Originally Posted by
vavJETTAw36
Should still start with 12.6. As corrado has stated, check your ground on the passenger side up under the lower inter cooler hose. Your alternator also connect to this point as well as the ground to your battery. If it visibly looks ok do not trust it. It can corrode between mating surfaces.
Quick health check:
Put voltmeter on battery. Note voltage. Keep positive lead on positive and take ground and put it on engine block. Note voltage. It will probably have a drop in voltage and that is indicative of bad ground.
Battery+ to Battery- = 12.6V
Battery+ to engine block = 12.6V
Also, I only hear one "click" when I turn the key...?
