Results 1 to 19 of 19
    Established Member Two Rings MathildaS3's Avatar
    Apr 14 2015
    Palm Beach Gardens, FL
    2 miles, and I miss my JB-1 already...
    I removed my JB-1 this morning in preps for my 5K mile service. I must say, Mathilda feels like a dog without it! Can't wait to reinstall!! That is all.
    2016 Sepang Blue S3. MagRide, SuperSport seats, B&O, RS3 grille, wheel spacers 10mm/17.5mm, K&N drop-in filter, stock intake mod, LED interiors, Spulen engine mount insert (modified), BMS JB4 tune. Sleeper AF...
    Veteran Member Three Rings jiannu's Avatar
    Mar 23 2016
    Ontario,Canada
    LOL!
    I too am coming up for my 8k 1st oil change and kinda nervous as I have a few mods .....
    Jan 15 2010
    Santa Barbara, CA
    I have a Neuspeed power module to remove before my 5k - did you clear codes (assuming there are overboost codes in there somewhere), or are you just putting miles on before the service?
    I was contemplating removing it, buying the Eurodyne tune and home install kit, using it to clear codes, and then just going Eurodyne Stage 1.5 after.
    Nov 17 2014
    San Francisco, CA
    I feel your pain! I drove for about 200 miles prior to my service without it and it was the longest 200 of my life!
    Fwiw, I was lazy at my 25k service and kept it on, dealership said nothing until they screwed up my car and then tried to blame me because of mods... tho had nothing to do with the problem.
    Apr 14 2015
    Just gonna drive 80-100 miles to be 'safe'. 👍🏼
    Senior Member Two Rings 16s3pang's Avatar
    May 07 2016
    07 Mazda MX-5 PRHT
    Goffstown, NH
    Quote Originally Posted by forbiddenbeat View Post
    What do you think of the module? I'm contemplating on getting one and wondered how hard it was to install and if you can really feel the power increase?
    TIA!
    |2016 RS7|
    |Sepang|Dynamic Pkg|B&O|Comfort Seats|Aluminum Atlas Inlays|Cold Weather Pkg|Milltek non-res exhaust|Roc-Euro intake|034 Motorsport Drivetrain Inserts|
    Jan 15 2010
    Santa Barbara, CA
    Quote Originally Posted by 16s3pang View Post
    TIA!
    I like it, the power increase was noticeable and makes the car more fun. The install was straightforward, but without a jack or ramps, getting the boost tap plugged in was quite something. My hands were bleeding and I swore a lot, but I got it done. With ramps, the whole thing would take 5 minutes.
    Nov 17 2014
    San Francisco, CA
    Ya take the bottom cover off cuz it's not easy to get to the plug
    Oct 01 2015
    Karachi, PK
    Happened with me too and couldn't wait to install it back, the most painful part it to re-install all the plugs especially plug D
    2015 A3 1.8TFSI 7speed S-tronic (FWD)
    Engine mod BMS JB4/ Revo catless DP/aFe dryflo drop-in/stock intake mod/Revo MQB Intercooler/Revo muffler delete/CTS TIP/GFB DV+/034 dog-mount ......VCDS mod visual parking aid, needle sweep & oil temp on DIS
    May 07 2016
    07 Mazda MX-5 PRHT
    Goffstown, NH
    Thanks for the info. Looking to get this after the sound enhancing resonator. :)
    |2016 RS7|
    Jan 15 2010
    Santa Barbara, CA
    Quote Originally Posted by mroberte View Post
    Yep, I removed the cover, but with the car on flat ground it's a b*tch to get to the tap. You have to contort your hand in all sorts of weird ways. Doable, but I recommend ramps or a jack.
    Someone claimed to have accessed the tap from the top, but I don't see how. I did end up releasing the harness from the top with a long flathead screwdriver, but still had to plug things in from the bottom.
    Jun 16 2015
    Nevada
    Quote Originally Posted by MathildaS3 View Post
    Did you clear the codes before going in?
    Apr 14 2015
    I will. Appointment is tomorrow.
    Jun 16 2015
    Nevada
    Have the best recommendation for this? Is the Ross-Tech one the only way to go?
    Mar 06 2016
    LI/NY
    Quote Originally Posted by s3saloon View Post
    what codes are supposed to be cleared after removing the JB1 before going in for his 5k service ???
    was under the impression that the tuning box left no telltale signs in the ECU.
    Please explain, thanx.
    May 25 2016
    Quote Originally Posted by esss 3 View Post
    was under the impression that the tuning box left not telltale signs in the ECU.
    This.
    Jan 17 2012
    '14 S4, '15 Subaru Forester
    Los Angeles, CA
    There shouldn't be any codes. As long as you;re on map 1, everything is within OEM limits (fuel trim, etc).
    Jun 16 2015
    Nevada
    Quote Originally Posted by drew4392 View Post
    You sure about that?
    Apr 14 2015
    There were no stored codes when I scanned, but I hit the 'clear codes' button any way. Easier than wondering if there was something I missed. All's well with the service, no flags. JB-1 and filter back in, and she's a monster again!
