Page 1 of 3 123 LastLast
Results 1 to 40 of 111
    Account Suspended Three Rings
    Oct 15 2015
    B8 brakes / q7 18z calipars
    Ok guys, I bought the 18z calipars and pads. Tryed to install these lastnight and realized I need different rotors. Does anyone know which rotors I need to run with these calipars on my b8 s4?
    Veteran Member Four Rings theswoleguy's Avatar
    Dec 07 2012
    Atlanta, GA
    Q7 brakes or Q5? Didn't know q7 brakes bolted on
    Sent from my Nexus 6P using Google's ProjectFI
    '01 Audi TTQ Roadster: QED motor, Pag 35R vband, spec twin, E85, Sold
    '03 GTI: Gutted, Parted & Transplanted
    '04 F250 6.0: 72mm turbo, 60 psi stupid fast for 8k lbs, Sold
    '15 Audi S4: Stock, S-Tronic, B&O, NAV, ADS w/ Sport Diff, Smart Key, glacier white w/ magma red, 19" Shamrocks lol
    Veteran Member Four Rings s4matty's Avatar
    Aug 15 2015
    2 feet
    Niagara canada
    Ya Q7 bolt on but not sure on the rotor..I run the 18z (Q7) with b7 s4 rotors on my c5 all road
    Sent from my SM-G900W8 using Tapatalk
    Jun 12 2015
    CA
    I believe the Q7 has a different bolt pattern.
    Oct 30 2008
    B5, B7, B8, 8V, 4M
    Big Lake, MN
    Something 350mm. I believe ml55 rotors are popular with that caliper. Nit sure how the offset works for you. As noted, q7 is 5x130 so those rotors will not work
    2020 SQ7- Wife's ride
    2000 S4- Working?
    Nov 01 2015
    2012 Q7
    FL
    I have a set of rotors if you want measurements
    Oct 15 2015
    Yes please! I'd like to get this swap done!
    Established Member Two Rings lapsandwich's Avatar
    Sep 28 2015
    Langley BC Canada
    Porsche Macan rotors are 350mm and are the correct bolt pattern 5x112. Just wondering about the offset though..
    Nov 01 2015
    2012 Q7
    FL
    What measurements?
    Dec 10 2011
    991 C2S, Stage 3 S4, E46 M3
    CLT | MKE
    I'm surprised you were able to bolt these up. Some before you tried and reported that the caliper body contacted the upright. Thus, I don't believe there are any B8 owners who've actually run this setup yet, and you'll need to make some calculations or test to find a rotor with the proper offset.
    As far as rotor options, you could look into the MB GL450 (350x32) and ML55 AMG (345x32) rotors.
    -Hayden
    B9 Q5 | Brilliant Black
    E46 M3 Cab | Steel Grey
    Veteran Member Four Rings infinkc's Avatar
    Feb 14 2004
    S Ã C, CÃ*
    Almost positive they don't bolt up. I think only the 19z work with brackets on the b8.
    There are 10 kinds of people in this world, those who know binary and those who don't.
    Oct 15 2015
    18z calipars as well as 19z calipars have the same distance in bolt holes. They bolt up.
    Dec 10 2011
    CLT | MKE
    Quote Originally Posted by Kustomimports View Post
    Yes, the bolt spacing is correct, but people report the caliper body hits the upright.
    Have you actually physically mounted them to the car yet?
    -Hayden
    Oct 15 2015
    I'll do it over the weekend and let you all know... I might of found a oem rotor that will work also.
    Jun 16 2016
    United Kingdom
    Hi OP Did you get chance to try the 18z's or any pictures this weekend?
    Oct 15 2015
    The calipars bolt up with minor timing to the heat sheild. The rotor I'm testing this week. Had to order some
    Jun 16 2016
    United Kingdom
    Cool, I'll try and pick a set up should be a nice conversion for pedal feel and possibly a thicker disc..... Any pictures would be appreciated
    Sep 28 2015
    Langley BC Canada
    Where the pics attttttt?! And what rotors are you using?
    Senior Member Two Rings lowjonathan's Avatar
    Jun 30 2015
    nice...
    18z bolt up directly...
    sub for the rotor fit up...
    thanks
    Volk racing G25
    KW v3
    Hotchkis ARB
    034 adjustable upp arms
    034 tranmission inserts & mount
    Uprated front bushing.
    CTS intake kit
    CTS SC pulley
    KI 184mm crank
    Custom tuned with DSG remap
    Jul 29 2015
    UK
    Great work, keep us posted on the rotors!
    Sep 28 2015
    Langley BC Canada
    Hey OP, what rotors did you order ?
    Jun 16 2016
    United Kingdom
    I'm not the OP but some maths and a lot of hunting through specs made me think that GL500 rotors might be close
    Screenshot in the link
    https://www.dropbox.com/s/6ju1clr9k6...14954.png?dl=0
    Would love to know if they do fit, if the calipers can be mounted I'm going to order some and try.....
    Senior Member Three Rings Li ls4's Avatar
    Jul 19 2014
    2011 s4
    Long Island
    Definitely interested in the outcome of this. I've been trying to get myself to buy the q5 calipers but if the q7s work I'd rather get those
    Sep 28 2015
    Langley BC Canada
    I'm a little confused exactly on what I should be basing the rotor offset on. The q7's offset ? Of the s4 ?
    Dec 10 2011
    CLT | MKE
    Quote Originally Posted by lapsandwich View Post
    You'd want to measure the difference between where the center of the 18Z calipers sits (when mounted) in comparison to the stock caliper, and then adjust the rotor offset/height accordingly.
    A little very quick math. For the B7 S4 (which uses the same caliper as the B8), the rotors for 18Z had a rotor offset/height that was 3.7mm more than the stock rotor, for reference.
    47.3 was the stock rotor height, ML55s (primary 18Z rotor choice) is 51mm.
    For the B8, the stock rotor height is 51.9mm, so maybe something around 55-56mm height?
    The GL550 rotor is 54.8, so in the ballpark. That may be the same as the GL500 one that was mentioned above. He's on the right track.
    -Hayden
    Jun 16 2016
    United Kingdom
    That's exactly how I drew my conclusion GL500 rotors are a 55mm height
    Sep 28 2015
    Langley BC Canada
    Ohhhhhhh okay. That makes a lot more sense. I'm really
    Hoping the OP throws a picture up of the calipers mounted for a little confirmation on the fitment. Z18s are relatively easy to source and the price is a little better then the Q5 four Pistons.
    Oct 15 2015
    Sorry guys yes I'll post pictures. The calipars bolt up. But the project is on hold atm. Something came up. I'm still on it tho give me a week or 2. A 2010 cl 600 rotor looks like it will do the job. I'll order one and double check it in a week or so.
    Jun 16 2016
    United Kingdom
    cant wait for pictures........ slightly excited lol
    Sep 28 2015
    Langley BC Canada
    What about having the q7 rotor redrilled for 5x112
    Dec 10 2011
    CLT | MKE
    No, Q7 has totally different hubs and the fitment is much different.
    -Hayden
    Jun 30 2015
    any updates on the rotor used?
    Volk racing G25
    KW v3
    Hotchkis ARB
    CTS intake kit
    CTS SC pulley
    KI 184mm crank
    Oct 06 2014
    Cleveland, OH
    Does anyone make an adapter for the 18Z that you can buy seperatley? For the B8.
    Established Member Two Rings pcardenas's Avatar
    Sep 04 2014
    S4 B8, Audi Q7
    México
    I have a q7 and always look "hugry" the front calipers with 3 pistons. These are 18Z ?????? will fit directly on our B8 S4 front?????
    Oct 06 2014
    Cleveland, OH
    Quote Originally Posted by pcardenas View Post
    OK, so the 18Z caliper fits, the 19Z needs the adapter? But the 18Z needs a special rotor that the OP is attempting to source? Got it. Sorry for my confusion, trying the source a BBK for less than $2K ahs me all confused!
    Has the OP contaced Adam for rotor options?
    Aug 15 2015
    2 feet
    Niagara canada
    Quote Originally Posted by SR7D1 View Post
    I have a set of 18z calipers with b7 s4 rotors if your thinking of doing the swap..
    Oct 06 2014
    Cleveland, OH
    Quote Originally Posted by s4matty View Post
    Sent you a PM
    Veteran Member Four Rings UkuRiSh's Avatar
    Jan 09 2010
    New York
    Awesome thread, I'm glad someone start this! I was planning do that too.
    2013 AUDI S5 4.0T SWAP 9.7@145mph < Press @svarog_performance < last test updates
    Oct 06 2014
    Cleveland, OH
    Sent you a PM the other day.
    Mar 04 2010
    95.5 Audi S6 Track car 2010 S4 with mods 2006 Audi A4 2.0T S line w/ mods, 1974 Alfa Romeo 2000 GTV
    NY/NY
    I don't think B7 S4 rotors are going to fit the B8 S4. The center bore on the B8 S4 is 66.6 mm and the B7 is 57.1 mm.
    2019 Ara Blue RS3, APR Stage 3, DSG tune, UM Haldex tune, TTE700, APR 4" turbo & throttle inlet, rear carbon tube, pendulum mount & dogbone insert, Tyrolsport Front Deadset Kit & Harness bar, Superpro LCA bushings, CSF radiator, JDY Performance oil pan, APR FMIC, Race Downpipe, catted Mid Pipes, Milltek exhaust, Wavetrac LSD F&R, KW Clubsport 4 coilovers, Neuspeed tubular sway bars and 350mm rear rotor kit, AP Racing CP9660 BBK, RSE11R 18X9 45mm offset wheels, 265/35 Michelin Pilot Cup 2 squared
