Results 1 to 17 of 17
    Junior Member Two Rings
    Jul 01 2014
    Upstate, NY
    C5 A6 Avant Roof Rack Fairing w/ Sunroof
    I want to get the fairing for my Yakima roof rack, but I'm curious how it will mount relative to the sunroof? The factory rails don't seem long enough to get the fairing in front of the sunroof, and if it is mounted behind the sunroof seems the rack would be too far back? Anyone have a fairing on their Avant that could shed some light on the subject for me, maybe even a pic of how it looks?
    Aug 04 2009
    Glen Ellyn, IL
    This is what I've got that shows placement, if you're still needing a better illustration I'd be happy to take more pics tomorrow.
    My Thule fairing sits JUST in front of the sunroof and the feet are mounted pretty much as far forward as they can be. It works perfectly.
    OEM+ work in progress allroad
    Unicorn Society member #8
    @fourings | Build
    Sep 16 2010
    Central Wash
    OMG! What a peace of junk! Is it peace? or piece? Dammit. That's harrible. You parting hat out? BBD swap?
    You're not going to win with a rack fairing, there's no real good placement/ design that makes your effort really pay off the way your brain adds it up. But it can look cool, it can help maybe a bit with wind diflection ...diflecting wind.. redirecting current... is there a word for it?
    But don't listen to HIM ^ with his off road jeep type animal. Since when did jeep need a fairing? Okay, so 4 Moscow Mules in to a sunday night I'll say just make one.
    IF you had a beautiful car, such as, say..a Polar White S6 (see pic below), you might consider some major expenditure of cash to procure a proper roof racking system
    I really don't have much to add.
    Except you're right. There's no really rack system that makes a fairing sit in the right place and accomplish any wind shear blocking noise cancelling effect. I ended up making one a while back, and trimming a section around the bike rack, and doing this or that. Honestly I don't think it helped at all but it looked pretty good.
    Jul 01 2014
    Upstate, NY
    Quote Originally Posted by 4rings2turbos View Post
    What's the width of your fairing, Yakima website lists a 44" for my car.
    Veteran Member Four Rings PaperToast's Avatar
    Apr 29 2009
    Quadzilla
    Longmont, CO
    i personally wouldn't worry about it
    i had to take the fairing off my thule moab roof basket. reason: with the sunroof open, the headliner would inflate
    besides, id rather have the air going through instead of hitting the fairing.
    sure it makes some wind noise at 40mph+, but if im going on an extended trip, it comes off
    Rockin' the Rockies
    '01 allroad, 250k woot woot, still boosting on original turbos and tippy, slightly modified. . .
    Scotty@Advanced, "Push it off a cliff, when it hits the ground you should have a few thousand horsepower available for a brief second."
    Veteran Member Three Rings Renegade5's Avatar
    Mar 01 2010
    '08 RS4 '05 Allroad
    MA
    Kind of off topic, but can cross bars be mounted behind the sun roof? I'm going to be throwing a Thule set up soon, and it would be ideal if the front bar was behind the sunroof, so that it can remain open w/o the front bar in the sunroof opening. that possible? I've seen a lot of pics of bars on AR's, and some look like this setup is possilbe.
    '08 RS4 Ti
    '05 Allroad
    '21 SQ7 Prestige
    Jul 18 2009
    D2 S8, E61 535xi, B5 S4
    Subdivisions, NW burbs
    Mine are right behind it on c5 ar. No issues. Tips up flush to my whispbars
    Jul 01 2014
    Upstate, NY
    Here is my C5, probably going to have to move the crossbars forward for the fairing though:
    Aug 04 2009
    Glen Ellyn, IL
    Quote Originally Posted by rollerton View Post
    I had a Polar White S6 once. Hated it. Worst car I ever owned.
    My fairing is 44"
    Much quieter with fairing in place and it doesn't interfere with any of the sunroof functions.
    @fourings | Build
    Jul 01 2014
    Upstate, NY
    Well the fairing idea didn't go as well as planned. My front cross bars do not come far enough forward for the fairing to clear the sunroom, and if I set it up with the fairing behind the sunroof it looks very odd. Not to mention the fairing doesn't fit in between the factory rails. Good info on your site Yakima, saying 44". Could cut it to work, but then I'm stuck with it... Hmmm...
    Active Member Two Rings iandonovan's Avatar
    Aug 20 2015
    Wausau, WI
    I have a yakima rack on my allroad. I've moved it back and fourth so many times. The yakima fairing won't sit in front of the sunroof. So for a while I had my fairing in sitting in the middle of the sunroof, because I never used it. But I recently moved the rack back so now the fairing is just behind the sunroof so I have full use of it. Much quieter. But yeah because of the side rails the yakima fairing will never sit in front of the sunroof. And actually you really don't want it to, because then your cross bars will be at an upward angle. With the crossbars back more behind the sunroof it evens the bars out so they're more level, less wind resistance.
    Jul 18 2009
    If you search you might find an old style one that has longer extension arms. The old ones used to extend out further. Less aero and more rectangular. That said, I have had one that basically blew up and disintegrated going about 80. We have run ours further back behind the sunroof and it was still functional with bike trays on a b5 avant even, so you would have more useable roof space on c5. And ya, you are going to need a narrower one to fit between the rails.
    Jul 01 2014
    Upstate, NY
    Quote Originally Posted by iandonovan View Post
    I went with what Yakima said and used a 44", it doesn't sit inside of the factory rails. Maybe I will try to find a smaller one and sell this 44" before I cut it to shreds. Do you have a pic of yours mounted behind the roof?
    Aug 20 2015
    Wausau, WI
    Quote Originally Posted by MW3Designs View Post
    You have an allroad? Their recommended size for a fairing is 38" and that's what I got and it fits perfect, so go with that. I do have pictures....Just don't know how to post them on here lol....
    Jul 01 2014
    Upstate, NY
    The car is a A6 Avant, going to measure between the factory rails and get a fairing that will fit between them. Took another look at cutting it, but I would have to cut thru the Yakima logo. Could always mount it backwards and put my vinyl cutter to use..... Guess I'll see what tomorrow has in store.....
    Aug 20 2015
    Wausau, WI
    Bad pic (my front bags recently gave out lol)
    Aug 20 2015
    Wausau, WI
    Also, if you just go to yakimas website and put in your car info it will tell you what size. Or go to their website, bottom right of the page you can find car specifications and that will show you everything that will fit your car. super simple.
