You messed up something with them:
Enable Front Turn Signals as Parking lights
[09 – Cent. Elect.] [Coding - 07] -> Long Coding Helper -> Byte 10
Bit 0- Check the box or change :Bit 0 to 1
Once the change has been made you can enable the front turn signals as DRL's by making the following change:
[09 – Cent. Elect.] [Coding - 07] -> Long Coding Helper -> Byte 2
Bit 6 - Check the box or change :Bit 0 set to 1
Its enabled on my car aswell, but i changed adaption channel 5 to 0% to keep them off, could be wrong but difference is if its enabled like this(turn as parking) turn should fade in/out slower, then only blink.
