|Ace Convex 19x8.5|ECS 10mm rear|Solowerks S1
    Veteran Member Three Rings sferraro's Avatar
    Jul 19 2011
    Quote Originally Posted by zcspec View Post
    Interested but confused...So the set works on both B8 sedans and avants despite the heavier rear of an avant? I know Solo Werks made a stiffer spring on newer sets of coilovers for avants to reduce sagging. Wouldn't that spring be too stiff for a sedan? Does your set include the stiffer rear springs?
    EDIT: I've got an avant.
    2013 allroad
    revo Stage 2 | revo intake | SPM exhaust | KW V3 coilovers | B9 S4/5 + B8/8.5 S4 calipers | STaSIS rear sway bar | R8 oil + coolant caps | BBS Ti CH-R | RS5 Ti rotors | RS4 spoiler | S5 mirror caps | E-codes | Thule Dynamic 800 | RS4 FBSW | S4 pedals | Piano black inlays
    2018 Q7
    SQ7 FBSW
    IG: sfavant
    Aug 10 2015
    Orange County
    Quote Originally Posted by sferraro View Post
    You are correct, the newer series of springs are stiffer for the avant than the sedans to reduce the sag. The avants at most, are slightly heavier than the sedans due to the rear hatch but we're not talking about several hundred lbs here. Also keep in mind, the Solos are a progressive rated springs as opposed to a linear rated one. Because of the progressive nature of the spring, that difference in stiffness isn't going to make a tremendous difference.
    Jul 19 2011
    Payment sent.
    2013 allroad
    2018 Q7
    SQ7 FBSW
    IG: sfavant
    Aug 10 2015
    Orange County
    Payment sent.
    Thank you for the purchase!
